Home > General Chat > a-series turbo-supercharged
sean g
Member #: 9184
lancashire bolton
Has any one ever turbocharged and supercharged an a-series had a look on the web but couldn't find nothing.
Cheers sean
Clubman Ben
Member #: 8909
North Cornwall
Would love to see it done.
If in doubt... flat out! The words of a true legend
Clubman Ben
Member #: 8909
North Cornwall
Ben H
Member #: 184
Melton Mowbray, Pie Country
It has been discussed many times on this forum, try the search. Tu summarise:
Pros: None
Cons: Everything that is not a pro.
http://www.twin-turbo.co.uk
Yes but probably not at the same time. *tongue*
isnt the new polo?
and i cant remember if it was a super-turbo micra,
it has been done/doing...
there has to be some gain, if done properly,
go then sean go for it!
I know of one such car in Norway. A 7 porter.
kenny2
Member #: 5362
wexford in ireland
micra super-turbo my dream car!!! 1 litre and 105 horseys standard.
On 5th Jan, 2011 wolfie said:
Mini_the_minx
Member #: 9077
Cheshire
I know someone who was going to be doing it. If he did I don't know but it wouldn't surprise me if he didn't, too many problems.
On 2nd Nov, 2010 wil_h said:
Asphalt
Member #: 1027
Germini, black forrest
These have been posted on here a while ago:
[X] nail here for new monitor
johnnysti
Member #: 2480
Would be easier when a blow through system is available *wink*
From the research i have done for it, the mirage turbo setup would make better use of space. Those pics are of the M24 blower which is quite a bit smaller than the M45 which would also help.
feature=mhum
The SC has an actuator, so it would be easy enough to do mappable boost control with it...
What are the main advantages?
Boost from idle?
Personally I would just go with an appropriately sized turbo.
johnnysti
Member #: 2480
Im guessing the supercharger would feed the turbo and act as anti lag. I do have to agree with john though and say for all the work that would be required to make it work, sorting a correct turbo would be an easier route. But where is the fun in that!! lol
feature=mhum
Asphalt
Member #: 1027
Didn't David Vizard talk about nitrous to combat boost lag? Or what about VTG turbos? Are they yet available for petrol engines? They seem to be fairly common for diesels, but I remeber heat being the problem for petrol applications...
I was talking to a kid at the Renault world series with a R5 GT Turbo and he had a VNT turbo on that. He said he was getting 18psi of boost just below 2000rpm! He's either mastered the VNT control or he's mastered bullshitting.
I think you have to consider why manufactures may do it and why one of us might want to do it.
Manufacturers will want to make an engine that has the best compromise between fuel consumption and power. However a large highly efficient turbo will have a high boost threshold, so the SC is on to compromise, well this is my guess why.
Us lot on the other hand want lots of power. Now we know a turbo that is available that boost from 2k ans will produce n excess of 200bananas, so why as a supercharger, just ballast as far as I can tell.
Rick.SPI
Member #: 8027
Just a quick bit. My old man new scirocco is 2litre turbo and supercharged, the r model and it has power like no other turbo car at the bottom end and has it all at the top. I would love to see it done on an a series.
Chris Dillow
Member #: 6647
Avon Park Class B winner 2010/11
milton keynes
There was a fiesta super-sport that used to be up POD alot that had both on a cvh. I can't remember times it did but did go very well
Joe's point is very clear. Think if the weight saving too!
clubman91
Member #: 8923
North Wales
http://cgi.ebay.co.uk/Ford-Fiesta-XR2-Supe...=item41564a1286
Star Mag
Member #: 375
Leicestershire
There are quite a few lads running vnt turbos on the Renault club. From what I believe they take a lot of adjustment to work correctly.
Not something I have looked into though as the turbos weren't cheap to buy!
nutter driver
Member #: 47
Not very sunny swanage
there was one in aus a few years ago iirc.....
it was in one of the magazines , if memory serves me it was red, pictured next to a massive pile of bricks and the reg was something like qik 850 or something...
