| Home > General Chat > Paint/Lacquer help | |||||||
14th Apr, 2009 at 09:58:38pm
One for Wiggi or Rick I think this....
14th Apr, 2009 at 10:05:07pm
you can let it dry Tom, but if your feeling brave go wet on wet,
14th Apr, 2009 at 10:10:07pm
The base coat will go matt when its dry - about 15 mins in decent temperature thats touch dry too, so you can wipe over it again with a tack rag if you want.
I seriously doubt it! |
14th Apr, 2009 at 10:24:23pm
On 14th Apr, 2009 paul wiginton said:
The base coat will go matt when its dry - about 15 mins in decent temperature thats touch dry too, so you can wipe over it again with a tack rag if you want. Do a couple of colour coats, letting it dry or 'flashoff' inbetween, then the lacquer. Its pretty much impossible to get runs in the colour as you can dust it on, but as you know, be careful on the lacquer coats not to get runs Paul ive just told him that but i took up less bandwidth ,lol carl |
14th Apr, 2009 at 10:26:48pm
As paul said tom, the base will be touch try in a few mins and you can tack inbetween coats, you will find usually two coats and a drop(dust) .It will dont go over it when its still wet, but by the time youve cleaned the gun for lacquer then it will be dry anyway.
559 Posts Member #: 2775 Post Whore Aberdeen |
14th Apr, 2009 at 10:31:03pm
Paul I thought that the base would take alot longer to flash off with just thinners and no hardener? I was also under the impression that with doing 2k Paint and not using the hardener you needed to catch it just as it flashed off before putting on a lacquer or leave it 24hrs / or bake? Is this a bit of a bad case of chinese whispers? I know when I painted my car I did 2k with thinnners and no hardener then polished out my orange peel. I never did put a laquer on it. Whats the best way to do it to get a good finnish?
14th Apr, 2009 at 10:37:59pm
With direct gloss colour you use a hardener and no lacquer.
![]() 367 Posts Member #: 1643 Senior Member West London |
14th Apr, 2009 at 10:46:00pm
Orange peel is down to how the paint is applied. The gun is to close to the job.
Lightweight racer coming soon. |
14th Apr, 2009 at 10:51:55pm
Cheers guys. The gun I used was a borrowed item from a friend. Once I get my welding done I am going to be in the market for my own gun. Any recommendations. It will be hardley ever used so nothing to steep. But I dont want a pile of crap that is going to make painting my car again even harder than it is? |
14th Apr, 2009 at 10:56:11pm
devibiss gti with a 1.4 fluit tip and 110 air cap. max 2bar
14th Apr, 2009 at 11:00:40pm
Lockfast - Something like this will do. :)
14th Apr, 2009 at 11:03:18pm
Thank you |
14th Apr, 2009 at 11:05:49pm
sorry to hi-jack Tom.
14th Apr, 2009 at 11:19:38pm
Depends how much you got to paint, I prefer using both gravity and suction fed.
15th Apr, 2009 at 07:25:54am
Cheers all, we'll see how I get on today.
15th Apr, 2009 at 10:29:53am
Well here are my painted wheels, in the end I let the base go touch dry and then lacquered them. They are for my Peu**ot sorry
15th Apr, 2009 at 10:40:00am
They look smashing, but you need a bigger tarpaulin! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
15th Apr, 2009 at 10:41:04am
They look good Tom.
15th Apr, 2009 at 10:55:36am
Good to know Paul!
15th Apr, 2009 at 10:58:28am
A tip for next time Tom, get them higher and you wont blow dust around so much
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
15th Apr, 2009 at 12:36:44pm
Did you use etch primer on the ali? Geoff |
15th Apr, 2009 at 12:47:16pm
Yes I did
15th Apr, 2009 at 01:03:28pm
If he use dthe old paint as the foundations he need no apply etch primer.
Own the day
15th Apr, 2009 at 07:02:05pm
It's not the paint in the paint pot, its the paint in the gun pipes itself that goes off Lightweight racer coming soon. |
16th Apr, 2009 at 10:00:42am
I normally get a ragged soaked in thinners and drape it over the pot, and leave the gun standing in a bucket/kettle of thinners if leaving for a long period. that way the thinners will keep the paint in the gun moist You can do that if your gun is an all metal construction, not all are! A mate scrapped two and a half grands worth or was it £25,000 worth of static gun through the same assumption Good thing it was his own kit. Best practice, wash your guns out before running in to watch strictly come dancing
Edited by Mr Joshua on 16th Apr, 2009. Own the day
