Home > General Chat > kad brake bias kit
afrter weighing up the prices of different bespoke brake setup, ive been thinking about getting one of these as an early xmas present to myself
anyone using this?
as they have a range of differing front/rear bias, will the std rear drum cylinders be ok for this? or do i need different ones?
running alloy 4 pots up front (if it matters)
alos do they include and fittings? what threads will the master cylinders be so I can get some banjos
Joe
Master cylinders usually either M10x1 or 3/8UNF, both sizes common TBH.
mini93
Member #: 2017
Warwick.
iv got one on mine...there adjustable by an on dash twist thingy, as it turns it pulls a screww across changing where the bar pivots
i might have a little problem with mine, but then it might be unrelated feels like i have to pull brake pedal up somtimes but when i dont it doesnt effect anything
David.
Scruffy
Member #: 328
Seaford Rise, South Australia
A lot depends on weight of car _ I had to fit different size rear cylinders and a bias device to stop the rear from locking up.
I was using biggest cylinder available at time on rear 3/4 but i believ you can get 1" now which would have cured issue without bias lever as well.
On 5th Sep, 2011 Vegard said:
it will be fairly lightweight, its a rally car so fully stripped, glass front end, carbon bootfloor/lid etc. has full cage and extinguishers though, so prob put back as much as that takes away, maybe more.
can kad supply whatever master cylinders you request? or do they supply 'x' and its down to you experiment?
danboy
Member #: 1381
scruffy, surley you needed a smaller diameter rear cylyinder?
Brake line pressure x piston area = force at piton face.
less piston area gives less force
regards
dave
miniminor63
Member #: 672
The oversills police
Oslo, Norway
He is talking about the master cylinder. For the same pedal force a larger cylinder will make less pressure to the circuit. force/piston area = pressure. same force, and he wants less pressure, so area has to be larger
danboy
Member #: 1381
miniminor, I read it as rear cylinders (plural), you are exactly right if he did mean the master cylinder.
Regards
Dave
Edited by danboy on 25th Nov, 2007.
yep, was on about master cylinders, do you specify what sizes you want when you order?
regarding the rear drum cylinders though, could these not be tweaked/downsized to limit the rear bite?
Just spoke to Colin and ordered it
V. nice chap, he has posted this reply to my questions on the Kad forum:
Hi Joe,
For 4 pots and drums we supply 5/8" front and 13/16" rear which works out quite well.
13/16" is the largest size of integral reservoir master cylinder available.
Should you need to go bigger at the rear, i.e. for less rear brake effort on a lightweight competition car with less weight at the rear for brake adhesion, then the larger 7/8 and 1" master cylinders would need to have remote reservoirs with the attendant problems of mounting these high enough to gravity feed the master cylinders.
Bias via the balance bar is the fine tuning, coarse adjustment should be made with master cylinder size. It is worth also remembering that smaller rear wheel cylinder sizes will reduce rear brake effort.
The in car adjuster is availabel as an extra as the regulations in some formulas do not allow in car adjustment. The part number is 1012282 for this.
The 5/8 front cylinder has a 3/8 UNF thread so that is pretty standard, the 13/16 has an odd size and we supply an adaptor for this.
Since you ask so nicely I will get one or two put up on Ebay at a favourable price!
Arrived today, will fit it at weekend, which means all thats left is the wiring, been putting it off forever...
Slightly surprised at the bill, I honestly thought the master cylinders were included in the price, and it doesnt say anything on the website, so there was an extra £100 that i hadnt budgeted for :(
dn89mini
Member #: 1506
Cheshire
Hi mate, Did you get the chance to fit this? I have one that I have lost the instructions for :) and if you could post any close up pics and tips I would appreciate it. I cant seem to get the bar balanced, in fact I am not sure if it is even supposed to be. I just emailled KAD but anything you can show would be great. Thanks
Edited by dn89mini on 3rd Dec, 2007.
Check out the (slow) progress at.......
http://www.turbominis.co.uk/dn89mini
will whack some pics up asap
dn89mini
Member #: 1506
Cheshire
Great, thanks
I just waiting for an oddly sized 7/16" UNF banjo from merlin to rig up the rear m/c then its all sussed.
Oh arse, just remembered that i forgot to take a pic of the instructions for you, will do next time i go down.
Joe
Joe
Snigger...
Your only jelous nic
Rick
Boom boom LOL!
dn89mini
Member #: 1506
Cheshire
Excellent thanks!
When you press the pedal do the pushrods on the cylinders move equally when you have it set like that or does the front seem to move more than the rear. I cocked about with my setup without really thinking and am trying to get it back to the initial settings. Your pics help a lot. Thanks again
I havnt got that far myself yet, but hopefully when I post a pic of the destructions all will become clear
mini93
Member #: 2017
Warwick.
do you have the adjustable twist screw thing that mounts on the dash?
also i found today i had a problem with my bias box, the lever was binding my clutch master cylinder holding the brakes on, do you have alot of clearence with the plastic cylinder?
David.
yeah, got the on dash adjuster, havent messed with it yet, but it looks like its got enough room for quite a bit of adjustment, if its fouling when fully adjusted, try swapping the master cylinders form side to side so the balance bar protrudes out the other way?
Apologies about the wibble pics, my sister stole the scanner when she moved to London:
I dont envy you, reading that makes me feel weel pissed.
Edited by joeybaby83 on 4th Dec, 2007.
dn89mini
Member #: 1506
Cheshire
Thats great thanks.
For reference, the thread on the girling 13/16" m/c with integral reservoirs is 7/16" with 24tpi
