| Home > General Chat > Matt, I found the problem: Clutch Issues | |||||||
4th Feb, 2008 at 08:31:20pm
So last night Matt (MiniWilliams) came round and I took him for a blast in the mini. I'd changed the clutch on the Saturday and all was well. But then it started slipping again.
4th Feb, 2008 at 08:34:11pm
one idea here wil i have a good back plate for you vertro if you wish
4th Feb, 2008 at 08:37:46pm
On 4th Feb, 2008 wil_h said:
So last night Matt (MiniWilliams) came round and I took him for a blast in the mini. I'd changed the clutch on the Saturday and all was well. But then it started slipping again. I wasn't happy that I had fitted the oil seal properly and a few drops of oil made me fear the worst. Anyway, I've taken the clutch out and it's not contaminated, although the seal was leaking and I'll try again with a new one. The problem is that it's a verto clutch and I've put in the later, larger, plate thinking it'd be better. However, because the flywheel has worn over the years the new plate is only contacting the unused part of the flywheel (maybe 2mm) rather than the whole surface. Ideally it needs resurfacing I guess, which is a pain. Anyone have any ideas? bring it to me and i'll face it off ffor you. eassy peasy lemon fooking squeezy. |
4th Feb, 2008 at 08:48:22pm
I might take you up on that offer carl. When's good for you?
4th Feb, 2008 at 08:50:33pm
I might take you up on that offer carl. When's good for you? It's only the flywheel, Steve, I got a new backplate and spring in the Kit almost anytime, do it while your here, |
4th Feb, 2008 at 09:02:34pm
Fcuk me carl your feeling generous
Site Admin 6303 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
4th Feb, 2008 at 09:03:25pm
can't say fairer than that! |
4th Feb, 2008 at 09:27:57pm
generous is my middle name .
4th Feb, 2008 at 09:47:59pm
ive got a better idea wil and thats fit on preverto set up with a grep diaphram, bingo lighter set up which actualy works unlike the verto set up
4th Feb, 2008 at 09:56:31pm
Good stuff mate glad you found the problem, i did enjoy our little spin the other night, it was nice to got out in a turbo mini again! around the stunning roads you have near you.
Edited by Miniwilliams on 4th Feb, 2008. Best 1/4 mile 13.2 seconds @116 mph
4th Feb, 2008 at 10:01:24pm
So Matt, you drove up the M1 past my house and couldn't be arsed to drop in,
4th Feb, 2008 at 10:10:56pm
I would have loved to have poped in mate but i didn't no your addy :(
4th Feb, 2008 at 10:44:26pm
take carls offer up mat you know he is tight......LOL
5th Feb, 2008 at 09:46:02am
On 4th Feb, 2008 turbo hogster said:
ive got a better idea wil and thats fit on preverto set up with a grep diaphram, bingo lighter set up which actualy works unlike the verto set up just a thought mate The thing is, the standard 70,000 mile clutch lasted 2000 more miles with the extra turbo power. What I have now is a better verto set-up that is more than capable considering the relitevely low power I have (less than 90 bananas). I'm also not overly bothered about the minor improvements that a lighter flywheel might offer, and I also don't want to wear the thrusts as this car does 8 to 10k miles a year. And, having recently moved to Yorkshire I've become a tightarse! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
5th Feb, 2008 at 01:23:56pm
Don't bother taking it off, just lift the engine out on your own by disconnecting all the engione to trans bolts, then lift out the gearbox, then re-assemble, then re-fit the flywheel, and with it sat on the floor, start it up, then using a file through the starter hole simply machine it flat yourself. Easy!
5th Feb, 2008 at 03:55:26pm
I thought you were supposed to use an angle grinder when doing this 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
5th Feb, 2008 at 04:27:56pm
After a few attempts your stamina and skeletal strength with be such that you can carry an engine for 40 miles. With a busted knee! On 7th Nov, 2008 Nic said:
5th Feb, 2008 at 04:45:44pm
!!!!!HAHAHAHAHAHAHAHA!!!!!!!!
In the 13's at last!.. Just |
5th Feb, 2008 at 05:27:48pm
did someone mention fiesta brakes? "Turbo's make torque, and torque makes fun"
10th Feb, 2008 at 02:05:11pm
Update.
10th Feb, 2008 at 06:23:22pm
bugger Wil! that was a good idea anyway!
10th Feb, 2008 at 06:37:09pm
Well Will wev'e learned something there,
Edited by fastcarl on 10th Feb, 2008. |
10th Feb, 2008 at 07:03:19pm
1mm was too much, the fingers were pretty much flat. But as I didn't know if it was too much I tried it anyway. It had basically just gone past clamping and into the release position.
10th Feb, 2008 at 07:12:39pm
righto, make a mental note of 0.5mm |
10th Feb, 2008 at 09:16:46pm
Cool mate glad you now sorted and you have both learned some thing Best 1/4 mile 13.2 seconds @116 mph
