| Home > Help Needed / General Tech Chat > Wiped center main bearing | |||||||
27th May, 2009 at 06:58:33pm
Ok so i have had problems with excess noise and vibration under load on the engine.
Edited by Sprocket on 15th Jun, 2009. On 26th Oct, 2004 TurboDave16v said:
27th May, 2009 at 07:10:39pm
Bummer :(
27th May, 2009 at 07:19:52pm
i cant comment much as dont know enough detail to help diagnose, but i cant see how a poor dyno tune can affect one main bearing in an engine and not the others, and the slant your post has hints towards an alternative view. turbo 16v k-series 11.9@118.9 :)
27th May, 2009 at 07:21:25pm
Get the crank magnafluxed before even thinking about re-working it. I wonder if this would also show a potential problem.
27th May, 2009 at 07:21:36pm
Did you check the internal diameter of the mains after the block was line bored? Isambard Kingdom Brunel said:
27th May, 2009 at 07:24:30pm
On 27th May, 2009 mini13 said:
Bummer :( its not something like not enough bearing crushfrom the centre main? has the bearing actually spun or just smeared? Oil too hot? also didnt you have oil press issues on this lump a little while ago due to the zetec jets? i asume you changed the bearings when you changed to bimmer jets. well, the bearing I think has overheated causing the copper back to soften up. The backing has spread, baisicaly its wider in the middle than it is at either end of each shell. you can see on the back of the bearings, where they originaly sat, and that the two halves have starter to move, but i think its down to the excessive temperature rather than insufficient crush. The center main was line bored and then honed, all clearancies checked out and the whole engine purned over without binding without rings. When I changed the oil jets, I completely stripped the engine and the bearings at that point wer perfectly fine, so I re used them. The only difference on the engine on the rebuild was the oil jets, and that gave oil pressure at idle that i never had previously. Oil temperatures never rose above 110c, and the gauge is fitted in the main fead from the pump before the oil filter On 26th Oct, 2004 TurboDave16v said:
27th May, 2009 at 07:25:04pm
Piccys ???
27th May, 2009 at 07:25:19pm
I had a centre main wipe after only 10 1/4 mile runs last year, I cant explain that either
I seriously doubt it! |
27th May, 2009 at 07:34:19pm
On 27th May, 2009 TurboDave said:
Get the crank magnafluxed before even thinking about re-working it. I wonder if this would also show a potential problem. Oil pressure fluctuation is something I always got with the MS pump; prior to the powerflow unit. Not sure what you're running however. In this case however; we'd need more info on the 'main' hose - did you tap off the gauge hose at the head, or at the block end? Are we taqlking -3 or -4 hose? Dave, im using the Turbo powerflow unit, although it came from minispares. The gauge hose is something I got through work, its a refrigeration grade hose, and would equate to a -4. it was tee'd off from the external feed at the head, not the block. when I say the gauge fluctuated, im talking so much you could not read it, it fluctuated a good 1/4 to 1/2 the scale On 26th Oct, 2004 TurboDave16v said:
27th May, 2009 at 07:40:18pm
On 27th May, 2009 evolotion said:
i cant comment much as dont know enough detail to help diagnose, but i cant see how a poor dyno tune can affect one main bearing in an engine and not the others, and the slant your post has hints towards an alternative view. This was not a tuning session, but a dyno shoot out. I have been on rollers before for tuning and the operater never caused the gearbox to jump out of gear at 8krpm, nor did he get the car to jump in the rollers. This engine and car has been on the dyno for two tuning sessions 2 hours each and a dyno shoot out for MiniMag, that was all prior to this. I rebuilt the engine, drove 110 miles to York, ragged the arse off it and drove 110 miles home. drove 40 miles to Bury perfectly fine and the bearings failed. I know what I said in the other topic, and yes, due to the unknown nature of the engine prior, my comments were pure speculation, as they are with this. One thing is sure though is i know when the car is being treated rough on the dyno. On 26th Oct, 2004 TurboDave16v said:
27th May, 2009 at 07:40:47pm
On 27th May, 2009 Rod S said:
Piccys ??? I'm surprised if the top half is as bad as the bottom. Piccies up in a bit On 26th Oct, 2004 TurboDave16v said:
27th May, 2009 at 08:00:11pm
measure the circularity of the centre main once the crank is out ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
27th May, 2009 at 08:01:04pm
a bearing can fail over thousands of miles, never mind 40, could comfortably be a coincidence.. being rough on the rollers and unsympathetic to your gearbox doesnt affect your main bearings.(unless it was buzzed or ran low on oil/overheated)all im saying. turbo 16v k-series 11.9@118.9 :)
27th May, 2009 at 08:25:08pm
which revs did you pull on the dyno?
