| Home > Technical Chat > Power difference between 8-1/9-1 at same boost. | |||||||
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
28th Jun, 2012 at 09:23:46am
Just wondering what the power difference would be at same 10psi of boost with increasing the cr from
Edited by alaskanow0 on 28th Jun, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
28th Jun, 2012 at 09:33:55am
(BHP/8)*9 ? must be good enough for a ball park figure
Edited by Brett on 28th Jun, 2012. Yes i moved to the darkside |
28th Jun, 2012 at 09:54:45am
Theoretical Otto cycle gives:
Edited by Paul S on 28th Jun, 2012. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
28th Jun, 2012 at 09:59:17am
thats alot less than i expected tbh Yes i moved to the darkside |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
28th Jun, 2012 at 10:31:30am
head..........hurt............************** |
28th Jun, 2012 at 11:00:53am
You like maths???
28th Jun, 2012 at 11:32:37am
That may as well be written in Chinese for all I can make out of it. It's all just random letters on a page to me lol. On 26th Jan, 2012 Tom Fenton said:
28th Jun, 2012 at 11:35:46am
Reminds me of when we studied the Otto cycle in primary school.... :S Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
28th Jun, 2012 at 12:07:31pm
ot·ter (tr)
28th Jun, 2012 at 12:42:34pm
You see the heading above?
28th Jun, 2012 at 12:47:33pm
Tough crowd Audi s4 b5 - 470bhp & 486ft lbs
28th Jun, 2012 at 01:39:20pm
Thanks Paul, Class C 3rd Place Avon 2011 14.18 @101mph |
28th Jun, 2012 at 02:18:12pm
Interesting, that is for an NA engine, I wonder how it holds true with boost.
28th Jun, 2012 at 02:33:29pm
Like most things relating to turbo-charging, there is an optimum compression ratio for maximum power and it may not be as high as you can get away with. However, for driveability, it certainly is.
28th Jun, 2012 at 02:36:18pm
Impossible to have this discussion without a mention of the SAAB variable compression engine. High compression for off boost torque/driveability. Lower compression for less ignition timing compromise when on boost.
28th Jun, 2012 at 02:49:16pm
Went to the Indian for a takeaway and the bloke asked me if i'd like to try a chicken tarka. "Tarka?" i asked. whats that. "It's like chicken tikka only a little otter"...........I'll get my coat. |
28th Jun, 2012 at 04:07:16pm
At that then in short! You could gain a minimum! 4% power at 1 atmosphere
28th Jun, 2012 at 04:26:41pm
I'm on 8.6:1 and on 10psi my engine makes considerably less power than Wintersurfers on 9:1.
In the 13's at last!.. Just |
28th Jun, 2012 at 04:56:16pm
On 28th Jun, 2012 theoneeyedlizard said:
I'm on 8.6:1 and on 10psi my engine makes considerably less power than Wintersurfers on 9:1. They share the same cam, same basic engine arrangement. The only real difference is CR and side mount turbo. Thats partly what made me ask. Am just trying to understand what route to take for my injected 7 Port project. I would like the optiimium for power and drivability, looking at 20psi from GT2056 Class C 3rd Place Avon 2011 14.18 @101mph |
28th Jun, 2012 at 06:03:13pm
From what I understand of all the information Paul has written, there is more power to be had from correctly designed manifolds (inlet and exhaust) than from a small compression ratio change.
28th Jun, 2012 at 07:08:03pm
I'm on 8.6:1 and on 10psi my engine makes considerably less power than Wintersurfers on 9:1. They share the same cam, same basic engine arrangement. The only real difference is CR and side mount turbo. problem with this is your not comparing apples to apples, on your engines i imagine theres way more to it than the static compression ratio difference, but for talking sake, lets take 2 engines, 1. 8:1 CR 10psi 2. 9:1 CR 10psi 3. 8:1 CR 13psi 1. effective CR of 13.44 2. effective CR of 15.12:1 3. effective CR of 15.07:1 now this is a massive massive generalisation ignoring lots of variables, but when it comes to compression ratio case 2 and 3 are comparable, and will probably make similar power, albeit the lower CR engine will have less manners and economy. turbo 16v k-series 11.9@118.9 :)
28th Jun, 2012 at 07:55:48pm
That makes sense. Class C 3rd Place Avon 2011 14.18 @101mph |
28th Jun, 2012 at 08:09:06pm
yep, I agree with this,
I'm on 8.6:1 and on 10psi my engine makes considerably less power than Wintersurfers on 9:1. They share the same cam, same basic engine arrangement. The only real difference is CR and side mount turbo. problem with this is your not comparing apples to apples, on your engines i imagine theres way more to it than the static compression ratio difference, but for talking sake, lets take 2 engines, 1. 8:1 CR 10psi 2. 9:1 CR 10psi 3. 8:1 CR 13psi 1. effective CR of 13.44 2. effective CR of 15.12:1 3. effective CR of 15.07:1 now this is a massive massive generalisation ignoring lots of variables, but when it comes to compression ratio case 2 and 3 are comparable, and will probably make similar power, albeit the lower CR engine will have less manners and economy. On 28th Aug, 2011 Kean said:
28th Jun, 2012 at 08:16:00pm
I am very tempted.
28th Jun, 2012 at 08:17:29pm
...and you need to get stuff sorted so you can run this alleged 28psi!
