Home > General Chat > MEDs cam gear drive
I know its been out for a while but what are peoples thoughts on it?
Paul
PaulH
Member #: 2340
Dublin Ireland
You mean Brian's Timing gear kit :)
http://www.slarkraceengineering.co.uk/camshaft_kit.htm
On 17th Feb, 2009 Rob H said:
I know Steve didnt design it, but he has re engineered it in conjunction with Brian
MEd are turning into just another stockist, imho.
carl
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
carl
True, but i does not stop this being a top peice of kit.
If you have the budget, class. On anything else, other than an all out build, id say it was overkill.
what is the backlash on these?
I still favor the belt drive.
The backlash is whatever you set it at depending on where you fit the idler bracket. I cant remember atm what it should be set to
Paul
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
i had a set, makes your engine sound very rattley.
16V project underway
1972-ANGUS
Member #: 3894
Also very true, especially when accompanied by sc drops.
Noisier the better as far as Im concerned. lol
I keep wondering if there's less friction than a chain and if there is, does it outweigh the extra bit of weight of the gear drive.
Paul
obviously you wont get the timing chain stretch ether, another pro for the gears
SidewaysGTM
Member #: 5022
Oxford, Kings Lynn, Pod, Pub.
More weight to caryy around and more to spin up too i would had thought compard to a chain, what about belt drive on nice light weight alloy pullies
West
Edited by SidewaysGTM on 10th Dec, 2009.
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!!
Had a belt on it, pulleys are very heavy steel
you need to get some made in aluminium
The complete assy would still be heavier than the chain arrangement I have. I just wonder if there would be less friction with the cogs than a chain and outweigh the weight
Edited by paul wiginton on 10th Dec, 2009.
johnK
Member #: 690
Norfolk
hmm, I think if you set the backlash correctly the driven losses should be less - something you'd have to measure - may be worth a little bit - for the price though not as much as giving the two inner cylinders more spark than the outer two though Paul.lol!
JK
If Carling made Mini engines
Thats something Im looking at aswell John, thinking no counterbalance on the crank too, I have a massive list, just no budget
Paul
wev'e all got massive lists and tiny budgets,lol
Carl, you have budget and penis mixed up again mate. lol
yes i still have a massive former and the tiny latter,lol
What do you mean, a massive butt and tiny penis?
F1 engines are gear driven, why?
SidewaysGTM
Member #: 5022
I would hazard a guess to the harmonics associated with 18K rpm would have a role.
west
west
i have the same problens with the DON,lol
