Home > Help Needed / General Tech Chat > spark plugs getting hot. do i need cold ones
psimini
Member #: 6070
they get quite hot what is the model or serial number of the right plugs
na engine + turbo + boost = ya hewwww
The correct NGK plug is the BPR7ES or BPR8ES, In most cases the 7s should be ok.
I don't know the number of the Champion equivelent, it's something like NYCC7 or something
PaulH
Member #: 2340
Dublin Ireland
If your using clock work Ignition with Silicon leads then you need BP7ES or BP8ES
If you are using Mega jolt or the likes then BPR 7 - 8ES
the Silicon leads are all ready resistive and so don’t need resistive plugs this will only lead to misfire.
On 17th Feb, 2009 Rob H said:
psimini
Member #: 6070
awesome thanks for the info paul
when you say 'quite hot'
do you mean 'hot to the touch'
not meaning to be a nob, but they will get rather warm sat in the combution chamber
psimini
Member #: 6070
yeh really hot probably glowing
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
all that must be a joke!!
so who's under psimini???
psimini
Member #: 6070
pardeon
You really need to either give up and let someone else work at your car...or learn very fast.
Because some of the statements you are making.....could lead to some of those epic stupidity threads you find all over the net.
lockfast
Member #: 2775
Aberdeen
on a similar note. My coolant is only cool when the car is not running! After a long run it is hot! Do I need to get colder water to put in?
Sorry! I couldnt resist.
By the way I have a slight puncture its only at the bottom of my tyre! Any advice?
n.g.l.
Member #: 181
Chard, Somerset
Class, Lockfast. Has anybody seen the videos of this car on youtube?
http://www.youtube.com/watch?v=86gcWT6n5xg
http://www.youtube.com/watch?v=76Vw3503XYI
http://www.youtube.com/watch?v=FsH6jXZrfF4
http://www.youtube.com/watch?v=GWNaatqnQHw
I think they should have done some homework first. *hehe!*
SidewaysGTM
Member #: 5022
Oxford, Kings Lynn, Pod, Pub.
On the coolant, I would guess you filled you minis radiator from the hot tap at home I would suggest you use the cold tap as it will run cooler.
Anyone got any ideas where i could find a cordless extension real?
WEST
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!!
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Whats happening in the one vid, where the dash-pot is missing and a pair of pliers in holding a rubber pipe where the dash-pot should be ?
"Try to take over the world!"
Unbelievable....... on the second video, 25 secs in, there is no top on the carb but what looks like a fuel pipe held down the top with mole grips.....
Can somebody change his username to 'Dangerous Brian'?
fab
Member #: 100
Paris' suburb
so you're real?!!
*Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping* *Clapping*
PaulH
Member #: 2340
Dublin Ireland
FOR THE LOVE OF GOD :(
psimini
Member #: 6070
pack of arseholes. everytime i try and get advice it turns into this. fucken poms
evolotion
Member #: 83
Glasgow, Scotland
people have answered your problem countelss times and you dont aknowlege the answer what do you expect? its like you sayign 2+2=? everyone answering "4" yet you ignore it and continue asking the question :) fit a restrictor. fit the grade "8" plugs. tune the needle as per the sticky threads, enjoy.
Denis O'Brien.
Well when you ask stupid questions, what sort of answer can you expect ???
If you havent the first notion about how to tune a car...then maybe you should consider getting someone who has to do it.
Go buy David Vizard's how to tune an A-series, and after you have read that, you might be in a better position.
littlejem59
Member #: 2544
Biddulph, Stoke on Trent
OMG PMSL *hehe!* *Clapping*
It's not the age that makes me creak it's the mileage
Carl S
Member #: 1761
Stalker
poms
I hope you took care when excavating that insult, it's almost 3 centuries old!
Jay#2
Member #: 648
Northern Ireland (ex AUS)
poms
It could be worse, you could be a Kiwi! Apparently New Zealanders have the same tendencies towards sheep as the Welsh (Sorry Jimster).
On 7th Nov, 2008 Nic said:
naeJ
m
poms
They also really love been confused for Australian people. I call the Kiwi that I work with Bruce. He loves it. *smiley*
giallofly
Member #: 164
The Stig..
Newport Pagnell
EXCUSE ME?
Are'nt we supposed to be nice to new members?
I realy think we should give this total wankstain of an arsewipe a chance.
JF.
Edited by giallofly on 19th May, 2009.
