Home > Technical Chat > E85
PaulH
Member #: 2340
Dublin Ireland
Ok lads was just doing some research, E85 looks like it could be a great source of power for the Fuel Injection lads. Has anyone looked it to using it ??
On 17th Feb, 2009 Rob H said:
no,
i've looked at it a bit,
iirc on a na moter you wont gain anything, apart from a higher fuel bill, but for forced induction it will allow you to wind the boost more up as its more resistant to knock. but you will need another map to stick in around a 1/3 more fuel.
SumpNut
Member #: 28
I have with great interest, I did a fairly large study based project in my final year at university on alternative fuels mainly e85.
If anywhere near me had it at the pump both my cars would be running on the stuff, it goes fantastically well in turbocharged applications.
Just fit a big fuel tank if you plan on driving any distance!
Edited by SumpNut on 31st Mar, 2009.
I've read that e85 likes to eat aluminium, some plastics and some rubbers. I wish it was as simple as changing your map.
SumpNut
Member #: 28
most fuel pipe rubber post late 80's is normally ok.
To get round problem with aluminum you need to anodise. Easy enough to do at home with a caustic soda and care.
Also if you run a carb the float chamber in an SU will need doing too.
PaulH
Member #: 2340
Dublin Ireland
Well what I have found out so far,
to run E85 the changes you need to make are,
Stainless steel fuel lines or braded PTFE (no great shakes)
change your Fuel map and Ignition map (again no great shakes)
if you run an alloy tank it needs anodising little bit of hassle if you have run it with fuel before.
but the benefits seem great
104 Octane
very high Nock suppressant
all that means more boost so why ant we using it ??
surely this means we could keep the same boost and increase the compression meaning less boost need to make the same power meaning cheaper turbos lasting longer.
from what i've read modern fuel hose is ok with e85, not sure i'd trust it though judging by the rate of deterioration of most rubber parts theses days *oh well*
it is meant to attack bare alluminium, but as alluminium quickly builds up a barier oxide layer (like a thin anodising) i personally dont think this would be a massive issue. also e85 is run in lots of egines with ally heads (read ports) and there does not seem to be an issue there.
another issue is that e85 will "clean" your fuel system, so any crap in the tank/ fuel lines etc will dislodge and can cause issues blocking stuff, floatvalves, regs etc.
I put my fuel system together with the thought of using e85 at a later date, I sealled the twin tanks with POR tank sealer, ran ptfe lined airoquip hoses, anodised the fuel rail. Megasuirt has the capability to read alcohol content from a flex fuel sensor and interpolate between a petrol and e85 map. all you need to do then is make sure you don't use too much boost with too little e85 lol.
DD_Racing
Member #: 3013
Epsom Surrey
the yanks are really big on this at the moment and i quite often read a magazine called hot rod and they often do alot of good reading material about e85 and the differences in power gains over normal fuel!!
id highly recomend buying a few copys!! this mag is a really good read!!
PaulH
Member #: 2340
Dublin Ireland
Ya but you would have to live with the shame of buying an American Hot rod magazine, I'd sooner by gay porn at least you would get a sympathetic look from the girl behind the till :(
DD_Racing
Member #: 3013
Epsom Surrey
nah its not about hot rods, there crap!!!...lol
this is a pure muscle car mag goes really indepth with tunning and does loads of articles on budget engine builds to full blown 3000hp motors!!
they go really in depth and its a very good mag!!
I've done quite a bit of anodising at home, to anodise a fuel tank your going to need a containter big enough to hold the tank, which is not made from any metal apart from titanium, your going to need shed load of acid and lead, you also need to boil the tank. So going to need a pretty large setup. I'd love to anodise my fuel tank, just because I think it would look great!
wouldn't the acid leak out from the wooden sides of the shed Jim,
surely you would be better off with a large plastic container load of acid,possibly as large as a shed.
but using a shed is just fooking stupid,
carl
You are already putting 5% ethanol into your tank, so Unless you intend to go E100 I dont think the aluminium thing is going to be an issue. After all, cylinder heads these days are aluminium.
