| Home > General Chat > alloy fuel tanks, any of you using them at all??? | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
16th Jan, 2007 at 06:52:12pm
16th Jan, 2007 at 09:54:31pm
yup, mines a brise one, about 5 gallon capacity i'd say.
16th Jan, 2007 at 10:42:54pm
here is a photo of mine, which is forsale if you want to make me an offer.
16th Jan, 2007 at 11:47:02pm
hmmm, could be interested there jimster, if you PM how many gallons it holds & what your after i may head down to grab that from you, looks about what i'm after '1st refusal if possible jim' i'm in the market for one now Edited by clubminiflip on 17th Jan, 2007. SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
17th Jan, 2007 at 12:31:06am
same please jim :) |
17th Jan, 2007 at 12:47:13pm
& if anyone has an alloy tank even if its in a race/motorsport car post a link to a pic or pop a lil pic up, its just so i can work out the best mounting method, as i'm going to run a bracebar from arch to arch, & plumb in my fuel pump, filter & fuel lines ready for....... SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
17th Jan, 2007 at 01:38:53pm
the one i have bolts to the rear firewall
17th Jan, 2007 at 02:28:33pm
ok clubminiflip was the first to show an interest, followed by gav, and stig.
17th Jan, 2007 at 03:02:55pm
Are the fittings push on jim? I assume endaf can make me one with -6 screw on fittings. Ah i posted this site a while back, they look ok www.nor-mal.com Edited by t3gav on 17th Jan, 2007. |
17th Jan, 2007 at 03:24:48pm
yea my connections are push on, he can make anything you likem, put the screw on connections are not cheap. Around £25 each for male and female, so thats £75 added to your tank!
17th Jan, 2007 at 06:45:27pm
Edited by slater on 17th Jan, 2007. |
17th Jan, 2007 at 06:51:50pm
Slater, Just as a point of interest, The fuel pressure regulator operates more accuratley when it is mounted close to the carb.
Edited by danboy on 17th Jan, 2007. |
17th Jan, 2007 at 07:02:11pm
This tank was fitted central in the boot, It's 4 gallon capacity. I cant show it fitted as I now have a flat boot floor and it fixes to the rear bulkhead and the wheel well floor
17th Jan, 2007 at 11:21:26pm
Still using my 5 litre one........F1 style pit stop every garage + the lead/octain additive
![]() 568 Posts Member #: 1200 Post Whore Bristol |
19th Jan, 2007 at 07:20:24pm
where did you get yours from slater? Ive seen similar advertised in demon tweeks but smaller for 250quid! |
397 Posts Member #: 694 Senior Member Shropshire |
19th Jan, 2007 at 09:16:55pm
On 17th of Jan, 2007 at 06:51pm danboy said:
Slater, Just as a point of interest, The fuel pressure regulator operates more accuratley when it is mounted close to the carb. Regards Dave Dan I think you are confusing the fuel filter with the fuel presure regulator on slaters pic |
19th Jan, 2007 at 09:22:38pm
That's a regulator with built in fuel filter. Hey Jimster I like your swaybar! On 7th Nov, 2008 Nic said:
19th Jan, 2007 at 09:31:02pm
What you replacing yours with jim? |
19th Jan, 2007 at 09:58:39pm
On 19th of Jan, 2007 at 07:20pm pickmeup said:
where did you get yours from slater? Ive seen similar advertised in demon tweeks but smaller for 250quid! Made it. Its a well simple design. 1 internal baffle about 2" off the base with a 1" hole in the middle. The pickup pipe goes down the centre of the tank through the baffle from the top. That must make mine worth £300+ then
(Pressure reg works fine where it is. So long as you set the pressure at the carb and not at the reg then you will take into account any pressure drop along the line.) Edited by slater on 19th Jan, 2007. |
19th Jan, 2007 at 10:14:41pm
Not quite right Slater,
20th Jan, 2007 at 09:19:49am
As I run fuel injection now, I want to make one with a built in swirl pot.
20th Jan, 2007 at 06:37:00pm
heya jimster, i've gotta pass up on the tank, i've just had to get a full set of spax shocks for my mini, two of mine failed on the MOT so decided i'd change the lot to be on the safe side, n its tax time too!
20th Jan, 2007 at 08:21:55pm
Why doyou need a bracebar anyway?
21st Jan, 2007 at 10:46:44am
i'm going to be using it as a bit of re-inforcement to the subframe mounts on the bootfloor, i have a bar that go's from arch to arch & & once thats in i have two smaller bars that will link to the triangulated part thats the stiffener to the mounts, i proboly dont expalin that to well in txt, i'll do pics once its in, i feel supporting any part of the car that has something mounted to it is worthwhile SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
21st Jan, 2007 at 11:39:36am
it's not a brace bar, it's an antiroll , if you look you can see the drop links going through the floor to the radius arms. Team www.sheepspeed.com Racing
