Home > Help Needed / General Tech Chat > Still having trouble bleeding brakes!
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
I recently bought a tandem master cylinder (yellow band type) from ebay, which I rebuilt with new seals and secondary piston etc.
I have bled the master cylinder on the car and then proceeded to bleed each wheel.
I wasnt sure on the order to bleed them as was unsure on the type of system I have, front to rear split or diagonal split dual circuit system. The car is 1990 and was told that it would be front to rear so bled the passanger rear to drivers side rear, then passenger front followed by drivers front.
We did that a few times but only the drivers side rear locks up. The others lock up after the pedal is pumped several times.
I replaced the passenger side rear cylinder as thought it was leaking but that didnt have an effect either!
I know its most likely air in the system somewhere but we've bled it all endlessly with no luck!! I just wanted to make sure I was bleeding in the right order?
Please help me obi-wan youre my only hope*smiley*
Rich
Carl
Member #: 95
liverpool-on-sea
try doing the rears first then the fronts.
richminiturbo.
Member #: 719
Thats the way I have been doing it mate!
p/r - d/r - p/f - d/f is the way ive been doing it?! Clear bubble-less fluid flowing freely out of each wheel :s
Rich
Scruffy
Member #: 328
Seaford Rise, South Australia
Clamp off each flexi hose in turn to see if the pedal improves. Have you fitted new linings at all to rear and are they adjusted properly?
I suspect the master cylinder is your problem - they rarely like being rebuilt ( sometimes you can be lucky !)
On 5th Sep, 2011 Vegard said:
Dangerous
Member #: 417
Don't you have to take the pressure differential switch out to bleed that type
NEVER bother rebuilding master cylinders. Buy new ones, every time.
richminiturbo.
Member #: 719
New linings? Do you mean brake shoes? If so nope I havnt! They have plenty of meat left on them and are in working order as they lock up after the pedal is pumped a few times!
I think thats on the slightly older versions of the tandem type, which have a electrical terminal on the side! With the yellow band type i think its all in the cap which is of course removed for bleeding anyway!
I get a really good flow out of the master cylinder when i bled it? I assume its working ok as I get the same, clear bubble-less fluid out of each wheel!
A while back I made a thread about the servo system I was trying to bleed and no matter how much I bled it I wasnt getting any braking force (but again when the pedal was pumped the wheels where locking!) I then decided I wanted to ditch the servo anyway so got the normal master cylinder which im talking about here!
So unless the servo and a freshly rebuilt master cylinder where both fooked it has to be something else surely?!
The only other thing I can think of is the pressure reducing valve, which I assume is working ok too as im getting a strong supply of fluid front to back anyway!
Tis really pissing me off now! Any ideas guys? I would so appreciate is as im out of them and just want to get it sorted of course!
Thanks, Rich
Dangerous
Member #: 417
Have you got the right size rear cylinders .500"/.625"/.750" to suit the front.
Are you sure the one that is locking hasn't got contaminated linings(had it before.lining kept rolling into balls instead of dust)
and have you got the rear brakes connected to the bottom of the master(incase it has a larger piston((can't remember))
Edited by Dangerous on 19th Aug, 2007.
richminiturbo.
Member #: 719
Didnt realise you could get different sized rear cylinders! What effect would it have if they werent the right ones for the calipers? The rear cylinder i replaced was a new (spare) one I had fitted to my previous mini and have converted the calipers over from that car to this car so in theory should all be ok as that combo worked fine before!
I have also checked the shoes on each side if theyve been contaminated and absorbed any fluid but they are fine aswell!
EDIT: The top union on the master cylinder goes to the left hand side of the pressure regulating valve and the bottom to the right hand side, thats right yeah?
Rich
Edited by richminiturbo. on 19th Aug, 2007.
Scruffy
Member #: 328
If you have a servo as well you need to pressure bleed the system either using an ezi bleed or with the engine running to eliminate problems with either the Mcyl or servo. Don't kid yourself it cannot be those components we all make mistakes ( i spent two days trying to work out why my spare engine would not start having convinced myself everything was fine - the timing disc was not where I thought I had aligned it as i copied where it was on the other engine to find what I thought on the other engine was tdc was just a white mark of paint).
All problems are usually simple ones - if the rear brakes are correctly adjusted and the shoes (linings) not contaminated a spongy pedal that pumps up either has air in it you say there are no bubbles in the fluid - so either you are mistaken and there is or the master cylinder/and or servo are f*cked. If the system has a loose union drawing in air it should leak as well making it fairly obvious.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Trust me, I've not gone mad .... try this.
