| Home > General Chat > What drive shafts are you runing | ||||||||||||||||||||||
31st Oct, 2008 at 07:36:01pm
Ok people have done a searching and read a good deal of posts on the subject and there seems to be some indifference on the topic so I want to do some averaging on the subject to decide the best route for the racer.
On 17th Feb, 2009 Rob H said:
31st Oct, 2008 at 07:55:44pm
Hardy Spicer all the way On 26th Oct, 2004 TurboDave16v said:
31st Oct, 2008 at 08:00:26pm
I second that!!
31st Oct, 2008 at 08:18:01pm
I'm on pot joints with std shafts, never had a problem.....yet! Team www.sheepspeed.com Racing
31st Oct, 2008 at 08:32:20pm
Standard everything...probably the next thing to go wrong though! Lol https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 85 Posts Member #: 2234 Advanced Member Palm Beach Gardens, Florida |
31st Oct, 2008 at 08:58:33pm
my 67 S has been a racecar all its life. Raced in SCCA in Sedan classes until 1978. I bought it in 78 and ran it in C Sedan for a year, then in GT-4 until 1980. I retired and parked it for 20 years. The car is a then-state-of-the-art 60s racer, always ran with a Longman inclined-valve head on a 1293 with flattops with a Boffo 460 cam. Never dyno'ed, wild guess maybe 120hp. Have gone to MED's scatter cams since then, car pulls good from 4000 to 8000. The car/suspension is severely lowered. Its all Mk1 stuff, early BMC SC/CR box, no rod change which would allow an engine tilt; and without tilting the engine, the driveshafts have to be at a big angle. As part of the un-retirement and conversion to vintage racer, I replaced the HardySpicer u-joints, since then ran it only a few times in HSR vintage, maybe once every 2 years. Never broke a driveshaft or U-joint, but last time out (2006) broke the CV joint exiting the hairpin at Barbour Motorsports Park. |
31st Oct, 2008 at 09:51:11pm
Mike Brown Cow Racing snapped a standard driveshaft clean off at the large C clip on the outer CV joint, last year at Santa Pod/ Mini In The Park. he managed to get the car fixed after a visit to the auto jumble On 26th Oct, 2004 TurboDave16v said:
31st Oct, 2008 at 10:22:50pm
On 31st Oct, 2008 Sprocket said:
Hardy Spicer all the way . Makes it easier to take the engine out without fucking around with ball jointsYou can get the engine out without splitting balljoints Paul I seriously doubt it! |
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
31st Oct, 2008 at 10:47:18pm
I think maybe he means pot joints. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
1st Nov, 2008 at 07:15:47am
1st Nov, 2008 at 07:46:09am
We run standard drive shafts in the hillclimber. Over the years we have broken one pot joint and two dif output shafts. I would bet that as our car uses slicks and only sees tracks that the shafts see more loads then people here with more power (not everybody). I don't think I will consider anything else bearing in mind cost vs reliability. http://www.twin-turbo.co.uk
1st Nov, 2008 at 08:41:33am
I have seen JKD hardy spicer shafts twisted beyond use at the splines for the hardy spicer. I have also seen the same shafts snap, again at the outer CV end. Those rally Minis know how to break stuff :)
1st Nov, 2008 at 09:06:42am
I have hardy spicers on my Sprint but am thinking of changing to pot joints. Anyone know the weight difference?
1st Nov, 2008 at 09:35:18am
http://s24.photobucket.com/albums/c2/carl1...=Picture004.jpg
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
1st Nov, 2008 at 09:37:33am
oooh shiny On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
1st Nov, 2008 at 09:59:54am
On 1st Nov, 2008 Sprocket said:
As for removing the engine with Pot Joints. You are having to fuck around with eather the joints themselves, clean and regrease, or fuck around trying to seperate the shaft from the joint trying not to split the boot. With Hardy Spicer, 8 nuts and they are free I think you need some help with this one. I don't know what you have been doing all these years with pot joints, but it is no trouble at all and the grease never sees the light of day. Just knock the pot joint free from the dif and wiggle it out, easy. http://www.twin-turbo.co.uk
1st Nov, 2008 at 10:20:45am
O/T I know, but the splitting ball joints or not issue.....
1st Nov, 2008 at 11:26:49am
This is a timely discussion.
1st Nov, 2008 at 11:28:20am
you have to drop the oil with pot joints too, not hard i know.
1st Nov, 2008 at 02:42:48pm
On 1st Nov, 2008 mini13 said:
you have to drop the oil with pot joints too, not hard i know. Good point, but it is much easier to drain oil while the nngine is in the car than out. http://www.twin-turbo.co.uk
1st Nov, 2008 at 02:57:03pm
On 1st Nov, 2008 fastcarl said:
http://s24.photobucket.com/albums/c2/carl1964/?action=view¤t=Picture004.jpg Tadaaaaaa!!! How much do you charge for those then Carl? Paul I seriously doubt it! |
1st Nov, 2008 at 03:12:37pm
people talk about the need to have the drive shafts as level as possible. With modern CV joints, its bollox. Put it this way, how often with drive line be perfectly inline while the car is in use, never. The whole' keep the driveshafts level stems from the 60s when UJs and Hardy Spicers were in use. I always thought that the theory behind keeping the drive shafts level was to reduce torque steer. Isambard Kingdom Brunel said:
1st Nov, 2008 at 05:35:25pm
carl last time i saw your car it had thoes shiney shafts with hardy spicer couplings. still the same? Drives
1st Nov, 2008 at 05:38:17pm
oh anyone had pot joints (inners) that won't come through the subframe?
1st Nov, 2008 at 05:55:27pm
On 1st Nov, 2008 Paul R said:
carl last time i saw your car it had thoes shiney shafts with hardy spicer couplings. still the same? those shafts are solid TI, fooking too heavy for me , i'm making up two pairs or tubular for the twinnie, Paul, £380, a pair, carl |
