Home > Help Needed / General Tech Chat > Which rollcage ??
Arge
Member #: 290
Basingstoke, Hampshire
hi,
I am after a rollcage for my mini project and have no idea what to buy and who to buy from !??
The plan is it will be a 1293 turbo with around 130hp. I am asking early on in the project (Before shell has been painted) as i am unsure wether i will need a bolt in or weld in cage.
It will be a fast road car so driven fairly hard and also it may have the rail/shelf that goes across the center of the bulkhead removed due to fitment of a curley EVO 2 asad dashboard.
I am thinking sumthing along the lines of a 6-point cage with a brace across the bulkhead, any such thing ??
So what are your suggestions people ?
Thanks
Arge
Will my project ever be finished !!? hopefully you guys can help !
Its only been like 10 years in the making and I'm only just assembling my engine!
A 6 point bolt-in cage with an additional dash bar is what you want then.
Safety Devices or The Roll Centre are your best bet.
Even with a bolt-in cage you will need to weld in some spreader plates onto the floor and arches; so make sure you do this before painting.
Wil
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I have a Safety Devices bolt in 6 point in my NA 1380.
For my turbo build I will be using a Roll Centre weld in "miglia spec" cage (£315 for the cage, £35 for the footer rails (mounts pedal box and steering column if using something like the dash you describe) and £20 for post ... all plus VAT.)
You do have to notch a few points yourself but that is to ensure a good fit.
I'll let you make your own mind up...
AL
Member #: 1347
Croydon (South London)
ive got a rollcentre cage, twin door bars etc etc. Its good quality but ive heard they have pretty poor customer service.
do you really have to chop the dash bar out for the asad 2?
Arge
Member #: 290
Just had a look on the safety devices web site and cant find a 6-point bolt in cage for a mini !!
I know they do cages for minis, anyone know where to buy them !??
Arge
RogerM
Member #: 1217
Min-Its was where mine came from but that was a while ago... not sure if they still do SD cages
YES Safety Devices 3mm seamless
welded is the best
but ........... a dash bar they do not do
and in my book this is most important ! *wink*
especially for the road
iam going to fabricate one myself in addition to the saftey divice cage i already have
as two peeps i know have got killed head on!
and the engine came into the cab and took them out badly .... *frown*
I got my dash bar mady by The Roll Centre. I gave them the distance between the uprights and the OD of the tube.
From that they made me a lovely bar with sliight bends at the ends to match the angle of the uprights.
It didn't cost too mych £50 iirc, and their service was great.
Wil
t3gav
Member #: 229
Gavin@minispares.com
kent
Ah i forgot to say in my old post i phoned fabricage and they do do a bolt in cage, cross diag and harness bar and a couple of extras for 480+VAT unpainted, pretty good i thought
JT
Member #: 637
Hertfordshire
has anyone got pics of what they have to give ideas on what you get from what companys?
cheers
josh
My build thread..
AL
Member #: 1347
At the weekend i can built my cage in the garden and post pics if you want as the cars a shell at the mo.
Arge
Member #: 290
yeh some pictures of various cages would be nice, help me decide what it is im after exactly !
Edited by Arge on 20th Feb, 2007.
Carl
Member #: 95
liverpool-on-sea
id get a bolt in one personally. if you write the shell off theres a chance, ok maybe a small chance, of reusing the cage. but if you use a weld in cage then its in for good.
My SD one was tight onto the roof skin whereas my RC one was superb and much nicer. the quailty was spot on.
Arge
Member #: 290
Does anyone have any pictures of rollcages from the roll centre ??
Do you know if safety devices and the roll centre both do bolt in dash bars for their 6-point cages ?
That will swing it for me really as i really want to add some strength up front behind the dash.
cheers
we reused the cage out of this
that cage has probably seen the most action, of any cage fitted to a mini-ever
(hahahaha, just pulling your leg boys)
(not in an alexf stylee)
AL
Member #: 1347
check out the volv :cool:
that middle roof bar should be on the other way round by the way
Edited by AL on 21st Feb, 2007.
JT
Member #: 637
Hertfordshire
so would the harness bar be an add on?
i take it it fits ok with the diagonal bracinf there?
AL, what cage is that? looks good, was it alot of £££??
cheers
josh
My build thread..
danboy
Member #: 1381
Al, Tell me about your lotus
Regards
Dave
Edited by danboy on 21st Feb, 2007.
AL
Member #: 1347
To be honest im not sure how much it cost, my mate got it for me (think in the region of £350 new).
Josh. Its a rollcentre cage. The first time i put it in u hadnt cut out the rear pockets and it was a real bitch, my mate ended up losing half the skin off 1 hand. So i cut the things out and now it goes in nice and easy.
As for harness bars they would be extra, or you could put them in yourself, just use CDS steel of correct thickness.
danboy, those are some eagle eyes u got there lol. Im afraid its not my lotus, i went round to a mates to use his camera. Its his dads. He has 2 of them, both elan+2's that red one a purple one (i think it looks like a big dildo) and he has a tr4 in the garage thats hes had since he was 18. Those elans are quite cool tho, handle really nicely. Im not sure but the red one might be for sale in the near future.
you really do love volvos then! me too!!
AL
Member #: 1347
yeh volvs rule. To be honest that isnt mine im borrowing it for a year from my mate while he works abroad. Its a 240 glt (top spec 8-) ). Ill be gutted when i have to give that back. Then i guess its gonna be a 340 with 360 running gear and some form of turbo engine for some cheap drift fun.
My old man has the same in red, im currently bombing about in his old faded sky blue 240GL, what a hotrod! LOL
edit:
sorry about going so O/T!!!
Edited by joeybaby83 on 21st Feb, 2007.
