| Home > General Chat > o/t clio headlights stopped working :-/ | |||||||
27th Mar, 2012 at 05:45:16pm
Good evening chaps, en route home i noticed my passanger side headlight was not working, so when i got home i changed the bulb, it still was not working after i had changed it so i thought i would try the one that does work, so removed that one and swapped them over. It still did not work after this so i put the bulbs back how they were and now neither work.
27th Mar, 2012 at 07:11:22pm
100% its not fuses? my volvo has 3 fuse boxes and are fused left and right caused alot of head scratching when the trailer blew a bulb and fuse Yes i moved to the darkside |
27th Mar, 2012 at 07:38:49pm
Check the Relays, under bonnet Fuses and check the earth to the lights aswell
27th Mar, 2012 at 07:50:10pm
we had this with ollies shitty vauxhall he put the wrong bulb in and it all went to pot, i would say both bulbs are now blown now what bulbs are they?
27th Mar, 2012 at 07:54:40pm
just looked it up there H7's i have a couple here if you want to try them or pop to asda as there only a couple of quid each so worth a try
27th Mar, 2012 at 09:09:26pm
make sure you have the radio code and disconnect the battery for a bit. body controll module may be having a fit. also test the wires to the lights with power on and see what they show. also, check the holders are making contact correctly and test the bulbs with a battery yourself. from that you can start to decide whats playing up. turbo 16v k-series 11.9@118.9 :)
27th Mar, 2012 at 09:11:00pm
and finally, if the headlights are controlled on a stalk like the indicators, there shit. there will be about 8 orange single core (brittle) wires which have to move each time the switch moves. and they always brake. easy enough to dismantle and fix. turbo 16v k-series 11.9@118.9 :)
7th Apr, 2012 at 07:34:20pm
The new bulbs i tried were asda cheapos turns out it was them! No current passing through either so got aome new ones £20!! And they work perfectly now winner Drives
7th Apr, 2012 at 08:58:30pm
7th Apr, 2012 at 10:43:44pm
Mate had a similar problem with cheapo bulbs, his headlights did all sorts of funny shit, told him it's got to be the bulbs after some head scratching, and I was right. On 26th Jan, 2012 Tom Fenton said:
8th Apr, 2012 at 02:41:47am
Just for future reference - many new cars will need the BCM reprogramming (dealer only) after a bulb change to make it work! For those of us in the trade - it keeps food on our table but a bit of a bugger for Joe Public! On 5th Sep, 2011 Vegard said:
8th Apr, 2012 at 07:16:50am
Lucky for me i dont have automatic lights Drives
should have popped over i would have sorted 2 hella units for you and saved £20
made sure of it when i got it lol, my mums clio does though, she had to get the fault sorted at renault as the renault specalist couldnt do it