Pump the pedal a few times, and get somebody to hold it down for you whilst you crack each nipple then immediately tighten them again.
Work round the car in order. Basically what this is doing is telling you that each of the bleed nipples is operational and sealling as it should.
Now check that there is no weeps around the seals on both slaves and calipers.
Find something to hold down the pedal, put it in place, loosen the cap and forget about the car over night ..... I find a few beers helps with this!!!!
Pressure bleeding can help but personally the only thing I have ever been able to do successfully with an Eazi Bleed is remove paint!!!! LOL
What this does is open the whole system and the air will find it's way out given time.
If you still ahve problems replace the pressure balance valve with two lengths of pipe and try again. If that works replace the valve.
If not I'll have to go away and think a bit more.
Scruffy
Member #: 328
Roger is right but I seem to remember now what happens with a remote servo - air gets trapped in one of the link pipes and unless you pressure bleed it with an ezi bleed or have the engine running even his method might not work - it is a right b*stard from memory.
Turbo Shed
Member #: 30
Epsom, Surrey
i agree with the chocking of the pedal over night. i spent all day once bleeding the brakes with no luck and no air coming out. chocked the pedal down hard over night and had a perfect pedal the next day.
stefaz
Member #: 1656
stoke-on-trent
scruffy he doesnt have the servo in this car - he has converted to non servo afaik so chock the pedal rich and see how it goes
Turbo Shed
Member #: 30
Epsom, Surrey
chocking the pedal works on all types of brakes and the clutch.
1380turbo
Member #: 1211
Working up the BHP ladder.
Rich, are you still using the sh*t brake equalizer valve bolted to the bulkhead?
They can be an absolute nightmare!
and also are you trying to lock the brakes with the wheels off the ground or driving?
Are you using new DOT4 brake fluid?
Old brake fluid will absorb air and water (i think) and will never give a firm pedal.
richminiturbo.
Member #: 719
Pumped the pedal until it felt harder last night and wedged a jack bar onto the pedal and seat after taking the cap off of course!
The brakes have been locked up all day, im still leaving the bar a little longer will test the brakes a bit later on!
If what youre thinking of is what im thinking of the yeppers i still have it on there, basically a cylinder with the unions from the master cyl going inot the top and the pipes to the front/rear systems out of the bottom yeah? Could there be an airlock in this little tyke then?
And yep im trying to lock the wheels while the car is off the ground, havnt tried it on the deck yet as didnt think it would make a difference seeing as the pedal goes to the floor?
Im using DOT4 I bought a week or two ago! Should be alright still?
Thanks so much for the replies guys! Keep em coming lol
Rich
richminiturbo.
Member #: 719
Leaving it with the pedal depressed hasnt helpled!! Theres been no leeks while its been under pressure either! hmmm
Scruffy
Member #: 328
If you haven't got a servo the only other thing is do you have a non std pipe work around the master cylinder that goes up at all even slightly - if not and you have tried to pressure bleed the master cylinder is f**ked new seals or not
richminiturbo.
Member #: 719
Nah i dont have a servo scruffy, i converted from a servo to the yellow band type master cylinder!
I got two pipes made up at my local motor factors and they arent leaking at the unions or anything, what do you mean by going up slightly?
The thing that makes me think its not the master cylinder is that i was having the exact same problem when trying to bleed the system with a servo, i thought it might be the master cyl on the servo so ditched it and got the yellow band type one, only to discover im having the same bleeding trouble!!
The brake compensator couldnt be to blame could it? Im getting fluid to either end of the car obviously and so that indicates its not blocked or anythingm could there be an air lock inside of this?
Rich
Turbo Shed
Member #: 30
Epsom, Surrey
the other day i change front and rear pads on a car and had no pedal! are the rears adjusted right up tight? have you fitted new pads?
richminiturbo.
Member #: 719
Yep I have fitted new pads! And have checked that the adjustment is right on the rear drums!
What problems could changing the pads cause?
Rich
Can you confirm that you have adjusted the rear brakes so that they bind ever so slightly?
Edited by Paul S on 21st Aug, 2007.
Turbo Shed
Member #: 30
Epsom, Surrey
new pads sit on the old worn disc but not quite square. when you lift your foot off the pedal the pad springs back pushing the fluid back to the master cylinder.
if you have bled the system and dont get any air, and you have chocked the pedal then it may not be air.
wind up the rear adjusters up tight then back off so you can only just turn the wheels by hand. then drive the car (on private road) and use the brakes to bed them in
then check the difference in pedal feel.
dont drive to much as the heat produced by binding brakes can reck discs and also produce brake fade.
