Home > General Chat > Latest rolling road results from MW and myself.
T3Tone
Member #: 252
Sunny suffolk
Well i was very pleased with 181bhp running 15psi, the plan was to run 16psi but could not bleed off any more air with my simple little bleed valve set-up but still very pleased.
And as for Matt!! well big big congratulations to him. As a few comparisons a new standard bmw cooper s was 177bhp, spot on according to bmw's figures. And a 1275 injection mini with rc40 and K & N made 66bhp. Matts then produced 284.5bhp on his second run due to slipping the clutch (for the first time) on the first.
Well done again mate.
-MINI CLUBMAN 1380 TURBO-
*surprised* Surely thats a typo!!
Whilst Im no longer a fan of bleed valves.....
Try rstricting the feed line into the bleed valve from the compressor.
The valve then has less air to deal with. This may allow you to up the boost a bit.
It may also make it a little more sensitive to adjustments though. Takes a bit of experimenting.
RR figures are often only useful in the pub.....
Some read high, some read low, some may even read close to true...not very often though.
Well I think that slipping a double-grey diaphram is a world first - and is enough proof in the proverbial pudding of the torque output...
I assume this was some RR shootout day then?
yeah but 284..... with a slipping clutch, thats a bit high isn't it!
very impressed well done matt!
I assume that was with gas too?? What size jets are you running matt?
T3Tone
Member #: 252
Sunny suffolk
Yes dave it was a mixture of bmw and classics at t & m colchester. Always get very acurate/genuine figures from these rollers, every standard car we know that goes on there gets very close to there surposed output.
mini 13, clutch did not slip on second run.
Thanks for advise steve, although as i only have a 6.5psi actuator i may get a 10psi one and the bleed off from there.
bloody hell!!
I knew he'd got 240 odd before with gas, but that really is a big jump!! well done Matt!
and of course wll done T3Tone, very impressive.
Edited by Joe C on 2nd Oct, 2006.
181 @ 15 psi, well done! what ever your doing, your doing it right!!
Carl
Member #: 95
liverpool-on-sea
well done guys. but 284.5 bananas holy crap!!
JT
Member #: 637
Hertfordshire
now i bet that is a bit of a handfull, both of them for that matter!!
what torque did you get out of them both?
My build thread..
Thats crazy!! Thats pretty much 3 times the standard output!
Congratulations mate. :)
Ric
Member #: 36
Basingstoke
That's pretty crazy...
Awesome. *happy* I need another go in that car!
Holy crap! Now, try getting that into the ground :)
The rollers were on the different setting for my run thats why it read that much.
Edited by Miniwilliams on 3rd Oct, 2006.
torque figures if possible chaps
please clarifie matt
can't mate that rolling road doesn't do them. I guess i could work it out with the 5250 maths calc.
chuffing nora!! good work guys
matt, how much gas is that using
same as last time jim i haven't changed the amount.
mini300bhp
Member #: 653
Cambs
Not far off 300 there dude..............
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
your rollers only measure torque and then calculate BHP....
but they obviously dont tell you those figures which is a shame!
and Mini300bhp LOL your right!
Alex
AlexF
turbo hogster
Member #: 178
stowmaket suffolk
well done mate pity i couldnt make it as i was been cooked to 300 deg c in a flash over back draught trainer.
those figs are normally spot on its about the only one i know of what gives true figs.
i told you tone to tweek it up hopefully now you will listen tone lol