27th May, 2009 at 09:37:15pm
Right then
27th May, 2009 at 09:55:43pm
I,M puzzled as anyone, but you did say earlier that you re-used the bearings after a stripdown,which is something I would not do,personally.could this have any relevance do you think ?. Not trying to score points, just offering suggestions as the answer is still not found. |
27th May, 2009 at 10:13:26pm
colin , in case this helps .
Edited by robert on 27th May, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
27th May, 2009 at 10:30:17pm
Wow...
27th May, 2009 at 10:36:30pm
i'm thinking along the same lines as Rod,
27th May, 2009 at 10:44:01pm
Could the main cap have distorted clamping the journal too tight, causing heat and friction causing failure?
27th May, 2009 at 10:45:41pm
could it have been left some small pieces of metal from the machining for the BMW jets in the oil gallery? This could have found its way to the bearing, and on their way caused oil pressure issues? |
27th May, 2009 at 10:54:06pm
could it not have been a drop in pressure on the centre main caused by the new jets on either side 'robbing' it of oil 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
27th May, 2009 at 11:06:32pm
On 27th May, 2009 chinlesswonder said:
could it not have been a drop in pressure on the centre main caused by the new jets on either side 'robbing' it of oil No
I tell you why. The Zetec jets i used had no check valve in any of them, and was a full bore nozzle, not crimped down. Oil pressure at idle when the oil was hot did not refgister on the gauge and was tickling the oil light. So if anything I should have suffered bearing failure then, and not now On 26th Oct, 2004 TurboDave16v said:
27th May, 2009 at 11:11:31pm
It could be the bearing cap, I dont think it has moved after all there are now four bolts holding it in place. It was a loose fit on the dowels when I removed it, it wasn't when it went on. On 26th Oct, 2004 TurboDave16v said:
27th May, 2009 at 11:16:26pm
On 27th May, 2009 paul wiginton said:
Could the main cap have distorted clamping the journal too tight, causing heat and friction causing failure? Paul possibly but i'd say no in my experience, this is how i know, ive just stripped the don lump as the hg had failed , history, only tom and myself know up to this point that when i origionally built the engine 2 years ago, the crank was stiff on the centre main, with just the crank in and torqued up it would lock up if not kept turning, if left for a few secs you could not get it to turn unless you put a small lever in the tail groove for a bit of leverage, the bearings showed signs of rubbing on the block side , not the cap,not much but defo rubbing, being a little inpatient and having time against us i ignored this tightness and built the engine up, this is the build that netted 220 bananas at emeralds, at the end of the year i stripped the motor and the bearings had settled down and the crank was spinning freely, so i freshened up everything else but reused the big end and main bearing even though they really looked as if they had taken a beating[which they had] that engine lasted all last year without problems.until the over heat at castle combe in sept 08. i then stripped the motor again and rebuilt as we'd lost all compression due to ring seizure because of the boiled oil at combe, now at the rebuild I'd over looked the head face so rebuilt the lump with new shells in the bottom end and stuck the head back on, two thing i did wrong here at this time, 1 assumed the head was flat. 2 assume the centre main was no worse than before, i rebuilt the engine in a hurry as we were due to do the mag shoot with matt , tom and myself did a few miles at elvington to try loosen the bottom end up but it just didn't want to know, even the dyno shootout did nothing to loosen the bastard up, which is why i would not let Tom run more boost, i knew it wasn't right, so i took the car to cadwell and give it a good pasting over 5 sessions, still the bottom end was stiff as the starter would struggle to pull the engine over TDC if it happened to stop there , even an outing to the pod entered into the euro street compact series did nothing to ease the stiffness[ even then i ran a 124 sec]. then at mins v beetles the HG failed [see above point 1]. so strip down no 4 was under way. the head turned out to have a 0.008" depression over 2 3 and 4 cyls , and the HG had blown over all three , so while the head was off i had time to ponder the bottom end that was still stiff even with no head on, needing a bar on the crank to turn it , the starter struggling to spin it fast even with no head on, something was wrong, so i tore the bottom end down, and after some diagnosis came up the a distorted centre main, i have had the housing line bored now and the bottom end really is as good as i could ask for, sweet as a nut so to speak, my very long winded point is that even after all the canning it had on a tight centre main the bearings them selves did not pickup or fail and i had perfect oil pressure all the time, so a tight bearing would not necessarily . fook that was along one, carl |
There is some blue'ing of the center journal only on one part with some ridges.
No
