| Home > Help Needed / General Tech Chat > Clutch removal | |||||||
313 Posts Member #: 9367 Senior Member Derby |
14th Jan, 2013 at 08:10:58pm
Have been trying to get my clutch and flywheel off for a couple of days with no success. Left it over night and also heated it. I have undone the flywheel bolts from the clutch and the flywheel is apart from the clutch but the clutch won't come off the crank taper. Any ideas?
14th Jan, 2013 at 08:32:01pm
Keyway out? And make sure the pully is square to the fly 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
14th Jan, 2013 at 08:37:59pm
Oh yeah the keyway is out and the flywheel puller is up as tight as it will go. Got no more thread on bolt. I'm pretty sure it's square on it looks it. |
14th Jan, 2013 at 08:40:19pm
I always found the trick was in the hitting of the hammer, finding the flywheels resonance. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Jan, 2013 at 08:45:59pm
I've been twatting it all night and most of yesterday. It's an ultralight verto and trying not to damage it too much but doesn't seem to move. Hit it on end of flywheel puller with a 14lb sledge a few times yesterday and on the back a lot tonight but just with a normal hammer. |
14th Jan, 2013 at 09:09:16pm
Running out of thread does not sound right
14th Jan, 2013 at 09:14:11pm
Have you got the insert in the end of the crank for the puller to act on? You shouldn't have run out of threads, particulary if this is in place |
14th Jan, 2013 at 09:19:40pm
I don't think I do actually. Will have to look for that! I have my bolt into a big domed nut with just a thick flat washer in there at the moment. I'll have a look tomorrow for the insert and try that! |
14th Jan, 2013 at 09:19:42pm
Double post Edited by bakker110 on 14th Jan, 2013. |
14th Jan, 2013 at 09:21:14pm
and hit the bolt on the puller not the flywheel. |
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
14th Jan, 2013 at 09:34:37pm
I had this problem until Mike came around with his big hammer. Class C 3rd Place Avon 2011 14.18 @101mph |
14th Jan, 2013 at 09:36:49pm
Where did he hit it? You're only up the road in Mansfield!? I'm in denby near derby.
On 14th Jan, 2013 alaskanow0 said:
I had this problem until Mike came around with his big hammer. |
336 Posts Member #: 9941 Senior Member Derby |
14th Jan, 2013 at 10:13:39pm
Guys it's seriously well on I hav been holding one side of the engine while andy has had his big bar on it and as he said we have been giving it some serious hammer! |
14th Jan, 2013 at 10:15:48pm
Sounds like you need a bigger hammer! On 7th Oct, 2010 5haneJ said:
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
14th Jan, 2013 at 10:34:26pm
Have you tried an impact driver on the puller bolt, the type you put your wheel nuts on with, works for me best method I have used with out a doubt.. Alan Main Build
14th Jan, 2013 at 10:55:41pm
14lb sledge hammer was used on flywheel puller bolt |
14th Jan, 2013 at 11:09:43pm
Its the repeated shock action that makes the impact driver work, some times the big hammer just does a bouncing action, just a thought if you have got one to try what you got to lose.. Alan Main Build
15th Jan, 2013 at 07:58:48am
have you taken the torch to it yet??
15th Jan, 2013 at 11:07:55am
I can come take a butchers tomoz night? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Jan, 2013 at 02:44:59pm
be prepared for a fooked crank i think
Yes i moved to the darkside |
![]() 684 Posts Member #: 9590 Post Whore Derby |
15th Jan, 2013 at 03:37:19pm
i can come over again tomorrow or maybe ill take it to mine and get the oxy - acetelyene on it Matt W
On 14th Mar, 2012 mw3 said:
Got a nice big delivery from Carl at Force Racing today. |
15th Jan, 2013 at 03:53:55pm
I'll have one more look tonight then if I can't shift it Mike would you mind calling in? Where are you? It was a brand new MED ultralight setup last summer and they did say they cleaned up the taper anyway at the time. |
15th Jan, 2013 at 05:31:31pm
Actually I've just realised tomorrow is no good. I'll try it again now and let you know how it goes. |
15th Jan, 2013 at 05:57:46pm
Well I found the insert to the end of the crank. Thought it was going well had loads of thread left and then it sheared the head off the bolt.
15th Jan, 2013 at 06:12:04pm
Oxyacetylene! Bring out the big guns! |
