Home > Show Us Yours! > my new car *UPDATED 18/1* pic added
clubman_dan
Member #: 142
Winchester
ok here it is, i've removed the front subframe and engine so its up on stands at the moment.
when was the car last on the road???
also if anyone wants to come round and tidy my garage please feel free!
DAN :)
Edited by clubman_dan on 18th Jan, 2005.
clubman_dan
Member #: 142
Winchester
heres the turbo as well
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
time to put it all togeteher then *happy*
are you going to do a step by step photo rebuild?
alex
AlexF
clubman_dan
Member #: 142
Winchester
yeah i think i'll photograph the build and post here, i'll update as and when i do things.
DAN :)
clubman_dan
Member #: 142
Winchester
update, i got a bit of welding done today, on a hole in the drivers floor started to cut off the passenger side a panel, there's a few more pics of the car as well.
DAN :)
i get my cheque from the uni next week so i can put some money in to the car. another update soon!
Edited by clubman_dan on 8th Oct, 2004.
T3Tone
Member #: 252
Sunny suffolk
Keep up the good work:)
-MINI CLUBMAN 1380 TURBO-
clubman_dan
Member #: 142
Winchester
did a bit more welding inside the car today, all that needs doing now bodywork wise is a panels, one sill the rear valence and one corner of the boot floor. i also ordered my mega squirt so ican do mapped ignition, like ben h, i also saw this exhaust, its a bit jon boy but what do you reckon??
DAN :)
clubman_dan
Member #: 142
Winchester
got some brakes today to replace the old drums.
should stop better with those :)
DAN
clubman_dan
Member #: 142
Winchester
quick update, i have now got my mega squirt ecu , so i'm on the way to mapped ignition heaven :)
i have also just ordered some 6x1o wellers so it should hopefully be off the stands and rolling again soon!
huray!!!
DAN :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
A pre built ECU or the parts?
alex
AlexF
clubman_dan
Member #: 142
Winchester
just the circuit board and the map sensor and chips, i need to go to maplins and get the resistors and that.
DAN :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
You ordered that from the guys who designed it out in America?
alex
AlexF
clubman_dan
Member #: 142
Winchester
yeah, it came over here well fast actually, i wasn't expecting it until nearly christmas :)
DAN :)
clubman_dan
Member #: 142
Winchester
i've just ordered, new barke and clutch master cylinders, brake lines and some new wheel cylinders for the rear brakes and i have also got my bias adjuster on the way.
i have also been stripping all of the paint out of the engine bay ready for some fresh paint, then i can put the front subframe back in get the wheels and brakes on and hopefully get it rolling and get the brakes working soon, then i can start welding.
DAN :)
evolotion
Member #: 83
Glasgow, Scotland
where did you get the bias adjuster! ?
the turnbo iv got 'ere could probably do with one ,currently has the space for one right next to the handbrake but just has an inline female - female conenctor in its place *surprised*
Denis O'Brien.
clubman_dan
Member #: 142
Winchester
i got mine from a shop on ebay,
http://search.ebay.co.uk/brake-bias_W0QQsojsZ1QQfromZR40
i went for the knob style adjuster because after doing a bit of research i found out you can get more fine adjustments from it than the lever,
DAN :)
clubman_dan
Member #: 142
Winchester
master cylinders etc arrived today and i am ordering some new panels in the next day or so so hopefully some real progress will be made, the only problem is now i'm at uni free time seems to get more and more difficult to find, but at least i get 4 weeks xmas holiday so i can get on with some work over xmas.
i will try and get some more pics up asap.
DAN :)
clubman_dan
Member #: 142
Winchester
here's a pic of my new brake gear
DAN :)
clubman_dan
Member #: 142
Winchester
i've also ordered some new panels to get some welding done weather permiting, i've also got some heacy duty tie rods coming and i am going to order some negative camber bottom arms so i can build the front subby back up, the engine bay is nearly paintless now so i can give it a lick of paint and start refitting the parts to the bay.
here's a couple more pics
DAN :)
*happy*
clubman_dan
Member #: 142
Winchester
*happy*
Zeemax Power
Member #: 393
Oulton Park
you loving the work cos there looks a lot
http://www.Zeemax.com
clubman_dan
Member #: 142
Winchester
just got a performance meter so i can check the effectiveness of engine mods, ignition map changes etc on the mini, i can also practice my 1/4 miles with the timer built in to it.
oh yeah and i can look flashy with it on the dash *laughing*
DAN :)
Zeemax Power
Member #: 393
Oulton Park
i bet its deer welding on them little bottles you want to get some pub gas
clubman_dan
Member #: 142
Winchester
havent done lots of welding really i dont do enough to bother with pub gas