I would have expected the fueling to be injection rather than carburation and AFRs tend to increase to around 9:1
I looked into this as there is a pump just 12 miles from me. More of a challenge than anything else, and simply to say that I have one of the cleanest running Mini engines. The environmental renewable energy aspect of it is some what debateable.
There are a lot of people, mainly in the US, who have used E85 on standard engines and management systems for thousands of miles without issue, despite manufactures warnings that it will damage the engine and fuel pumps. However, this may well be down to the lack of testing done by the manufacturers, and not wanting to commit themselves to any liability with the slightest possability of any failures attributed to E85. Ususal story, some one says in theory you cannot, but in practice, you can.
E85 is an excellent fuel system cleaner, stripping the varnish left by petrol on all the fuel system, and then dumping it at the injector with the obvious result. It is recommended to fit an aditional fuel filter as close to the injectors as possible for a period to catch all that crap. It can then be removed.
One down side is with the mini, is the size of the fuel tank. If the car is anything other than short duration racer, you need to fill the tank more often, and if its a road car, you have no chance of getting from one station to the next, where the actualy sell E85.
http://www.efiminis.olicentral.com/index.p...msg3563#msg3563
carl
PaulH
Member #: 2340
Dublin Ireland
I am seriously thinking of runing it in the racer there is a Maxoil station 10 miles from my house which has it. It should alow me run a very stable boosted engine with higher compression,
I take it that it has no afect on wide band O2 sensors as there only reading O2
johnnysti
Member #: 2480
Can you get this stuff at the pump in England? I only use Shell V-Power. Anything else and the car throws a wobbly!! Even the Tesco 99 RON stuff
feature=mhum
there are (was) about 15 pumps in the uk that have it,
you can search where they are online.
http://www.saabbiopower.co.uk/default.asp?docId=13115
Vpower is gauranteed to be at least 99 octane at the pump. The same cannot be said about Tesco 99, you might be lucky and get 97 at the pump. Dont use anything other then V Power *wink*
Lambda sensors are fine, and depending on which ECU you use, the Lambda and Lambda target maps dont need to be altered, just the VE map due to the engines requirement for more E85 compared with Petroleum. Lambda is the same irrespective of fuel, AFR on the other hand is not
PaulH
Member #: 2340
Dublin Ireland
Thanks Colin, Slowly starting to get my head around this Watch out in the coming weeks Ill get a build thred going on EFI just need to have somthing to show first :)
Hedgemonkey
Member #: 360
Not worth using IMO. Somewhere on here, I posted the old skool fuels brew, including E85.
You would be a lot better off adding 4% TEL/EDB and 2% methyl aniline to 95 octane petrol. That's as close as you can get to avgas without buying a weird feedstock.
The calorific value is less, which is a snag.
I would most certainly try it, but I would expect to find a much of a muchness. I expect it would yield similar £/hp as normal petrol. Money spent better is better spent on additives. One of the worlds largest TEL manufacturer is in the UK and you would be able to get Me-Aniline from a chemical supplier.
Do a google search for di-cyclopentadiene and have a look at it's MON!
I personally think E85 is probably good for cutting up with a bit of methanol and nitromethane for strip fuel for something.
I'd be very interested in a direct comparison with proper fuel.
good luck!
Edited by Hedgemonkey on 1st Apr, 2009.
i think you've missed the point stu,
85 is classed as pump fuel, and although may be a grey area could be considered eligable for some race clases, where as dyspazmo-hyromethane mixed with amal nitrate won't be.
yes your right that it has a lower calorific value, but it will stand a lot more boost.
SumpNut
Member #: 28
I'm not too up on ecu maps and mapping, but surely if I am reading this right then the lambda target map would need to be altered as air fuel ratio on e85 is very differnt.
So if you are cruising around gently the afr target is still set to 14.7 to one from the petrol map, would it not run very lean because stoich arf on e85 is more like 9.7 to 1?
If you use lambda rather than AFR for the fueling tables, it wont matter what fuels you uses, stoich is always lambda 1, however with AFR stoich might be 14.7:1 for petrol and 9:1 for E85
Lambda is a factor rather than a ratio
