| Home > 998cc > Head | |||||||
27th May, 2009 at 09:39:15am
Im collecting parts for my 998T build.
I seriously doubt it! |
27th May, 2009 at 10:50:11am
I know Keith Calver really rates the 202 heads as they can be made better than the 295 heads. It takes time though. His reasoning was that a 295 is good, but lacks material some places where it shouldn't, the 202 didn't, but is not as good by far, when standard, compared to the 295 |
27th May, 2009 at 11:40:46am
In all honesty I would go 12G940 Paul its a rocking setup and with little or no porting it will flow very well for a 998.
On 17th Feb, 2009 Rob H said:
27th May, 2009 at 11:48:38am
Considering the similarities in spec between the hillclimber and the road 998T, I would say that the 940 on the hillclimber has more potential.
27th May, 2009 at 11:53:30am
If doing a "mild" job, the 295 would be far less time consuming to get right.
Edited by Vegard on 27th May, 2009. On 13th Jul, 2012 Ben H said:
27th May, 2009 at 12:01:54pm
See my new thread in the 998 section :) |
27th May, 2009 at 12:04:25pm
I was thinking that a 940 with the guide bosses removed would be cheaper than a ported 295 or 202 to give the same results due to the 940 ports being bigger in the first place.
27th May, 2009 at 03:44:10pm
paul,
Edited by robert on 27th May, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
27th May, 2009 at 04:35:38pm
Robert are you going to over bore the motor if not why not run the standard Flat top piston that came in all the late 80's 998s I have about 5 sets here ? On 17th Feb, 2009 Rob H said:
27th May, 2009 at 07:50:54pm
thanks paul , appreciate the offer . i have a set here too, i was checking it out and, with the longer stroke of the 1098 ,they stick out of the bore 3.15mm , if i machine this off this leaves it v close to the top ring and a bit thin in the crown ,very dissapointing ..i dont want to skim this head . Edited by robert on 27th May, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
27th May, 2009 at 08:06:31pm
Why not use a 1098 block? Isambard Kingdom Brunel said:
27th May, 2009 at 08:24:39pm
On 27th May, 2009 Rob H said:
Why not use a 1098 block? Is it just because theyre not A+? Paul I seriously doubt it! |
27th May, 2009 at 09:00:14pm
the 1098 block and the 998 are the same i think rob .the 98 pistons i have are a plus , the 1098 ones are pre a plus . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
27th May, 2009 at 09:27:57pm
I defo would ude the 295 head,
27th May, 2009 at 10:56:12pm
Why not use a 1098 block? Is it just because theyre not A+? Paul The 998 and 1098 use the same block.. In fact, a later 998 is better as the early 1098s were thin flange. On 13th Jul, 2012 Ben H said:
28th May, 2009 at 06:51:41pm
yes vegard ,the block i have has a little flange. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th May, 2009 at 07:19:19pm
I love a little flange! On 28th Aug, 2011 Kean said:
28th May, 2009 at 08:27:34pm
I cant be fussy |
28th May, 2009 at 08:31:59pm
Me too!
On 28th May, 2009 mini13 said:
I love a little flange! If something is worth doing, it's worth doing half of. |
28th May, 2009 at 09:11:07pm
I prefer a tight flange to a little one... On 11th Feb, 2015 robert said:
28th May, 2009 at 09:12:54pm
To be fair flange is flange. If something is worth doing, it's worth doing half of. |
28th May, 2009 at 09:34:35pm
even when it covered with a thatch like a thirteenth century barn? On 28th Aug, 2011 Kean said:
28th May, 2009 at 10:33:34pm
On 28th May, 2009 apbellamy said:
I prefer a tight flange to a little one... I've never encountered one that isn't tight.... On 13th Jul, 2012 Ben H said:
28th May, 2009 at 10:37:05pm
28th May, 2009 at 10:39:37pm
I wondered how long it would take to go off topic. lol
