Home > Help Needed / General Tech Chat > M.E.D £4000 none runner
Zeemax Power
Member #: 393
Oulton Park
Depressed is the word lads its getting more and more likely its in the engine. I dont really no now! Fuel and spark. Has anyone had or no of probs with the dizzy drive could itbe jumping or something. Doesnt seem smooth turning of jerky.
someone said to me theres no problem only solutions lol.
I only seem to have problems and heart break.
http://www.Zeemax.com
clearly this guys in desparation
is anyone avalable to go and sort it for a brew and a natte if not i will donn the Zimmer frame and go sort it
Edited by BENROSS on 20th Jul, 2007.
philc
Member #: 1346
bromsgrove
does it turn ok without the plugs in??
Best thing to do mate is step back and think logically and positively! Dont rush and just go back to basics.
What i try to do is think about the progress ive already made!
Keep your chin up pal youll get there!
hows fars oulton park from us steve?
Edited by MikeRace on 20th Jul, 2007.
Nick
Member #: 154
Midlands
oulton parks in chester, i'm up there racing next month but i'm only there one day and i'll be busy with the car all day. i'll have a look see what time our races are and what time we'll be finished, if its early enough i might be able to pop round but i've gotta shoot off to a mates pretty sharpish for a session before MITP.
dev
Member #: 1158
Manchester
Where abouts are you, i can pop over for a looksie maybe sunday.
After that i cant till 24th august
TurboDave said
"Fab's right of course.
Maybe you should take your styling ideas off the French instead! "
Zeemax Power
Member #: 393
Oulton Park
Thanks lads really good of you. Really think its something serious in the engine just seems dead.
Departion in a big way. If someone could tell me with the problem i'd be over the moon but i dont think staight forward. I'll see any right to help me out. going to see can get the AA out to it again but i aint holding my breath wish me luck
What sort of flywheel do you have on?
Does the engine turn over smooth?? Check your earth straps!
AV-R Technologies
Member #: 345
Guildford Surrey
You'll sort it out buddy. Give us some more details. Write an essay if you have to. So does it turn over nice and smooth with the plugs out? If so then could be an ignition problem. If not then there is obviously some mechanical restriction.
Let us know
http://www.avonbar.com
Carl
Member #: 95
liverpool-on-sea
is the engine still in your car ready to be started?
did med build up the block and time the cam etc?
have you got fuel?
have you got good feed and return pipes?
have you got a good charged up bateery?
have you got a good working dizzy?
is the carb good?
have you got a shelter/ garage to work in?
can you brew up?
if you can answer yes to ALL the above then i can spare you saturday afternoon ( thats the only spare time ive got) to come and take a look, youll have to refund me fuel money tho lol
sent you me number if you want me to come phone me asap
Nick
Member #: 154
Midlands
haha, the brew is the most important part!
On 20th of Jul, 2007 at 12:44pm Carl said:
can you brew up?
I assume you mean tea? lol.
philc
Member #: 1346
bromsgrove
what dissy is it?
could it be up side down?
have you got fuel?
is the carb good?
can you brew up?
now theres an offer you cant refuse *smiley*
Zeemax Power
Member #: 393
Oulton Park
Engines in the car.
MED built me a short motor and i put gearbox and flywheel and all.
got fuel
Good feed and it returns
battery where i have a problem doesnt seem to be turning the car over i've had jump leads on it and the engine seems to jam.
I think the engines knacked depressed all day ended up watching the golf lol.
Whats happened oil cooler pipe has got a hole and the engines lost all its oil, and its finished its self i think.
Dizzy good had it checked
brand spanker the carb
Markey tent
brew up as much as you can drink! Live on a farm, so milks on tap and, we have own well water.
Anyone willing to help i'll be there whenever, but dont want to waste your time mate if i've finish the engine.
cheers
has the engine run at all?
has it ran at all with no oil, or have you just been trying to turn it over with no oil in it?
the golden rule when trying to run an engine is get oil pressure first, did you achieve this?
Carl
Member #: 95
liverpool-on-sea
ok do not dispare.
sounds like it could be a bit of a waste me coming up this weekend then.
what you need to do is do a few checks before somebody comes to help i think.
1. remove all the spark plugs and see if the engine turns over freely/ smoothley. if it turns ok then it should be startable.
2. is the flywheel the same type as the starter motor?
3. is starter motor good?
4. fix the hole in the oil cooler pipe, infact just bypass it if its easier for now.
5. get a good battery on there.
6. is engine earth good.
im sure people can add to the list.
do/check these then report your findings. check and recheck everthing over the next week. then ill come up next sat morning if you like and have a look. i did say tomorro afternoon but it seems it could be a wasted journey at the mo and ive got stuff to be doing.
evolotion
Member #: 83
Glasgow, Scotland
turn the engien over by hand, hows it feel!?
Denis O'Brien.
philc
Member #: 1346
bromsgrove
is the battery cable earthing anywere, does it have a split somewhere and touching the body
Zeemax Power
Member #: 393
Oulton Park
Had the engine running twice never seemed to bring any oil to the rockers though. I dont know when it lost the oil. But the flywheel came loss fix that run again then stoped and i haven't had it running again.
Yesterday found a pool oil under the car and checked the dip stick no oil.
Engine seems to turn over ok with out the plugs!
Starter is the same not sure how good it is it turns the engine with no plugs.
yep i'll fix the pipe
i'll buy a new battery this week
engines earthed well
i'll check battery cable aswell
thank you very muches
it needs someone to go have a look at this and sort it
philc
Member #: 1346
bromsgrove
never been a fan of MED *angry* hope you sort it, keep us informed
Mabie It could be worth backfeeding some oil into the pump. Just to make sure its primed proporly, to prevent damage if there really is no oil pressure when trying to get running. At least that issue may then be resolved.
Edited by minimole23 on 21st Jul, 2007.
Prime the pump, turn the engine over without the plugs in untill you get oil pressure, I remember doing this with Wes's engine, it took a good 30 seconds if not longer to get oil pressure for the first time!
TBH jump leads won't always get enough power to the battery, this has caught me out before!
Another thing to check is the sump plug, that could give a good indication if something has been grinding together due to the lack of oil.
Edited by matty on 21st Jul, 2007.
Zeemax Power
Member #: 393
Oulton Park
i've been moving cars today get it in my markey to work on. Thanx for the advice everyone i'll check it all and have one last go. It just got to me abit down the other day well you can emagine spending all that money.
