Home > Help Needed / General Tech Chat > blanking plates
turbo22
Member #: 3684
wisborough green west sussex
right i will no longer be having a heater, so is it best to just block off outlet on the head or should i pipe it back into the rad? would this give better cooling?.
What do i do with the outlet on the back of the block which i believe the mechanical fuel pump goes? any help would be great thanks.
Back into the top hose, or top of the rad, is the best place for it.
A pump blanking plate, believe it or not, is the best thing to blank the pump hole....
Edited by turbodave16v on 27th May, 2009.
turbo22
Member #: 3684
ok thanks thats what i thought, what about plate on the back of the block?
turbo22
Member #: 3684
scratch that... thanks
chinlesswonder
Member #: 1192
In the garage......again!!
Are you not using the fuel pump as the turbo oil return?.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
turbo22
Member #: 3684
i have a red top pump so im unsure on what to do there only just got to that point.
chinlesswonder
Member #: 1192
what turbo have you? is it the standard Garret T3? if so, it uses the mech fuel pump fitment as the oil return.
turbo22
Member #: 3684
yer i will be using a t3, this is my first build so learning a i go right ill try and find more on it thanks for your help!!!
If you're turboing, the Red top is of no use.
chinlesswonder
Member #: 1192
No worries, search buttton up there^^^ has most of your answers.
turbo22
Member #: 3684
why is redtop no good??? what will i need?
chinlesswonder
Member #: 1192
Easiest is to get hold of an MPI tank, it has the pump inside fitted plus has a fuel return on as well.
turbo22
Member #: 3684
i have bought a alloy tank for the boot, cant i just use that with a red top?
turbo22
Member #: 3684
for fucks sake no
nope,
a red rop make about 7psi
you need a high pressure fuel pump, able to give 2-3psi on top of boost pressure (essentially a fuel injection pump that can deliver 50psi)
this then needs to be used with a fuel pressure regulator referenced to boost.
turboing 101...
next time your compressor is running, try pissing down your airline.
thats why you can you a red top with a turbo set up.
Be careful not to inflate your penis though........................
turbo22
Member #: 3684
lol ok not high enough preasure then what pump would you reccomend?
An injection pump of some kind.
minimansam
Member #: 6195
yea, like a bosch one, there good as long as you get the one,
i got one off ebay, brand new £50, then i checjed the part number on the bosch website and its more than adequate,
if you cant find and bosch ones try searching for a decent roller van pump, i think minispeed do one but its not cheap.
minimansam
Member #: 6195
p.s, i ment the RIGHT one, sorry lol
turbo22
Member #: 3684
ok great thanks i will look into it if not is the standard metro turbo pump good enough?
Yes, it's fine for 30+psi of boost.
shane
Member #: 1246
Lowestoft, Suffolk.
I have a metro pump with bracket spare, if your interested PM me.
Shane
