| Home > General Chat > Seemingly obvious stuff / tips that not everyone seems to know... | |||||||
5th Feb, 2009 at 06:43:02pm
Ok, so you've been working on minis for years - and you suddenly find something new out, tell someone, and they already knew about it and assumed everyone else in the world did, hence why they never told you....
5th Feb, 2009 at 07:01:30pm
I always use an old bearing shell to lock the flywheel has always worked well for me :) On 17th Feb, 2009 Rob H said:
5th Feb, 2009 at 07:03:06pm
4) When removing a steering wheel, do not take the boss nut or steering wheel retaining nut compleatly off or you may hurt your self with a steering wheel in the face.
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
5th Feb, 2009 at 07:04:17pm
Use WD40 when putting window rubbers in, instead of washing up liquid. This was you dont get bubbles when it rains! On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
5th Feb, 2009 at 07:06:28pm
On 5th Feb, 2009 Paul R said:
4) When removing a steering wheel, do not take the boss nut or steering wheel retaining nut compleatly off or you may hurt your self with a steering wheel in the face. 5) when re-fitting your engine. make sure your pot joints are in properly before driving down the road and loosing all of your oil on ollie's driveway... Loving those ones! 6) make sure you refit the sump plug before pouring 5 litres of very expensive oil straight through onto the garage floor.... On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
5th Feb, 2009 at 07:24:36pm
I once stuck a 3m dia "garden umbrella" in the engine bay, hanged a garage light in it and actually felt real cozy working outside in the rain internationally known as "big" swede |
5th Feb, 2009 at 07:35:11pm
On 5th Feb, 2009 mini_surfari said:
Use WD40 when putting window rubbers in, instead of washing up liquid. This was you dont get bubbles when it rains! never use washing up liquid or wd40 because they eat the rubber. just use water. |
5th Feb, 2009 at 07:46:11pm
Don't clamp you're wiring loom to the shell with a toight ratchet strap and a massivly too big fuse at the other end.... On 11th Feb, 2015 robert said:
5th Feb, 2009 at 07:52:57pm
On 5th Feb, 2009 apbellamy said:
Don't clamp you're wiring loom to the shell with a toight ratchet strap and a massivly too big fuse at the other end.... In English please....
5th Feb, 2009 at 07:58:43pm
Don't clamp you're wiring loom to the shell with a toight ratchet strap and a massivly too big fuse at the other end.... In English please.... 1) Always use the correct rated fuses. 2) Dont earth parts of your loom that aren't meant to be earthed. Both these will help avoid melted wiring loom and other electrical components (stalks, switches etc etc). On 11th Feb, 2015 robert said:
5th Feb, 2009 at 08:01:48pm
sure it was on here i read this one
Edited by evolotion on 5th Feb, 2009. turbo 16v k-series 11.9@118.9 :)
5th Feb, 2009 at 08:13:09pm
You can pull a 'pot jointed' mini engine out without splitting your hub ball joints, you just lift the engine 2" or so, push to the left, then pop and slide the opposited side pot out, and drop down, then push to the right and pop&drop the other pot joint, then lift the engine. Or split the ball joints (just the top ones) which will take less than 5 minutes with the right tools and will take about an hour less than removing all the ancilliaries necissary to push/pull/swing/lift/left/right (the engine) ...... Call me old fashioned if you want, but I do it the easy way (splitting the top ball joints). Schrödinger's cat - so which one am I ??? |
5th Feb, 2009 at 08:22:57pm
On 5th Feb, 2009 Rod S said:
Or split the ball joints (just the top ones) which will take less than 5 minutes with the right tools and will take about an hour less than removing all the ancilliaries necissary to push/pull/swing/lift/left/right (the engine) ...... Call me old fashioned if you want, but I do it the easy way (splitting the top ball joints). TBH i dont think you need to remove anything, ive only ever removed mini engines by not splitting ball joints and ive pulled engine out totally complete even with rad on im sure? no longer a series, but still 1.3 turbo.
5th Feb, 2009 at 08:32:53pm
Well, I'd like to see you do the "swing left" with the rad still on :)
5th Feb, 2009 at 08:33:57pm
I've got fed up of swinging the engine and split the ball joint now! On 15th Jul, 2009 fastcarl said:
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
5th Feb, 2009 at 08:58:27pm
good thread, i do often think of this when i am working on the car, unfortuanatly (sp) my memory is so poor that the only one i can think of is...
5th Feb, 2009 at 09:07:06pm
Fitting rear wheel cylinders- push the new cylinder into place, get a pair of mole grips, turn them round so the handle that is usually nearest you faces away from you. Clamp them onto the hub flange. If you do it right, clamping them on will force the wheel cylinder hard up against the backplate, leaving you with 2 hands to fit the clip.
5th Feb, 2009 at 09:19:16pm
or...
On 5th Feb, 2009 Tom Fenton said:
Fitting rear wheel cylinders- push the new cylinder into place, get a pair of mole grips, turn them round so the handle that is usually nearest you faces away from you. Clamp them onto the hub flange. If you do it right, clamping them on will force the wheel cylinder hard up against the backplate, leaving you with 2 hands to fit the clip. On 11th Feb, 2015 robert said:
5th Feb, 2009 at 09:24:25pm
I'm willing to bet that 99% of people have got mole grips though, and probably not many have one of those.
5th Feb, 2009 at 09:25:01pm
3) A Metro front RH engine steady wedges nicey into the starter hole and locks up the flywheel a treat.
5th Feb, 2009 at 09:42:05pm
Fitting rear wheel cylinders- push the new cylinder into place, get a pair of mole grips, turn them round so the handle that is usually nearest you faces away from you. Clamp them onto the hub flange. If you do it right, clamping them on will force the wheel cylinder hard up against the backplate, leaving you with 2 hands to fit the clip. thats a cracker!! theres a few gooduns here(tho its a bit dated) http://www.ime.org.uk/ turbo 16v k-series 11.9@118.9 :)
5th Feb, 2009 at 09:42:10pm
I'm willing to bet that 99% of people have got mole grips though, and probably not many have one of those. On 11th Feb, 2015 robert said:
5th Feb, 2009 at 09:43:56pm
as mentioned, slotting the bottom 2 wok holes as a top idea
203 Posts Member #: 479 Senior Member |
5th Feb, 2009 at 10:02:26pm
When removing the flywheel, loosen off the crank bolt but do not remove, do the bolt back up until there is only a few mm between the the flywheel and bolt, then use the puller, this will prevent the flywheel launching itself into your shins!
![]() 367 Posts Member #: 1643 Senior Member West London |
5th Feb, 2009 at 11:22:28pm
RUBBER GLOVES!
Lightweight racer coming soon. |
