Home > Show Us Yours! > Yet another childish Guess my newest weight saving thread,
Right, fella's i know this is your favorite game next to w--nking, so the clues are, its 1660 mm long wieghs in at 2.9 kgs, it replaces the standard 5.8 kgs, now i'm being a little vague in the length discription, but the tape measure showed 1660mm from the start and i have measured in a straight line,not around something,
Tom fenton need not guess,lol
so away you go,
carl
Clutch arm?
Rick
no idea realy
On 21st Dec, 2008 cossierick said:
Clutch arm?
Rick
no idea realy
obviously,
Kean
Member #: 341
aka T2clubby
South Staffs
bloody long clutch arm!
Carl
Member #: 95
liverpool-on-sea
driveshaft?
i just went to look at me tape measure ill shut up now:$
Edited by Carl on 21st Dec, 2008.
Is it body work?
ie roof, sills, exhaust tunnel (you could chop that out and run a flat floor)
Fuel line the old one was 1/2" BSP cast iron.
Edited by Rob H on 21st Dec, 2008.
Why did i think that :(
I think the clue is its not somthing straight?
carbon roof?
You've had your lower intestine removed and replaced with samco.
Oli
Member #: 1910
Wilts
Got to be your cock? I've heard great things lol.
No idea.
Edited by Oli on 21st Dec, 2008.
miniboo
Member #: 2253
Las Vegas, Brit in the States
crossmember?
Must be the roof.
That's the only thing that long and that weight.
MarkGTT
Member #: 1194
Shropshire.
On 21st Dec, 2008 Paul S said:
Must be the roof.
im also guessing roof.
On 21st Dec, 2008 Rob H said:
roof
I said roof first come up with your own ideas
the sun lounger that i know you keep in the boot? (its just a picture of an engine and a tape player that everyone else can see.)
Ollie
Member #: 1380
stupid guess but something to do with the exhaust?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Exhaust pipe????
On 19th Jan, 2010 wil_h said:
Shaun87
Member #: 1277
Portsmouth
what car is it for?
On 21st Dec, 2008 milamber said:
Exhaust pipe????
think about his pipes....
surely the common one is right?
antman
Member #: 358
Snetterton, Norfolk
How about the steering rack?
Could be the pipes, the length works not sure about the weight, 1kg each to start with sounds a bit heavy to me.
You are all miles off...hee hee
naa, surely he would have said 6 of? like he did with the pinion nuts?
or maybe he is a tosser?
CF under tray?
gear linkage
Front splitter
Edited by Sprocket on 21st Dec, 2008.
