| Home > General Chat > Mot question foglight | |||||||
![]() 673 Posts Member #: 1395 Post Whore chepstow |
31st May, 2012 at 10:03:41am
Recently bought a gtm coupe just going through the electrics now and got most things working. I am right in thinking I need to have a warning light for the foglights when they are on and needs to glow orange? Thanks |
31st May, 2012 at 10:33:57am
also is horn ok to be a button mounted on the dash?
31st May, 2012 at 11:10:17am
Yes on both counts. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
31st May, 2012 at 11:45:33am
Doesnt need to glow orange but does need the warning light Yes i moved to the darkside |
31st May, 2012 at 11:46:03am
red one be ok? |
31st May, 2012 at 03:12:02pm
Yes fine, the standard 1 on my estate is red 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
15th Jul, 2012 at 06:55:50pm
Any question. Can I put reverse lights on a switch instead of the sensor on the gearchange? I can't seem to work out where it will work |
15th Jul, 2012 at 07:09:19pm
Yep, as long as it's labelled i think. Or just leave it altogether, reverse lights aren't tested. On 26th Jan, 2012 Tom Fenton said:
15th Jul, 2012 at 08:30:51pm
On 15th Jul, 2012 Carlzilla said:
lights aren't tested. never knew that !! Yes i moved to the darkside |
15th Jul, 2012 at 08:42:57pm
It's why I never bothered putting one on when i went to the mk2/3 lights or whatever they are. But replaced my foglight as it was previously my right reverse light. On 26th Jan, 2012 Tom Fenton said:
15th Jul, 2012 at 08:52:20pm
While it may not be a testable item, I'm sure you can't have a white light to the rear unless reversing, therefore the plod may have something to say if you forgot to switch it off? |
15th Jul, 2012 at 09:48:52pm
thats where my fog light is going when i can be arsed to solder a wire there ( its taken 6 months already lmao)
15th Jul, 2012 at 09:58:47pm
16th Jul, 2012 at 09:25:39am
So its not a case of if its fitted it needs to work, that is good news. Thanks for everyone's input |
388 Posts Member #: 442 Senior Member Manchester |
17th Jul, 2012 at 06:34:56pm
Indeed reverse is not tested. All other lights are unless non are fitted. In which case they cant be tested. |
17th Jul, 2012 at 06:52:52pm
If your reversing light is not automatically switched on by selecting reverse, then you must have a tell tale fitted. Only a problem if you get a really picky copper, but it isn't hard to use an illuminated switch anyway.
17th Jul, 2012 at 07:21:33pm
what year is it that you need a fog light? My build thread..
17th Jul, 2012 at 07:24:37pm
First used after 1st April 1980.
18th Jul, 2012 at 09:49:39am
Finally got the reverse lights sorted properly so no need to worry |
