Home > Help Needed / General Tech Chat > best braking set up
johnbee
Member #: 7327
morecambe/ belfast
does anyone know the best braking set up when running 13"s. i was looking at the KAD 6 pot caliper kit and the tarox 6 pot kit. does anyone know which is best or if there are any better ones out there?
What are you trying to stop? road/race/track day?
I've never used anything more than an alloy 4-pot. Never felt lacking when in good condition.
johnbee
Member #: 7327
morecambe/ belfast
im using the car for hillclimbing/trackdays but its still road legal. the KAD caliper apparently doesnt come with a dust cover or something so it requires regular cleaning. what make is the set up you use?
rosco454
Member #: 5222
Northumberland
Im sure this came up in a topic last week and apparently they do now make 6 pots with dust covers.
i know that their A&B typ calipers were un sealed, but the larger ones (non mini fitting) were sealed.
i ditched my kad 6 pots for sealed wilwoods with massive pistons, and 10.25" discs, cost less than the Kads too. the work really well, feels like a modern servo'd car.
there are pics in the links below.
The best brakes i ever had were a std cooper s setup with a std master cylinder
i have minispares 4 pots and pagid 40 groove discs its a cracking setup even bill sollis liked them
what pads wolfie?
1144's
1144's are good, thats what i have in the wilwoods, and on my S discs.
PaulH
Member #: 2340
Dublin Ireland
1144 are the best IMHO a savage price but worth the money I only use them now.
On 17th Feb, 2009 Rob H said:
nuukuus
Member #: 6857
Lieto / Finland
I have KAD's 10.4" big brake kit and they are good!! Not cheap but GOOD!!
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
http://www.garaget.org/?car=176816
Radleigh
Member #: 1643
West London
I had KAD 4 pots on mine, and loved them! never had any issues.
I've got Cooper S discs with Carbon Metallic pads.. They suffice..
IMO a lot to do with MC sizing and calliper choice. SO you get enough fluid without having to provide too much pressure.
Turbo Shed
Member #: 30
Epsom, Surrey
i'm with Vegard (he's normally right), cooper S discs and mini spares carbon metallic pads are spot on! and because i have girly leg muscles i also have a rover cooper servo. and with this set up you also get to use the much better 10" wheels!
if i was a chav and wanted big wheels then i'd probably have gone for standard metro vented discs and calipers
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
lol, ive got 7.9 vented mety 4 pots with greenstuff pads, thay are much more than up to the job and rarely get up to temperature, which is why im going for non vented 7.9s with alloy calipers next year.
6 pots are surposed to give you better pad stability (even wear) but to be honest i dont think thay do a huge amount more than a good 4 pot.
if your doing hillclimbing then you want the brakes to get up to temperature very fast so i recon a good non vented disk would be your best bet. *happy*
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
johnbee
Member #: 7327
morecambe/ belfast
thanks for the input guys. big help. i think i might be a chav and have a look at the 4 pot setups availiable. but im still tempted by the thought of 6 pots on a mini!!
I'm not a chav and I'm having metro vented 4 pots!
nuukuus
Member #: 6857
Lieto / Finland
No need for that. KAD's 10,4" big brake kit is powerfull enought.
But if you are looking better visual look....
Also KAD's look awesome..
Jani
chavs wear stripy white and blue jumpers and bomb around a camp site on the revlimiter at 2am then role the car over whilst sayin yea mate mint dis innit...
MONSTER HEDGEHOG
Member #: 4340
mety 4 pots are cheap, like the budgie.
£30 and an hour on the lathe at work aint bad *hehe!*
carl
MrTurbo
Member #: 814
Utrecht, The Netherlands
It has been said before, but just another warning. I've been using greenstuff pads with metty 4 pots and vented discs and lost all braking.. These pads are dangerous, if they get a little "too hot" (I think somewhere over 400 degrees which is not hot...), they just stop working, I'll never use them again.
1144's with 4 pots and vented discs never failed on me once! I use 1144 on a Cooper S 7.5 " and even on a Cooper 997 7" setup as well and they are they best for fast road and rally driving.
Scruffy
Member #: 328
Seaford Rise, South Australia
What is very dangerous with these big brakes is balljoint failure! You need to almost upgrade to the metro type or treat them as a consumable item.
Any of you who remember the Maguire type Blue Mini driven by Sollis pre 1994 FMITW race - it died a death in ireland due to this!
On 5th Sep, 2011 Vegard said:
carl talbot
Member #: 1323
I used KAD 4 pots on my hillclimb Lotus 7 , with the cheapest / crap pads I could get
for hillclimb you want the breaks to work at optimum from the first press of the pedal
If you need to wait for them to get up to temp you will have crossed the finish line !!
You will need different pads for track days
