Page: |
Home > FAQ / Knowledge > Fuel line sizes | |||||||
11th Apr, 2005 at 12:53:40pm
Right, ive always gone with 8mm there and back to be fair but with the new car im considering: Edited by iain on 11th Apr, 2005. |
11th Apr, 2005 at 04:30:29pm
Iain,
On 11/04/2005 12:53:40 iain said:
Right, ive always gone with 8mm there and back to be fair but with the new car im considering: 1/4" ID (6.35mm) feed 3/8" ID (9.53mm) return Then i wont have to worry about putting a restriction in. Im assuming that 1/4" will be more than enough to supply the engine upto 200bhp ish? Or should i go with 5/16" ID (7.94mm)? using 10mm to the pump as thats what the pump has as an entry, then the 1/4" from the exit of the pump with a ???? filter between the tank and pump On 17th Nov, 2014 Tom Fenton said:
11th Apr, 2005 at 05:10:43pm
Ok will do, fortunately i work right next to the fuel systems guys at work now so I'm sure they can help me out with the maths too |
12th Apr, 2005 at 12:09:37am
Are plastic fuel lines ok for the MOT,I have poly flo(american make) tubing on my golf and its petrol proof comes in yellow red and green 1/4 to 1" dia free from work ! joins using stainless compression fittings and nylon or stainless olives.can remember my mk2 escort had black plastic petrol pipe just wonderd if the rules changed.
12th Apr, 2005 at 07:33:00am
they should be as i think most new cars nowdays run plastic fuel line under the bonnet.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
12th Apr, 2005 at 08:04:37am
Quote from
Site Admin ![]() 9404 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
12th Apr, 2005 at 11:09:22am
I'll need the next size up from you then iain, LOL On 15th May, 2009 TurboDave said:
12th Apr, 2005 at 11:30:46am
Just trying to find the rating of the fuel pump in gph to find out what return to use..
18th Apr, 2005 at 07:23:01pm
If 8mm + fuel line is used do the inlets/ returns on the fuel reg need drilling out to 8mm as it's only 6mm normally so could be restrictive.
1171 Posts Member #: 107 Post Whore Sunny Sussex |
27th May, 2005 at 11:15:22am
fueling noob question... whats the deal with a restrictor? I'm just about to plan my fueling so am i correct is saying..
27th May, 2005 at 03:43:13pm
Restrictor reasoning here:
27th May, 2005 at 04:07:02pm
so am i right in saying that if i'm using 6mm feed, i wont need a restrictor if i have an 8mm return? The restrictor only reads as being nessesary if the feed and return are the same size. Edited by Mike on 27th May, 2005.
27th May, 2005 at 04:14:13pm
46 Posts Member #: 733 Member Gatwick |
6th Dec, 2005 at 11:19:16am
been using the standard supply pipe, ie. 6mm and a 9mm return with std bosch 36psi pump on my turbo for 12 years now with no problems, I hope this old set up will be OK with my FI system, I can't see why not? I am currently at 138bhp with no problems?
19th Jan, 2006 at 10:01:44pm
sorr yam confused surely the regulator will need drilling out to 10mm as well then otherwise that will be the restrictor as it isnt that big
19th Jan, 2006 at 10:25:08pm
In the Queens English please....
Edited by TurboDave16V on 19th Jan, 2006. On 17th Nov, 2014 Tom Fenton said:
19th Jan, 2006 at 11:10:42pm
On 18/04/2005 19:23:01 Dangerous said:
If 8mm + fuel line is used do the inlets/ returns on the fuel reg need drilling out to 8mm as it's only 6mm normally so could be restrictive. I said that before
19th Jan, 2006 at 11:11:45pm
sorry what dangerous said above
19th Jan, 2006 at 11:21:21pm
Fuel regulator pipes are (i recall) 8mm?
1300 Posts Member #: 829 Post Whore essex |
19th Jan, 2006 at 11:27:04pm
no way you will drill out to 10mm 8mm max 1293 Turbo mini
20th Jan, 2006 at 06:29:32pm
so there is no point in using a 10mm return line at all, just restrict the feed? |
12th Feb, 2006 at 06:55:34pm
dave how are you going to use a 10mm return then if the regulator is 8mm? sorry to bring this up again, gav |
12th Feb, 2006 at 07:02:38pm
Perhaps you can highlight where i said i was going to run 10mm return? On 17th Nov, 2014 Tom Fenton said:
12th Feb, 2006 at 08:57:03pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=1456 sixth paragraph down |
12th Feb, 2006 at 09:10:04pm
ah - no wonder i couldn't see it here ^^^^^^
On 21/05/2004 13:21:59 TurboDave said:
I'm only doing this as i can't rule out the return to fuel injection or Nitrous in the future, and restrictors in the supply line are not what i need! As it is - I'm now using -6 line feed and return. the outlet from my new pump is only 5mm so the ultimate flow potential is governed by this... On 17th Nov, 2014 Tom Fenton said:
Page: |
