Home > Technical Chat > Flywheel Materials, FAO any material scientists out there.
Thinking a couple of years down the road, and looking at possibilities for a high revving engine (sorry but I'm keeping the spec quiet)........
I've been looking around at various flywheels and it would appear that there are three options; Titanium & EN8 Billet Steel & EN Forged Steel.
Ignoring weight and cost for a minute are there any issues with any of the materials in terms of strength, especially considering the forces going through a high reeving high power engine.
Basically what are the pros and cons of the different materials.
What about aluminium alloy? Fastcarl makes these I believe?
hum, although it's light I wouldn't have thought aluminium to be strong enough.
doesnt carl also do Ti ones?
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Rob,
the right grade of aluminium, treated properly, replacable crank interface taper and with a friction surface that can be replaced should be fine .... would probably be my choice ... I think FastCarl's flywheels fit each on of these criteria and more.
Rog
Edited by RogerM on 11th Jul, 2007.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
I agree wit Roger. There are loads of grades of alloys that can be stronger than steels.
Its just all stereotypical. Alloys are soft. Steels are hard, and minis rust......
the last one I agree with LOL
Fuckin ell guys . Steel is an alloy. In a discussion about materials and metalurgy, not wheels, could we please use the proper terms?
Aluminium alloy is soft, but steel alloy is not, is that what you're trying to say?
V, don't you mean an alloy of iron and carbon?!
miniminor63
Member #: 672
The oversills police
Oslo, Norway
V is 100% correct the way I see it...
stefaz
Member #: 1656
stoke-on-trent
thought an alloy was a non-chemically combined combination of metals - therefore since steel is a combination of carbon and iron it's a metal in its own right aint it?
Edited by stefaz on 12th Jul, 2007.
yep,
steel, no 56.5 on the periodic table.
Lets see how the Devious Bastards machine gets on then as that's got an alloy flywheel.....
I've got an alloy flywheel myself. Works like a charm :)
miniminor63
Member #: 672
Oslo, Norway
That is the alloy of the ultralight steel flywheel from minispares is it not V.?:)
you meen it keeps the evil spirits away,
Alluminium alloy Tom!!
All I said was alloy, I did not say what type, if you decide to assume I meant aluminium alloy then that is up to you!!!!!!!
LOL!
on reflection, you are in a way correct,
bastard!!!!.lol.
Jordan
Member #: 1392
This was a stereotypical quote.
Ok, so why would anyone want to go for a titanium flywheel when an aluminium alloy one is as light, more than up to the job and a fair bit cheaper?
no idea mate, !!!,
RogerM
Member #: 1217
pub bragging rights ...... a ti flywheel is worth about 200% extra bananas on chav land due to the fact that you could then use the engine upto 1,000,000 rpm.
if thats the case , [which i suspect it is] i expect to have all my beer bought for me in the bar on sat night because if got two of the feckers in my car,
my spare car, which tom is keeping warm for me only has a crumby alloy one, pah!!.
carl
carl
RogerM
Member #: 1217
varl, do you have the "ring gear" as an integral part of the ti flywheels? Not sure if you could treat the ti to make the teeth lasted (in a limited eace car sense) when used with a pre engauge starter?
I think you made those numbers up, can you please show your calculations?
OK, so I think it's reasonable to say there is effectively no difference (other than cost) between Aluminium alloy and TI as far as high preformance mini fly wheels are concerned.
The next question is; is there any pros or cons of steal* (both forged & billet) over alloy** again I'm thinking about the centrifugal forces on the flywheel and the energy in the fly as well as the weight & cost of the materials.
Rob
* = EN8
** = Aluminium Alloy
Are
