| Home > General Chat > moving engine mounts | |||||||
4th Oct, 2006 at 10:22:44pm
Had a play at mocking up the front rad (a late metro) tonight, and it seems theres just no way its gonna fit, even the old style inertia starter is on the verge of fouling the back of the grill
4th Oct, 2006 at 10:40:45pm
There should be enough room with the old style inertia starter? Ive managed to get enough room with the new style starter and just re-drilling the starter mounts to rotate it so the solenoid is at the top. There should be a fair few inches between the grill and the starter!
Edited by matty on 4th Oct, 2006. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
4th Oct, 2006 at 11:36:54pm
which rad? Mk1 or Mk2.
Edited by Sprocket on 4th Oct, 2006. On 26th Oct, 2004 TurboDave16v said:
4th Oct, 2006 at 11:43:03pm
mine pissed in with a flip front dude, loads of room spare, even with a dizzy in there and my injection subframe. I've got the thinner metro rad with hoses at either end rather than on one side. Edited by Nick on 4th Oct, 2006. On 20th Oct, 2015 Tom Fenton said:
4th Oct, 2006 at 11:50:35pm
its the thinner mk2 rad goddammit! the more i think about it the more pissed off i get LOL
5th Oct, 2006 at 12:31:43am
pretty sure you've already seen these but pics usually help.
164 Posts Member #: 1271 Advanced Member Berkshire |
5th Oct, 2006 at 01:05:55am
wheres the oil cooler gone in the 2nd pic?! |
5th Oct, 2006 at 08:07:01am
the 2nd one is an older pic from when i didnt have the oil cooler....you can just see the stock mutro one over to the right hand side. On 20th Oct, 2015 Tom Fenton said:
5th Oct, 2006 at 08:35:32am
ihave the thick metro mk 1 rad in mine , i trimmed the front valance a bit , it sits on top of the subframe , i trimmed the fins back for the starter sol to clear ,and moved the stock alternator upwards about 5 inches ill find a pic .robert. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
5th Oct, 2006 at 04:39:22pm
could you fit the metro mk2 type in a non flip 'round nose' front end along with a 2wd cossie intercooler do you think?
My build thread..
5th Oct, 2006 at 05:00:06pm
This is a good example of that setup, although you have to move the grill forward to do it.
Edited by matty on 5th Oct, 2006. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
5th Oct, 2006 at 05:17:11pm
i take it its well worth the effort to fit in the metro rad as its bigger and gets alot of the cool air coming in through the grill.
My build thread..
5th Oct, 2006 at 05:41:27pm
All of these need work, in that you can kiss your bonnet lock goodbye. Which is fine if your mini is a track car or never goes on the road I guess?
5th Oct, 2006 at 06:00:47pm
easy fix for that Dave, just use a small padlock through one of the bonnet pins On 26th Oct, 2004 TurboDave16v said:
5th Oct, 2006 at 06:31:16pm
I use small padlocks just in case but i dont really leave the mini anywhere as it is a secound car! |
5th Oct, 2006 at 07:50:28pm
On 5th of Oct at 05:41pm TurboDave said:
..... or never goes on the road I guess? bit like mine then...LOL "Turbo's make torque, and torque makes fun"
5th Oct, 2006 at 10:34:48pm
On 5th of Oct at 12:31am bud666 said:
pretty sure you've already seen these but pics usually help. thats the hole it lived in
then an old pic of it first fitted ![]() Just realised where I've seen thnat engine before, it was parked in the middle of a field at Bristol Mini days. Isambard Kingdom Brunel said:
6th Oct, 2006 at 12:51:04am
yup that'd have been me, i was on the massive MF stand, all 3 of us...lol On 20th Oct, 2015 Tom Fenton said:
15th Mar, 2007 at 08:46:15pm
On 4th of Oct, 2006 at 11:36pm Mini Sprocket said:
which rad? Mk1 or Mk2. The Mk2 rads are thinner and you can, if your real gentle, massage a curve into it
You need to remove the top and bottom rails though. If rover on post 92 cars can get away with moving the engine 10mm forward from the original position. I dont see there being any detrimental effect in moving it 10mm backwards. This is my plan for the 16v, but i'll be moving it 20mm as i have a post 92 frame. What you will need is a shorter engine steady and to re drill the rod change mounts in the tunnel. I know its an old post, just wondered if anyone actually managed to move there mounts with any success? Need to find 45mm at the front somewhere, as things are getting a teeny bit.....not gonna fit, at the moment! lol https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
15th Mar, 2007 at 09:30:25pm
well funny this should be brought up, as i resolved this last weekend, im pretty much stuck with a side rad now for 2 reasons.
16th Mar, 2007 at 06:02:02pm
Joey ... where did you get that front from. Just so I know not to get it because I have to have a bit of space on mine for the plenum / IC / front rad for the K head conversion. Every day is a school day ...........
16th Mar, 2007 at 06:11:20pm
Its one from SMB composites, although the reason its 'tight' is probably due to me shaving a little too much off when i bonded the a-panels on (this was before they were available with a panels).
16th Mar, 2007 at 06:22:55pm
Using a clubman front is cheating!!!!! LOL Every day is a school day ...........
16th Mar, 2007 at 06:58:13pm
No Roger.. Cutting the front off is cheating.
16th Mar, 2007 at 07:09:29pm
On 16th of Mar, 2007 at 06:22pm RogerM said:
Using a clubman front is cheating!!!!! LOL ahem, im fitting a clubby front. but only coz mines a clubby.lol no longer a series, but still 1.3 turbo.
