| Home > Help Needed / General Tech Chat > LSD for road use. Pistons, thanks | |||||||
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
1st Sep, 2004 at 04:21:46pm
Going to be running a Eaton M45 at 12PSI and expect to have traction troubles with a 3.2 FD. I have read that some of you turbo boys run LSD's on the road. I thought this was a bad idea driving wise but heavy steering doesn't bother me. I have my suspension totally set up and want to not get wheelspin as much on hard cornering/accelleration. It is my fun hack and not a serious car. I will be using a Salisbury as that is what I can get my hand on. What pre load do you run........Any takers? Also, for running massive power loads, is a SC or Semi SC crownwheel a good idea? I might consider running more boost but first things first. Bugger off, I'm getting there. |
155 Posts Member #: 246 Advanced Member Cumbria |
1st Sep, 2004 at 06:43:36pm
Is this a Vmax kit then ? |
1st Sep, 2004 at 07:43:36pm
NOS pistons? What are they???
969 Posts Member #: 47 Post Whore Not very sunny swanage |
1st Sep, 2004 at 08:30:19pm
nos - new old stock????
And on the 7th day........... God created turbochargers! |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
1st Sep, 2004 at 08:46:20pm
dave , you have first hand knowledge of the salibury.lol.
1st Sep, 2004 at 10:47:39pm
Jon advises a Quaife but uses a salisbury.
2nd Sep, 2004 at 06:17:44pm
I have got wind that the LC metros had 8:1 pistons and were after oversize pistons giving the same ratio. I expect that the oversized option was not just 9.4:1. I will find out about this.
2nd Sep, 2004 at 06:20:21pm
woah!!! not too sure about your piston theory. im pretty sure that the turbo pistons were of a lot higher quality than the lowerr range ones. whilst your theory is good, i think you may well be asking for trouble. im sure someone with a lot more knowledge of this sort of thing will post shortly. And on the 7th day........... God created turbochargers! |
2nd Sep, 2004 at 06:34:49pm
I heard that they are OK but they disintegrate spectacularly when detonated. I think they are OK if you make damn sure you don't get detonation. I am going to attempt not to. (Exhaust gas analyser for setup.........hopefully). I'm only going to run about 12 PSI.
2nd Sep, 2004 at 06:42:44pm
i dont think piston rings are available for original pistons any more not sure but something to find out about no longer a series, but still 1.3 turbo.
2nd Sep, 2004 at 09:03:56pm
Try Minispares for there mega pistons, tested and good. Same rings as Omegas so easily available. They did a turbo version to with an 11.?? dish.
3rd Sep, 2004 at 08:47:19am
On 02/09/2004 18:17:44 Hedgemonkey said:
IThe 3.2 will be for 10" wheels and so will be more lively. I can get a salisbury for £150 and so will go with that. The tallest ratio FD that will fit an LSD is 3.44:1. A cwp from anything approaching a 3.2:1 will be a smaller diameter than the diff you are trying to fit it too. If you really want that ratio you will need to change your drop gears to have a primary gear with less teeth than the input gear (this means Minispare straight cut drops with a ratio of 0.958:1) which will give you 3.29:1 with you 3.44. Don't be tempted to use the helical version of these as the teeth are very weak with this ratio (they are know as a economy gear so not designed for big power) On 5th Sep, 2011 Vegard said:
3rd Sep, 2004 at 07:53:26pm
unless you ring Carl Austin who will happilly machine a standard one down to fit.
3rd Sep, 2004 at 08:42:09pm
don't think a 3.2 will fit the LSD - a little too small... On 17th Nov, 2014 Tom Fenton said:
4th Sep, 2004 at 12:19:13am
5th Sep, 2004 at 07:59:21pm
On 03/09/2004 20:42:09 TurboDave said:
don't think a 3.2 will fit the LSD - a little too small... I broke a 3.444 - it fractured because the metal left wasn't enough so a 3.2 forget it!!! On 5th Sep, 2011 Vegard said:
5th Sep, 2004 at 09:24:53pm
Curious, according to a mate, when buggering about with BIG power figures, they favoured seriously low FD's. If I remember rightly, the huge mid range torque of 8 ports and blower engines caused some sort of failure. I am sure this was either the crownwheel or the diff housing. I will go and have a chat with this old mini racer bloke I know. He was saying that on his car the weber came right into the cabin and he would have flames shooting past him when it backfired. Also, one guy had a passenger door mounted radiator with a huge kenlowe inside. Forget ashtrays, this guy let go of his fag and it went through the fan :) This was mid 60's. Awesome bloke to talk to.
5th Sep, 2004 at 11:25:36pm
I have ran a 3.44 semi helical FD for years and with XX amount of power and XX amount of torque i have had no problems.
6th Sep, 2004 at 08:48:32pm
as above , never had any probs Everyone knows that instructions only have to be read if the thing doesn't work....
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
6th Sep, 2004 at 10:38:52pm
hi
7th Sep, 2004 at 10:42:27am
Ok, thanks for your inputs so far.
7th Sep, 2004 at 04:08:20pm
Seriosly, why are you bothering with stock pistons? The only stock piston i'd use is the turbo one... (12.5cc)
7th Sep, 2004 at 09:50:34pm
Dave, I expect that I will be getting it wrong a few times despite the best maths and advice!! I reckon a couple of meltdowns will be unavoidable. Being a feet first idiot often, I am gradually learning from my mistakes and will use a couple of donks to try ideas out on like modded valves, etc. I expect that I will be scrapping a few first. It would be idiotic to step into the unknown with an expensive gearbox, etc. I will find out the truth about pistons and proceed accordingly. On principle, I don't want to be melting anything expensive. The expensive ones are inevitable really as I imagine I am going to want 180hp once I get it going. Bugger off, I'm getting there. |
7th Sep, 2004 at 09:58:24pm
we`d all love 180 brake . Everyone knows that instructions only have to be read if the thing doesn't work....
7th Sep, 2004 at 11:12:08pm
You won't ever melt a piston if you do things right... The only time i melted a set was when my bleed valve fell off on a 1/4 run...
