Home > General Chat > baulk rings - gen rover or minispares competition?
welshdan
Member #: 1111
s wales
hi chaps, i need to fit new baulk rings to my gearbox. its a fast road car. what do people use? gen rover or minispares competition?
are the competiton ones suitable for road cars? are there any issues with wear rates (of the baulk rings or other componets) when using the competiton ones?
i asked this in the beginners part, but have not yet found the answer im looking for.
advice much apreciated.
thanks
When I rebuilt my gearbox, I looked at the original bulk rings and refitted them, as overall they looked better then the minispares competition ones I had just bought. Though others may have experiance with the minispares competition ones.
If the original ones are OK, I always use these.
welshdan
Member #: 1111
s wales
they need replacing, got a few gear change crunches.
other than that the gearbox is fine. is it worth chaning the needle roller bearings as matter of course whilst its apart? thanks
Can you get some out of another std box?
All the minispares ones ive ever had havent been suitable for using
kstead
Member #: 1126
peterborough
rebuilt my box with minispares ones, tried to use 4 of them but couldn't get it to run freely. Ended up using 2 new(1st 2nd) and 2 used
turbo hogster
Member #: 178
stowmaket suffolk
place the baulk rings on the gear cone you want to aim for about 1mm between ring edge and syncro teeth.
any less then they may crunch between gear changes.
but try old ones first
nick1275
Member #: 1615
Ferndown, Dorset
i got a new box built up by med, i cannot remember what baulk rings they used but they went tits up in 2 mins, they replaced them at there cost with gen rover, taken just over 4000 miles abuse and still going strong with no probs
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind.
welshdan
Member #: 1111
s wales
thanks. looks like this concludes that gen rover are the ones to go for.
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
a mate of mine used the comp spec ones and had to pull the box apart as they where sticky. from the 4 points of wear in the cone id say a heat treatment process deformed them during manufacture.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
