| Home > Help Needed / General Tech Chat > no turbo whistle anymore | |||||||
160 Posts Member #: 1085 Advanced Member Netherlands |
13th Apr, 2009 at 10:19:23am
Hi all,
1963 Cooper
13th Apr, 2009 at 10:21:07am
Drive it up the road under load and see if it makes boost then. Revving it up under no load never makes any boost pressure.
13th Apr, 2009 at 10:33:30am
ok, thanks; I'll try that first. I was just afraid to ruin something when it gets really hot and it's not working properly.
1963 Cooper
13th Apr, 2009 at 11:30:40am
i guess that when you first ran it up it didnt have things like air filter on?
13th Apr, 2009 at 05:38:24pm
I just took it for a brief drive; no boost whatsoever. I even checked the boost gauge and that's fine. Mixture's weird too: at idle I set it at 3% CO; but when I rev it the mixture drops to .2%. I'll stick another needle in first, but still puzzled about the turbo. 1963 Cooper
13th Apr, 2009 at 06:28:04pm
What needle have you got in ? If it's stock the needle should be BDD. |
14th Apr, 2009 at 01:10:04pm
With the din the exhaust makes you’ll be hard pushed to pick it out.
Own the day
14th Apr, 2009 at 07:53:56pm
I ha a BDD in there; now a BDC. No change, even after I removed the air intake duct. It would rev when standing still, but die immediately. Since I ha no choice but to dreive it home (5miles) I decided to see how things went with the plenum removed: that's a vast improvement: it's quick enough in N/A form for the trip tomorrow, so I stuck a K&N cone to the carb and leave the turbo for now. I do hear it whistle when I drive it hard, but it seems to stick at lower revs so the carb gets starved of air or something. There's no way I get above 20mph with the plenum in place. I think this is a dead turbo, although I'm still puzzled as to how that happened. On a positive not: I got an MOT on it today, so the rest is good enough. 1963 Cooper
14th Apr, 2009 at 09:18:47pm
Is the wastegate actuator still connected to the wastegate? |
14th Apr, 2009 at 10:47:31pm
even a dead/siezed turbo wouldnt hinder performance that drastically i wouldnt have thought? "Turbo's make torque, and torque makes fun"
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
15th Apr, 2009 at 01:18:31am
On 14th Apr, 2009 metroturbo said:
Is the wastegate actuator still connected to the wastegate? this sounds like a good port of call, wind it up to the highest seting then take it out, if thats no good then id say the nut on the end of the comp wheel has come loose,maybe, On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
15th Apr, 2009 at 02:01:00pm
Yes it is. I assume it pushes the rod out under pressure? That's how I adjusted it anyway. I stuck a finger down both inlet and exhaust side and there's no play between the impellers, nor is there any play on the shaft. I'm not too experienced with turbo's, but it feels as if it could spin freely no problem. At least with good oil pressure going there I can hopefully drive it to France tonight before I take the whole thing apart again. Running it in N/A form doesn't appear to be a problem right now.
Is the wastegate actuator still connected to the wastegate? 1963 Cooper
15th Apr, 2009 at 02:32:11pm
Your balance pipe is leaking when you boost up if this item leaks you end up forceing fuel back down the jet. Thats why its running ok with no boost added into the equation.
Own the day
15th Apr, 2009 at 02:36:43pm
Is the wastegate actuator still connected to the wastegate? this sounds like a good port of call, wind it up to the highest seting then take it out, if thats no good then id say the nut on the end of the comp wheel has come loose,maybe, From when my brother was dealing with turbos he explained the threads on the compressor and turbine are frozen and the nut is heated then the two are torqued up. Even in this state he says the nut is a tight fit. Own the day
15th Apr, 2009 at 04:27:10pm
I've been thinking of fuel starvation myself, but thought the regulator might be toast or something (seeing that the engine works fine in N/A mode I think it's ok after all, or the carb would flood). BTW I hooked that up how I thought would be right; the drawing in Haynes is horrible and they seem to miss one connection (the bottom one) completely.
On 15th Apr, 2009 Mr Joshua said:
Your balance pipe is leaking when you boost up if this item leaks you end up forceing fuel back down the jet. Thats why its running ok with no boost added into the equation. 1963 Cooper
15th Apr, 2009 at 04:37:18pm
Some good pics on Phil's site i believe turbo-mini.com |
15th Apr, 2009 at 05:25:37pm
Own the day
15th Apr, 2009 at 05:50:33pm
This is also known as the "Part-throttle lean off pipe" In the 13's at last!.. Just |
16th Apr, 2009 at 10:07:41am
Never Knew that:) Own the day
16th Apr, 2009 at 11:34:58am
And it's also made of a special grade of shiny rubber that is designed to brake up and split as soon as you look at it sideways. On 7th Nov, 2008 Nic said:
17th Apr, 2009 at 10:54:12am
Knew that Own the day
17th Apr, 2009 at 10:01:10pm
I assume you have adjusted the wastegate pre-load to increase the boost? Apologies if I am stating the obvious, but did you wind it the right way?
On 15th Apr, 2009 Arnoud said:
Yes it is. I assume it pushes the rod out under pressure? That's how I adjusted it anyway. |
17th Apr, 2009 at 10:09:22pm
Thanks for the pic:) that line is in place and as far as I can see it still has the original clamps on it.
1963 Cooper
17th Apr, 2009 at 11:44:59pm
cant tow on a rope?
18th Apr, 2009 at 12:26:37pm
you can use a pole, but certainly never on the autoroute; on countrylanes you can't exceed 20km/h. Since we were still 400km from where I wanted to be we abandoned that idea. I'll arrange for a trailer this Monday instead.
On 17th Apr, 2009 mini13 said:
cant tow on a rope? thats hartsh! how about on aa tow pole? 1963 Cooper
