Home > Help Needed / General Tech Chat > erm, help, turbo to manifold
Simon
Member #: 1865
Norwich, Norfolk
metro manifold, T3 turbo, there i was all excited about fitting my new turbo to the manifold and it doesnt fit!!??
any thoughts?
Edited by Simon on 28th Aug, 2009.
If its really tight you could open up the holes on the turbo? Not the nicest thing to have to do to a new turbo but may only need 0.5mm each hole.
Have you tried tapping it on with a copper mallet?
Nick
Member #: 154
Midlands
rotate the compressor housing if its hitting the manifold.
as above, just loosen the bolts ont he compressor hosing and spin it around a bit
Lol didn't even notice that! *hehe!* As above ^^^
Dont worry
I was looking at the inlet of the compressor housing wondering what the hell that flange was from.
It wasnt until I read your post that i realised it was already on the manifold
Simon
Member #: 1865
Norwich, Norfolk
is that these ones?
yep,
just slacken them a bit
retroracer1380
Member #: 1972
Worcester
It all looks a bit wrong to me! The oil return on the turbo core is facing up too! I think it all needs rotating
Double check the angle of the core (the bit in the middle with oil feed and return) to BOTH the turbine section and the compressor.
The clamp bolts can be loosened at both ends and both sections rotated to get the alignment right.
From the photos, it looks like this one has been assembled all wrong for a Metro/Mini, was it intended for something else ???
EDIT - be aware that when you rotate the turbine or compressor end, the length of the wastegate actuator rod will change, so will need adjusting
Edited by Rod S on 28th Aug, 2009.
Simon
Member #: 1865
Norwich, Norfolk
thats not the oil retun, thats the oil feed, oil return is underneath with the square hole....
retroracer1380
Member #: 1972
Worcester
Ah good point, im getting confused with t2 cores!
Simon
Member #: 1865
Norwich, Norfolk
phew, dont worry me like that, enough to worry about just the fact it needs a slight adjustment!
Simon
Member #: 1865
Norwich, Norfolk
cheers guys, fits like a glove now :)
Nick
Member #: 154
Midlands
is that exhaust wrap with the stuff you spray on afterwards?
I've got some black stuff for me manifold this time round as the white stuff i had before was itchy and horrible and fell to pieces.
Simon
Member #: 1865
Norwich, Norfolk
Itchy? What were you wrapping with it? *oh well*
But yes this is the white stuff, I got what I am told was the best stuff from DEI and then sprayed the lot with their black HT Silicone paint. Painting it is a lot better than just using bare wrap.
http://www.designengineering.com/products.asp?m=sp&pid=9
Edited by Simon on 29th Aug, 2009.
longy
Member #: 2727
Bicester
looks great, how much wrap did you use and what width ?
1972 998 TURBO SLEEPER
Carl
Member #: 95
liverpool-on-sea
i thought you were selling your project?
Simon
Member #: 1865
Norwich, Norfolk
I used the 1" wide stuff, dont know how much but it was a lot more than you would think. The paint is amazing stuff, just makes it totally waterproof which in turn means no oil or grease can get on it either.
I was but no one bought it, I'm not going to leave it just festering so I'll carry on with it, if I end up selling it then it'll be more complete and more sellable.
Simon
Member #: 1865
Norwich, Norfolk
do i need some locktabs for the nuts holding the turbo to manifold? if so where can i get them from?
to stop the iche soak the wrap first before you stick it on
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
i think these are just wired!
are there holes in the studs?
The two I took a apart recently had both locktabs and lockwire, however, the new studs I bought aren't drilled for the lockwire so I'll just use the locktabs.
I haven't been able to find a source for new ones so will be using the originals (with a lot of care).
You could use self locking K Nuts.
longy
Member #: 2727
Bicester
where did you get the new studs from Rod?
