| Home > Show Us Yours! > Intercooler Build | |||||||
1st Jun, 2009 at 08:29:35pm
Right, not wanting to be considered idle, I've started to build up my intercooler for the 998 Turbo.
1st Jun, 2009 at 08:49:11pm
On 1st Jun, 2009 Paul S said:
I've never welded aluminium before, so this may end in tears. Wish me luck. Having finally finished my injection runners today, I had just about got the hang of it back again ( I used to do lots a few years ago) - but doing a little bit of mild steel afterwards reminded me how frustrating alloy can be... Good luck... Schrödinger's cat - so which one am I ??? |
1st Jun, 2009 at 11:46:04pm
Try leaving an overlap on yuor parts, so you can melt this to form teh joint, instead of always adding filler.
1st Jun, 2009 at 11:51:56pm
With TIG welding ally you need to be brave with the current- too low and it will just "wick" all the heat away leaving you with a frustrating blobby mess.
2nd Jun, 2009 at 08:14:59am
for somthing like a cooler, 10 min in the oven may not go amiss. On 28th Aug, 2011 Kean said:
2nd Jun, 2009 at 09:01:00am
gas mark 3 ? what do they taste like? I run a supercharger and I don't care the TB is on the wrong side.
2nd Jun, 2009 at 04:20:53pm
Yes, high amps and nerves of steel are needed by the sound of it.
Edited by Paul S on 2nd Jun, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
2nd Jun, 2009 at 04:34:14pm
Not enough heat is more your problem Paul TBH. If I were you I'd seriously consider cutting some more bits to practise on before going for it for real. In actual fact depending on how much the core cost I'd probably tack it up and then get my mate Phil to finish it off!!
2nd Jun, 2009 at 04:41:56pm
Tom, lots of practise on scrap is planned first then only when I'm ready will I start on the end tanks.
2nd Jun, 2009 at 06:52:46pm
IS that the general idea then ? blast it with high current, and move fast ?
2nd Jun, 2009 at 06:58:50pm
This is inspiring:
2nd Jun, 2009 at 08:15:22pm
To do that takes real skill and a very steady hand...
2nd Jun, 2009 at 09:23:33pm
Well, I was itching to have a go, so instead of watching springwatch, I went and fired up the Tig:
2nd Jun, 2009 at 09:34:06pm
http://www.youtube.com/watch?v=rR8Rlpf0ELQ...re=channel_page
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
2nd Jun, 2009 at 10:48:45pm
Over the last two years I have been fortunate enough for my firm to pay for a couple of evening courses at college on tig, I finished the mild and stainless modules in good time and started the ally module in advance of next year. I sat for weeks trying to find what works best for me and found the pulse setting a god send, you could use it to blast the workpiece without huge heat build up allowing a pornounced weld profile, the other thing I found good was it was easy to get a good rhythm with the filler wire listening to the pulse and adding filler wire just after it pulsed (if that makes sense) also found it easier using a larger diameter filler wire as this deposited more material thus slowing down the rate you have to work. This is only what I found, and doesnt necessarily mean is right? lol
On 2nd Jun, 2009 Paul S said:
Yes, high amps and nerves of steel are needed by the sound of it. Most of the Youtube videos of alloy tig welding show the welder working at one hell of a speed. Comes with practise I suppose. Anyone tried "pulse" welding? Looks like a good way of preventing too much heat build up. |
3rd Jun, 2009 at 07:24:46am
Dial in some settings I thought would be a good starting point, including pulse. Started second bead up on the right and thought this is easy but then things got progressively worse after fiddling with a few settings. I think that as the plate got hotter with the additional welds, it got trickier. Tried the edge joint, but blew a hole half way, filled that and then got a huge hole at the end. Finally tried the foot pedal to reduce the amps, but I think that the pedal is working backwards i.e. foot down to reduce amps. Have another go tomorrow. i think that looks bloody good for a first go ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3rd Jun, 2009 at 06:24:03pm
Shane, pulse mode does seem to work best, although my cheap chinese tig has limited setup and the fixed pulse rate is a bit fast for my liking.
3rd Jun, 2009 at 08:12:35pm
Larger dia rod certainly seems to make things easier I have found too. Something else I tend to do is a small dip of rod right at the end, again to try and avoid a crater.
3rd Jun, 2009 at 11:20:27pm
On 3rd Jun, 2009 Paul S said:
Shane, pulse mode does seem to work best, although my cheap chinese tig has limited setup and the fixed pulse rate is a bit fast for my liking. I use high frequency, 70 Hz to get good penetration and a short slope down to stop it from creating a crater at the end. The current level seems to be difficult, too high and you have to work quick, too low and you end up going too slow and everthing gets too hot. Robert, thanks, I hope it only gets better. |
172 Posts Member #: 1600 Advanced Member Portsmouth, Hampshire |
4th Jun, 2009 at 09:50:32am
the main issue with welding ali, is all down to preperation of the metal. makes sure its very clean, use acetone if you can get some or give it a good rubbing with some scotch bright.
4th Jun, 2009 at 09:59:49am
That's very useful, Thanks.
Edited by Paul S on 4th Jun, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Jun, 2009 at 10:06:32am
Sharp tip for DC, soft tip for AC. I had all this to find out too!
4th Jun, 2009 at 10:42:13am
White tip tungsten is zirconiated - which is correct for alloy (thoriated (red tip) is for steels).
5th Jun, 2009 at 05:02:18pm
After a few more trial runs, I found settings that I could work with. Around 80 amps with pulse and use the pedal to start it off quick.
5th Jun, 2009 at 05:12:46pm
looks good, something id like to learn... Yes i moved to the darkside |
