Home > Help Needed / General Tech Chat > Compression Ratio
Did some calculations last night of the CR of the engine I am building.
It comes out at 7.5:1 which I am quite happy with.
But I just was wondering what the rest of you guys out there use?
So post up your CR's please!
minimark
Member #: 19
newcastle
8/1
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
somewhere between 8 and 8.5:1
www.afracing.com/cr.xls
Feel free to have a play!
Alex
AlexF
Phil. *smiley*
So what is off-boost performance like with a low c.r.? I am guessing quite slow.....but all the more fun when the turbo starts to work?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Yup...
Thats the trade off... its also harms your fuel econo, not that it should ever be a considereation with turbo minis *wink*
alex
AlexF
fuel ecomony schmonony........ *happy*
Good effort at a rhyme there Tom...
7.3:1.
Worth mentioning that the off boost power will be worse the wilder cam you have. When I had a Phase 2 fitted the engine could be off cam and off boost, with the KC500 it's only ever off boost.
Wil
clubman_dan
Member #: 142
Winchester
i'm guessing the way to combat the sluggishness off boost is to keep the revs high betweeen gears??
DAN
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
yes *happy*
AlexF
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
7:1
16V project underway
stuart gurr - vmaxscart
Member #: 350
Turboing minis since '89<br> Supercharging minis since '04
try to keep an area of 'squish' in the chamber ie,'D' shape chamber ,area of squish is then opposite spark plug pushing mixture towards it (and supressing detonation)- and dont make the volume between turbo and carb too big , ie,to bigger bore of intercooler pipes or too large an intercooler - lag is the time it takes to start moving and compress this volume into the engine 7.5 :1 will be good for just about anything power wise ,and its not how big the intercooler is its mainly how much air you can get through it as to how efficient it is .
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hello and welcome Stuart!
alex
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
7.7:1 does it for me running up to 25psi.
Member #: 350
cheers alex
don't forget i'm a junior member though!
I'll change that for you Stuart.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
change mine to somthing else too Jimster!
alex
AlexF
"Nappies" has two p's in it Jim ............. *wink*
Cheers Phil!
What to alex?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
dunno...
suggestions anyone?
alex
AlexF
"Fountain of knowledge" .................. ???? lol *wink*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
how about "The Teacher" *wink*
alex
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
i must admit the Gurr/Wiffin combo gave me the turbo bug.
Jon, been turbo'in minis before most of you had pubes!
Andymini
Member #: 438
London
I've noticed that Stuarts tag says 'where in nappies' , shouldn't that read 'were in nappies' ?
Andy
Yep ! *wink*
