| Home > Companies to Avoid > F'n Hammerite | |||||||
29th Jul, 2009 at 12:33:16am
Bought a Tin of this agents my better judgment from my local auto factor. I wanted a brush on type hard paint for the inside floor of the racer. The guy (in his forties taught heed know what he was on about !how wrong was I) told me this was the only stuff for the job and Id never look back.
Edited by PaulH on 29th Jul, 2009. On 17th Feb, 2009 Rob H said:
29th Jul, 2009 at 08:27:48am
Your black paint has gone see through? Are you sure it is just not a gloss finish and you are looking at reflection?
http://www.twin-turbo.co.uk
29th Jul, 2009 at 08:55:22am
I'm not a big fan of hammerite I have to say.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
29th Jul, 2009 at 09:11:44am
i've used it on subframes, floors etc etc and never had a problem with it. did you use it straight out of the tin of mix it with something? |
29th Jul, 2009 at 09:35:18am
I painted my back subframe with hamerite with no prob's. On 11th Feb, 2015 robert said:
29th Jul, 2009 at 09:58:34am
Its usually quick and easy to use because it goes over everything and is recognised as a bodge job because of this. It also chips very easily. |
29th Jul, 2009 at 10:29:18am
Ill get pic later today. I wont lie to you guys I’m no painter just need something to do the job and this didn’t I followed to Instructions on tin and tbh the results are appalling the coverage was crap half a brush stroke and I had to re load the brush. It stunk and is still not dry nearly 12 hours later :( On 17th Feb, 2009 Rob H said:
29th Jul, 2009 at 10:48:55am
Do you have any of the original sound deadening bitumen stuff left on the floor ??? I would assume not if it's a racer but if there is any still there, or even any residue left, the solvent in the hammerite will react with it. Schrödinger's cat - so which one am I ??? |
29th Jul, 2009 at 11:04:36am
nope Rod I chiped all that off and sanded to floor back to metal then coated it in Hammerite "special" under coat and then a top coat of smooth hammerite black. On 17th Feb, 2009 Rob H said:
29th Jul, 2009 at 01:05:02pm
That is interesting I have never seen hammerite undercote. The secret with hammerite is to put it on thick and directly onto metal. http://www.twin-turbo.co.uk
29th Jul, 2009 at 01:15:02pm
this is it Ben the guy I baught the paint off said I need this or the paint would not take :(
29th Jul, 2009 at 01:19:10pm
"Promotes adhesion for metal finish paints on non-rusting metal surfaces such as aluminium, galvanized and stainless steel, chrome, brass and copper. "
29th Jul, 2009 at 01:29:06pm
That would not be a very good show if the paint reacts with its own primer ! On 17th Feb, 2009 Rob H said:
29th Jul, 2009 at 01:32:59pm
I meant the primer not setting as it should as it's not on the metal it was inteded to be used on, then reacting with the paint On 11th Feb, 2015 robert said:
29th Jul, 2009 at 01:38:09pm
TBH AP I have no idea what I do know is I painted the engine with dulux metal primer then one coat of dulux smooth black, It looks prfect I used half the paint and it was dry in 6 hours:) On 17th Feb, 2009 Rob H said:
29th Jul, 2009 at 06:39:23pm
I've always just rubbed the metal down for it to key too, never any under coat or primer. On 19th Jan, 2010 wil_h said:
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
29th Jul, 2009 at 06:54:06pm
I painted the whole inside of my mini with hammerite - worked really well imho.
549 Posts Member #: 5327 Post Whore Dudley, West mids |
29th Jul, 2009 at 08:48:02pm
I've had this problem before. I think that the tin I brought was either really old or not mixed correctly at manufacture. Use a chop stick and give it a really good stirring. I found that good paint had settled to the bottom of the tin. |
29th Jul, 2009 at 08:54:16pm
Hammerite normally needs a really good stir before use, as it is normally like treacle at the bottom of the tin and like water near the top. |
29th Jul, 2009 at 10:51:36pm
yeah, a ood shake/stir lways helps, but tbh i cant stand hammerite ither
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
30th Jul, 2009 at 10:29:43am
i use hammerite on load of stuff, its brilliant, i have had exactly the problem you talk about but only on nice new shiny metal which is where the undercoat comes into play.
30th Jul, 2009 at 11:30:16am
Hammerite sticks best to poor surfaces on a good surface it can be a bit of a pain.
Own the day
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
30th Jul, 2009 at 11:42:04am
On 30th Jul, 2009 Mr Joshua said:
I paint my bollocks with it never had an issue (red of course). Careful with that........ On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
30th Jul, 2009 at 01:14:43pm
On 29th Jul, 2009 tadge44 said:
Its usually quick and easy to use because it goes over everything and is recognised as a bodge job because of this. It also chips very easily. Found that myself. Looks fine when freshly done...but never seems to stay on very long. I painted my rear axle with it.,..after it was shotblasted so totally clean bare metal. And it still chipped off easily. 9.85 @ 145mph
203 Posts Member #: 1734 Senior Member Lancaster |
2nd Aug, 2009 at 12:16:03pm
A mate of mine many moons ago building a marlin kit car taught me a trick with hammerite.
