| Home > Help Needed / General Tech Chat > Rock HARD Clutch | |||||||
19th Jun, 2008 at 10:13:28pm
Right then fellas, had a little set back today bled the clutch up and it wont budge!! At all! Ive even bust the seal on the slave pressing so hard. Ive tried putting a bar on and no joy
559 Posts Member #: 2775 Post Whore Aberdeen |
19th Jun, 2008 at 10:15:47pm
Dont want to sound cheeky. Is the clutch plate in the right way round? |
19th Jun, 2008 at 10:22:13pm
On 19th Jun, 2008 lockfast said:
Dont want to sound cheeky. Is the clutch plate in the right way round? got it in one
i will come over tomorrow evening mike and have a look see this is whats wrong
19th Jun, 2008 at 10:23:01pm
Stevey said that mate, i can wiggle the plate around tho?
19th Jun, 2008 at 10:24:32pm
yes pull it mike
20th Jun, 2008 at 07:38:33am
seized plunger in the wok, but then again your not that daft as to overlook that are you,
20th Jun, 2008 at 08:35:25am
When i remove the wok, i can tap it with a hammer and the plunger just drops out, Im currently awaiting the arrival of a clevis pin however so im using a 3/8 bolt as temporary (would this make a difference). Its deffo nothing to dith the hydraulics, as i cant move the release manually. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
20th Jun, 2008 at 10:52:16am
On 19th Jun, 2008 MikeRace said:
Stevey said that mate, i can wiggle the plate around tho? thats not right, you clutch plate should be clamped up and you should not be able to move it Team www.sheepspeed.com Racing
20th Jun, 2008 at 10:58:11am
Isn't there normally a spacer beneath the drive straps where they bolt to the flywheel on the U/L flywheels?
20th Jun, 2008 at 10:58:45am
This sounds like a clasic backwards clutch plate :) On 17th Feb, 2009 Rob H said:
20th Jun, 2008 at 11:10:15am
On 20th Jun, 2008 Tom Fenton said:
Isn't there normally a spacer beneath the drive straps where they bolt to the flywheel on the U/L flywheels? Yeah i've got these on mine! |
20th Jun, 2008 at 11:38:40am
Yes they are spaced equally with washers. And when the pressure plate is all bolted up the straps sit pretty level. When i take off the pressure plate i can move the clutch plate along the primary gear back and forth toward the engine and toward the flywheel are you supposed to be able to do this?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
20th Jun, 2008 at 12:58:43pm
What Plunger are you using Some dont have the hole in the centre if yous dose not it will look up agenst the niple on the flywheel bolt marked in red in the pic On 17th Feb, 2009 Rob H said:
20th Jun, 2008 at 01:17:39pm
the release bearing doesnt have a hole on the middle! Not that i can rememeber anyhoo. This maybe the problem. What does the nipple do exactly. i might just saw it off and try again. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
20th Jun, 2008 at 01:20:22pm
From what I rember the niple is there to centrlise the little shaft the relece bearing sits a kind of suport spigot all the new bolts you get from swifttune and Mini spares MED ect ect dont have them so I see no reason you couldnt cut it off
20th Jun, 2008 at 01:59:48pm
I know, ill chop it off tonight then! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
20th Jun, 2008 at 02:01:11pm
Ya you do that you go home ans chop your Niple Off :) On 17th Feb, 2009 Rob H said:
20th Jun, 2008 at 03:48:46pm
i had another think,
20th Jun, 2008 at 04:14:17pm
iam going over in the morning gents
20th Jun, 2008 at 05:05:36pm
No its a pre verto plunger and bearing, and yes carl i am a numpty. However i dont have this in the wrong way round. Edited by MikeRace on 20th Jun, 2008. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
21st Jun, 2008 at 06:57:17pm
well found the problem mike and i
21st Jun, 2008 at 07:05:48pm
Bummer!!
21st Jun, 2008 at 08:02:02pm
On 21st Jun, 2008 BENROSS said:
well found the problem mike and i it was the back plate, the lugs were machined off some 5 mm more than btm limit ....
the guy who mike bought it off said it was fine! ![]()
this could have never worked as the pressure plate was FULLY clamped on and no more scope to release to disengage the back plate. anyway mike has another and fast carl is machining 1.5mm of the lugs as i type, top man carl ![]() Ahem!!, not quite steve, , mike been over and the offending backplate has only had max 0.060" off so not the 0.200 as you suggest. anyway. i fettles up the replacement lightweight one he brought along, so he will use this, ive explained all the critical dims to Mike, and he is at this moment hopefully checking parts and doing a dummy build. the suspect backplate in my opinion has not had enough removed to cause the severe problems mike is describing, its a puzzler thats for sure, carl |
21st Jun, 2008 at 09:10:53pm
Firstly a massive thanks to Steve for coming over and going over the clutch with me and Carl for sorting out the backplate top fellas!
21st Jun, 2008 at 10:13:15pm
cover looks perfect, but whats that on the release bearing, is it some kind of washer, come to think of it ,it looks like a verto release, |
