| Home > Help Needed / General Tech Chat > question for the gearbox gurus!! | |||||||
![]() 1128 Posts Member #: 142 Post Whore Winchester |
15th Oct, 2004 at 06:13:02pm
i amgoing to rebuild the 'box in my engine ready for the turbo conversion. its a standard 998 a series box, what stuff do i need to rebuild and are there any mods worth doing while its apart, all i canthink of is comp diff pin and central pick up pipe anything else??? |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
15th Oct, 2004 at 08:21:31pm
Minispares do a gearbox rebuild kit. Includes bearings, thrusts, shafts, baulk rings, etc, etc. It's pretty obvious, that's what I'm going for anyway. It's not cheap, but it is the way to go if you've got the cash to chuck around. (which I haven't-ish) Bugger off, I'm getting there. |
15th Oct, 2004 at 09:32:50pm
x-pin diff and a central pick up are worth it...
AlexF |
15th Oct, 2004 at 09:35:30pm
do you think you could explain the significance of the bearing to me? will the 998 one be able to with stand the punishment or should i shell out 350 for a rebuilt s/gt 1275 type box with 3.4 diff?
16th Oct, 2004 at 07:29:16am
The thing that always worries me about mini gearboxes is the resulting carnage if the gearbox DOES let go for any reason.......
Edited by Tom Fenton on 16th Oct, 2004.
16th Oct, 2004 at 04:57:05pm
A few points.
17th Oct, 2004 at 02:16:03am
just a quick question , as i was bout to post about this, is it possible to convert a turbo box, to use a non-turbo transfer case, as the transfer case i have here has a great many gubbed threads for the wok :S
Edited by evolotion on 17th Oct, 2004. turbo 16v k-series 11.9@118.9 :)
17th Oct, 2004 at 01:28:10pm
You can use whatever transfer case you want - but you need to make sure the ist motion nose bearing on the gearbox is right for the transfer case... On 17th Nov, 2014 Tom Fenton said:
17th Oct, 2004 at 03:47:38pm
yes...
AlexF |
18th Oct, 2004 at 06:29:30am
Crank seal is the same on 998 vs. 1275 engines. s/Gt box is great, it is a so called "close ratio" helical box, well at least closer ratio than normal box. It has a different laygear and 1st motion shaft.
18th Oct, 2004 at 06:33:44am
Sorry guys, should have read the topic title. The word guru has nothing to do with me.
18th Oct, 2004 at 08:41:25am
Sorry Jukka, but you must have had a blow to the head! The term is pretty close to the truth for yourself in my opinion!
18th Oct, 2004 at 08:52:51am
thanks for all this help guys, i am begining to get it now, keep the advice coming!
18th Oct, 2004 at 08:57:16am
if i do decide to rebuild the box my self are there any specific tools i am gonna need?
18th Oct, 2004 at 09:07:49am
Haynes Metro workshop Manual.
18th Oct, 2004 at 08:28:03pm
ISRT MOTION SHAFT NUT IS 29MM IN METRIC TERMS. always looking for them bigger bunches of bannanas |
18th Oct, 2004 at 10:18:17pm
right does this lot sound alright?
19th Oct, 2004 at 09:48:58am
I'm not sure if the S/GT conversion is worth the money, as the ratio increase is only slight...
19th Oct, 2004 at 09:53:23am
he's got a 4 pin on his list dave |
19th Oct, 2004 at 10:03:29am
I used to have a box with the S/GT ratios in it, I used to love it as it basically had a longer 1st gear, and then the rest were all closer together. Especially 3rd to 4th was nice and close.
19th Oct, 2004 at 02:11:18pm
use std drops if thats all you can afford!
AlexF |
19th Oct, 2004 at 02:52:14pm
Yes definately. If you can't afford s/c drops then you need to make sure your helical ones are set up 100%. So that means checking the size of the bushes in the primary gear, checking the size of the crank nose where the primary gear sits. Also the endfloat of the primary gear is important. As is the endfloat of the idler gear, this needs to be set up to the correct tolerance as well. To do this the haynes manual details a method using wax washers to determine the clearance, or do it with the gearbox seperated from the engine using a new gasket and a set of feeler blades. Either way, you need to measure accurately (e.g. with a micrometer) the thickness of the thrust washers you have, and then order the oversize ones you require to get the float correct.
19th Oct, 2004 at 03:52:23pm
if i don't really need the s/gt conversion then i can strecth to a set of s/c drops.
19th Oct, 2004 at 05:28:42pm
Where in Hampshire...
AlexF |
19th Oct, 2004 at 09:29:40pm
winchester so just down the a303 from you i think.
