| Home > Help Needed / General Tech Chat > Engine Questions | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
26th Aug, 2009 at 03:46:46pm
Hi
26th Aug, 2009 at 05:00:54pm
go for the minispares ultralight flywheel and back plate. then have the whole rotating assembley ballanced.
26th Aug, 2009 at 06:55:33pm
O.k.
Edited by jonb_5 on 26th Aug, 2009. |
27th Aug, 2009 at 09:18:38am
Are you planning on any upgrades in the near future? If so it might be worth considering changing to a pre verto setup and doing as Benross suggested. |
27th Aug, 2009 at 09:31:42am
Hi
27th Aug, 2009 at 09:43:47am
Look at C-AEG421, a lot of the weight is in the actual clutch though. Prob 90% of people on here use a pre verto setup as it is lighter and there is a wider range of diaphragms and clutch plates available i.e you can build a setup to cope with more power. |
27th Aug, 2009 at 10:03:54am
A lot of people seem to be going down the RTS inspired clutch route nowadays. If something is worth doing, it's worth doing half of. |
27th Aug, 2009 at 10:18:09am
Lol i was waiting for someone to say that, now you've confused matters :) |
27th Aug, 2009 at 12:14:24pm
Hi
27th Aug, 2009 at 12:22:26pm
MED do a lightweight verto, On 28th Aug, 2011 Kean said:
27th Aug, 2009 at 01:11:49pm
Verto and a 296 camshaft is stupid. Too heavy. If you're going to fit a 296 you need to go the entire mile. I guess you've lready got decent pistons, high CR, good head and a 45DCOE?? On 13th Jul, 2012 Ben H said:
27th Aug, 2009 at 07:05:32pm
Hi
27th Aug, 2009 at 08:15:11pm
If running a Hif44 because of body mods, then run a different cam. Unless you only do it to impress the friends at the pub. On 13th Jul, 2012 Ben H said:
27th Aug, 2009 at 09:28:49pm
Yeah - I often go to the pub and tell everyone what cam I have!
27th Aug, 2009 at 10:23:04pm
The 296 and SW5 are MIIIIILES apart. The SW5 delivers all the goods before 5000rpm, whereas the 296 delivers NO goods until after 4500rpm.
28th Aug, 2009 at 08:34:13am
Hi.
28th Aug, 2009 at 08:53:39am
I feel that a 286 is borderline for a road engine. To gain the best of this cam, you'll still need a Close Ratio gearbox and so on,a nd also a light flywheel.
28th Aug, 2009 at 09:13:53am
I had a 286 in a road car, looking back it was shite, would not take full throttle below 2500rpm, would not idle.
28th Aug, 2009 at 09:56:01am
My personal N/A road cam choices are in no particular order:-
28th Aug, 2009 at 11:48:44am
Hi
28th Aug, 2009 at 11:55:07am
or something like this?
28th Aug, 2009 at 11:57:44am
Written by yours truly http://minispares.com/Articles.aspx?ty=ad&aid=571
Edited by t3gav on 28th Aug, 2009. |
28th Aug, 2009 at 12:44:27pm
On 28th Aug, 2009 jonb_5 said:
or something like this? http://www.med-engineering.co.uk/product_d...97&vlang_id=540 Thanks Jon This is much easier than buying the bits one and one. This is the expensive option: http://www.swiftune.com/Product/678/swiftu...e-assembly.aspx On 13th Jul, 2012 Ben H said:
28th Aug, 2009 at 01:10:58pm
Think the swiftune option may be a little over my budget. Will go for MED setup as its no more expensive than buying each part from minispares and its balances already.
30th Aug, 2009 at 07:11:39pm
just to confuse you jst a little more i have a vp3c cam, this come's in arund 1500 and finishes around 7200, gives me 87bhp at wheels and 107 at fly good torque, if you have a look at my previous topics i think the rr graph is on there showing the torque.
