| Home > Help Needed / General Tech Chat > AFR settings why the variance and does it have to be adjusted for different fuels | |||||||
20th Jun, 2009 at 09:57:40pm
Having used the search function my query is not yet answered.
Own the day
20th Jun, 2009 at 10:49:32pm
the theoretical and actual best ratios for best power are what change from engine to engine , combustion chamber shape, squish, valve sizes, tumble, swirl, sparkplug location, knock suppression, cylinder wall temperature are all things which will affect the air fuel ratio.
20th Jun, 2009 at 11:30:58pm
best power is not 15:1 not ever!
AlexF |
20th Jun, 2009 at 11:47:38pm
Yep, best torque at 12.5: or 0.86 lambda
21st Jun, 2009 at 12:16:05am
My race motors run best at 12:1 on In cylinders any Leader and as Colin said torque Falls off On 17th Feb, 2009 Rob H said:
21st Jun, 2009 at 01:00:11am
Bottom line, as sproket says the rolling road session will let you know what setting your engine build works best at.
Own the day
21st Jun, 2009 at 01:11:45am
On 20th Jun, 2009 Mr Joshua said:
Having used the search function my query is not yet answered. Basically it’s the matter of fuel air or air fuel ratio. Part of my training/education had us looking into piston engines in all their glory. On the subject of fuelling we were told that the perfect ratio for best power development was 15:1 period. Can you get whoever told you this, to back it up with proof. Get him/her to run an engine up on the dyno, preferably turbcharged, ensuring 15.0:1 AFR.... Then post up the pics of melted bits and slap whoever told you such nonsense.
21st Jun, 2009 at 01:19:04am
He was my lecturer when I was doing my LWTR training which was back in 1994 so no! Own the day
22nd Jun, 2009 at 12:14:47pm
He's either confused or talking about somthing else LOL AlexF |
22nd Jun, 2009 at 10:55:08pm
Denis hit the nail on the head, you can have rough figs to start with, but all engines are different, i run mine with afrs that the skyline boys don't agree with, and they can't understand why i haven't blown it up. Best 1/4 mile 13.2 seconds @116 mph
23rd Jun, 2009 at 02:10:23am
On 20th Jun, 2009 evolotion said:
(lean burns hotter, just think of an oxy-acetaline torch) more boost may be allowed making the engine ultimately more powerfull, or just simply more likely to survive! Lean is not hotter, it is cooler. The highest temperature occurs in a petrol engine at ~12.5:1, any richer and the temperature drops off, any leaner and the temperature drops off. This is why Some people run richer that 12.5:1 on forced induction, as the extra fuel does not produce any more torque but does cool the combustion temperatures down a little. If you tune your engine richer than 12.5:1 to keep it cool, there is something fundamentaly wrong with the 'design' of that engine, whether it be too much boost, too high a compression ratio, or lack of intercooling. The 'Oxidisiation' of a lean mixture is what damages your engine if it were to be lean enough and run at load. The excess oxygen at the high temperatures of combustion, oxidises the metals. High pressure High temperature of full throttle lean burn will erode (oxidise) the sofeter more vulnerable parts of your engine, if it doesnt detonate before hand. On 26th Oct, 2004 TurboDave16v said:
23rd Jun, 2009 at 02:50:20am
And don't forget that the AFR shown by a WBO2 sensor is the average of all cylinders so with the siamese ports what you see is not what you get.
23rd Jun, 2009 at 01:38:10pm
When my car runs lean it runs warmer, you sure you have that the right way around sprocket?? think you'll find that more fuel cools the engine not having less. Best 1/4 mile 13.2 seconds @116 mph
614 Posts Member #: 2153 Post Whore kings langley |
23rd Jun, 2009 at 02:17:18pm
miniwilliams what kind of figures do the skyline boys run then? how different are they to yours?
23rd Jun, 2009 at 05:38:49pm
On 23rd Jun, 2009 Miniwilliams said:
When my car runs lean it runs warmer, you sure you have that the right way around sprocket?? think you'll find that more fuel cools the engine not having less. Lean mixtures burn slower, therefore the relatively hot gasses are in the combustion chamber longer and the engine picks up more heat. It could also be down to ignition timing, considering lean mixtures burn Edit* slower would say that more advance is required, over advance can lead to pre ignition, and cylinder damage. Too little advance and EGT rises
23rd Jun, 2009 at 07:23:32pm
On 23rd Jun, 2009 supermotolee said:
miniwilliams what kind of figures do the skyline boys run then? how different are they to yours? lee if matt has seen the same skylines as me, most i have stuck a wideband on that are running decent(i.e. greater than a genuine 400hp@wheels) run low 10:1 AFR's. have even seen some dip into the 9's! (not my work btw!) sprocket, perhaps i have the wrong understanding of why it happens, but i know for sure that running richer than 12.5:1 is pretty good at suppressing detonation. always believed this was due to lower temperatures as i figured the burn would be most efficient (i.e. hottest) at stoic. and fall either side. much like your egt graph. Edited by evolotion on 23rd Jun, 2009. turbo 16v k-series 11.9@118.9 :)
24th Jun, 2009 at 10:17:48am
There is no need to run a skyline down that rich at all....
AlexF |
24th Jun, 2009 at 10:25:32am
sprocket is right - highest combustion temp is obviously going to be highest at the point of maxium power - thats when the most energy is being converted.
AlexF |
24th Jun, 2009 at 12:31:21pm
Just to throw a spaner in to the works how does representative altitude affect AFR? Own the day
24th Jun, 2009 at 12:32:53pm
If you are running a decent ECU with a MAP sensor then it won't affect it at all if the compensation table it set right.
24th Jun, 2009 at 12:47:46pm
So a barometric form of control would be required. Own the day
24th Jun, 2009 at 12:51:26pm
On 24th Jun, 2009 Tom Fenton said:
If you are running a decent ECU with a MAP sensor then it won't affect it at all if the compensation table it set right. On a carb it will basically overfuel at high altitude as there is less oxygen in the atmosphere. not the other way around? With a carb lower atmospheric pressure the carb has less of a pressure drop so dishes out less fuel, and as the exhaust is venting to a lower pressure it scavenges better ( like fitting a fee er flowing exhaust, net result is lean? turbo 16v k-series 11.9@118.9 :)
24th Jun, 2009 at 01:18:07pm
I take back my last statement. Due to how the SU works I am of the thinking it wont over fuel that much so extra control may not be required. Own the day
24th Jun, 2009 at 09:25:25pm
finding this one hard to work out, i've always been told that leaning off the mixture makes heat, so you say "Lean is not hotter, it is cooler" and then you say "Lean mixtures burn slower, therefore the relatively hot gasses are in the combustion chamber longer and the engine picks up more heat" why does it pick up more heat if lean is cooler?
24th Jun, 2009 at 11:44:06pm
Compairing a mini and a skyline is always gonna throw up differences - the way the flame front moves in a modern design head is so different to what happens in a mini.
AlexF |
