Home > General Chat > OT - Reverseing roatational force.
Sam
Member #: 1686
Oxford
Hello folks,
I’m having a slight problem choosing two gears.
The purpose I have for them is to reverse rotation of a chain.
I need them to be able to spin at near on 7500 rpm and take 90 lb/f of torque.
If you guys have any suggestions when it would be a great help
Thanks
Sam.
OMG Robert that's a big one
Sam
Member #: 1686
Oxford
Oh and it must maintain a 1-1 ratio from input to output.
Sam
Member #: 1686
Oxford
Found a set of gears now, ive just got to work out the strongest pressure angle.
any gear engineers around?
Mr Joshua
Member #: 1954
Luton Bedfordshire
Aplication?
Own the day
Sam
Member #: 1686
Oxford
To take drive from an r1 engine and gear box and change the direction so it can be used with a modified mini differential for front wheel drive.
Probably a bit late now, but you could run the chain round the second sprocket in an 'S' configuration (same as a mountain bike rear mech. You'd also need a couple of idlers, one of which doubling up as some form of tensioner? *oh well*
how are you positioning the engine? back to front?
is this entirely necessary?
pm R1 manx on this forum, or even better visit his site
www.r1manx.com
Sam
Member #: 1686
Oxford
The engine will have the exhaust at the back and the carbs at the front.
Looking at it from the drivers side the output is pointing towards you, this spins counter clockwise. The wrong way to spin the differential.
i need the exhaust to be at the back because I can modify the bulkhead to fit a turbo but i don’t want to have to cut the front.
It is a clubby front mind but I need to put a radiator and inter cooler there.
Edited by Sam on 27th Oct, 2008.
turbo r1 eh?
personally i hate the complexity of the backward engine install, far too much stuff to go wrong, but if needs must...
have you thought about clutch issues with an turbo'd r1 engine?
there are quite a few r1 engined cars on the island, strikers, z cars, home brew conversions and the likes, the biggest issue they seem to have is the clutch capacity, ive not looked into it recently, but this time last year there was very little that could be done to help...
fingers crossed theres a solution now
good luck
joe
heres how pro0motive do it, but imo its horridly complex
http://www.pro-motive.co.uk/R1KitInfo.html
my mate has an r1 kit, its really simple looking to put together. he is also planning on turbo charging his at some point
How come no one goes for a busa engine? They have far more grunt, and have been turbo'd a fair bit in the past?
theres a hyabusa zcar over her, but im guessing its because r1's are just so plentiful, small and cheap?
r1 parts and engines as said above are alot cheeper and easyer to come by, alot of people in the states and japan have done r1 turbo's. the hyabusa can some with a turbo from the factory so i have been told as an optional extra
Could this thread have had a subject and first post to make it sound any more complicated?
Sam
Member #: 1686
Oxford
The hayabusa is a lot bigger then the r1 engine.
I am starting to think about mounting it the conventional way around and just routing the exhaust around the side.
Would mean only one tensioner and one chain to go wrong.
I’m just concerned about a turbo in such proximity to the front.
i guess id have to ask evolution about that.
id def reconsider doing it that way after seeing bens (r1manx) conversion come together
on a clubman youll piss it for room
Sam
Member #: 1686
Oxford
Yes ill have around 5 inches for room at the front.
However what I’m worried about is something so hot in such close proximity to what is effectively plastic with a bit of Kevlar in it.
Edited by Sam on 28th Oct, 2008.
the promotive kit on a clubby gives loads of room, you can get a t25 in there and a front mount rad and intercoooler with room to spare!
Sam
Member #: 1686
Oxford
yes but i dident want to go with a pro motive kit :)
what kit do you have?
Sam
Member #: 1686
Oxford
Im not, I’m doing the lot myself.
An engineering exercise.
Not because it will be cheaper, the amount of man hours into development ect negate that.
Mr Joshua
Member #: 1954
Luton Bedfordshire
edit:- Just had a thought that wont work
Edited by Mr Joshua on 29th Oct, 2008.
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
I Started a thread asking what to do for my next projecct and I had decided to do a front install of a Turbo charged Daytona 600 unit. Hope we can throw ideas back and forth and get two of these working
Rob p.
Own the day
