Home > General Chat > spark plug gaps?
jameswildcooper
Member #: 1355
Leicester
what gap do you guys go to on NGK BPR 7ES plugs?
im also running megajolt too.
ive got 35 thou in my head but just wanted to double check?
jameswildcooper
Member #: 1355
Leicester
ooops just realised i posted this in wrong area :)
pinkyandnobrain
Member #: 2588
Pretoria South Africa
35 thou is a start, but try a search, there are a bunch of threads on this topic.
I had to go down to 20 thou on mine but I'm running and coil and dizzy set-up.
"Try to take over the world!"
kelvg
Member #: 3277
whetstone, leicester
Mine are 0.6 mm gap mate only know as just brought them.
05bwardl
Member #: 9991
lichfield ,staffordshire
usualy 25 thou as a start point
Craigie-B
Member #: 9468
Wootton Bassett
how do you know if they dont have the right gap
feeler gauges
jameswildcooper
Member #: 1355
Leicester
come on craig you should know this :)
Johnny
Member #: 6926
Accrington
ive always set mine to 0.8mm??
turbominivanman
Member #: 1504
Westbury, Wiltshire
Yep.
Me too.
0.8mm with a MJ or MS setup but I did use 0.6mm when on dizzy before going to MS. This is on an 8.3 CR and 99/100 RON Shell V-Power, up to 12 psi.
Rich.
evolotion
Member #: 83
Glasgow, Scotland
start with .8mm if you start to notice a misfire around peak torque and you know its not fuelling, close up the gap .1mm at a time and see if it improves.
as it stands i run .6mm but it didnt like the lean burn mixtures i used to run at cruise and part throttle when i had a .8mm gap. but had to go down to .6mm to alleviate misfires around peak torque.
Denis O'Brien.
Craigie-B
Member #: 9468
Wootton Bassett
Yeah I know thats how you measure the gap but i wanted to know how the engien acted if the gap was too big or small etc
On 12th Jun, 2012 apbellamy said:
feeler gauges
Thanks Mate :)
