| Home > General Chat > graphs from tm rr day | |||||||
30th Oct, 2009 at 06:44:05pm
before i put any up , i thought id ask , does anybody from the day have a problem with me sticking up some graphs from the day ? pm me if you do !:) Edited by robert on 30th Oct, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
30th Oct, 2009 at 07:02:09pm
No probs from me Robert.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
30th Oct, 2009 at 07:18:51pm
On 30th Oct, 2009 turbominivanman said:
No probs from me Robert. As the lowest powered 1275 car of the day, I'm proud of my graph, especially as it was bloody useful in visualising my fuzzy ignition issue between 4000-4500 rpm ! I'd welcome seeing the others. Richard. actually richard that was me , with a lame 8psi....lol On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
30th Oct, 2009 at 07:19:22pm
30th Oct, 2009 at 07:19:35pm
id say get em up... but what about the mag feature? maybe best waiting for matt? to see what he says?
Yes i moved to the darkside |
30th Oct, 2009 at 07:37:55pm
On 30th Oct, 2009 Brett said:
id say get em up... but what about the mag feature? maybe best waiting for matt? to see what he says? o/t Richard did you manage to track down your problems? On 2nd Oct, 2009 Vegard said:
30th Oct, 2009 at 07:54:17pm
ahh yeah ill still buy it lol Yes i moved to the darkside |
31st Oct, 2009 at 10:32:26pm
No Problem from me mate, i would just like to add though that my graph isn't a true reading as i had to keep the torque down due to the slippig clutch (this can be seen on the 3rd run, in the vidoes) But turning the bleed vavle opne slowerly with the revs as they climbed, sadly my timing wasn;t spot on so ending up with not full post at end power, but got and ok result.
1st Nov, 2009 at 11:52:50am
fine with me |
1st Nov, 2009 at 08:05:40pm
fine with me, you can see from my run how rich I was running and was losing power :( Also worked out my boost problem :) Team www.sheepspeed.com Racing
1st Nov, 2009 at 09:52:59pm
Fine by me, I know mine was down anyway. |
1st Nov, 2009 at 10:03:27pm
On 1st Nov, 2009 Jimster said:
fine with me, you can see from my run how rich I was running and was losing power :( Also worked out my boost problem :) Jim. I've managed to sort my Megasquirt problem over the weekend - trigger wheel had slipped 5 teeth. However, you're not gonna get away with saying something like that without us wanting to know more. LoL. We're now intrigued - how did you sort the boost problem ? Richard. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
2nd Nov, 2009 at 10:04:16am
When I was running 30psi I was running a 14psi spring in my wastegate. I wanted to run a lower boost than this at lydden hill, so changed the wategate spring to a 4psi spring. I forgot all about this but thinking about it trying to blead of 25psi of boost it quite a bit. So basically I need to change the spring or add a smaller restrictor in the boost pipe. Team www.sheepspeed.com Racing
2nd Nov, 2009 at 10:06:07am
also when Dave walker mapped the car we could only map it around 17 psi due to wheel spin on the rollers, so we kinda guest the boost enrichment after this point, it is to agressive hence me running 10:1 AFR Team www.sheepspeed.com Racing
2nd Nov, 2009 at 10:18:06am
Maybe you should take it somewhere with rollers like theres for some more mapping jim If something is worth doing, it's worth doing half of. |
2nd Nov, 2009 at 11:02:24am
yea maybe, but I don't think I'd see 300 without gas Team www.sheepspeed.com Racing
2nd Nov, 2009 at 11:24:54am
You may get very close though If something is worth doing, it's worth doing half of. |
2nd Nov, 2009 at 05:37:09pm
On 2nd Nov, 2009 Jimster said:
also when Dave walker mapped the car we could only map it around 17 psi due to wheel spin on the rollers, so we kinda guest the boost enrichment after this point, it is to agressive hence me running 10:1 AFR You know where you have to take the car to get it set up without worry of wheel spin
2nd Nov, 2009 at 05:49:13pm
also when Dave walker mapped the car we could only map it around 17 psi due to wheel spin on the rollers, so we kinda guest the boost enrichment after this point, it is to agressive hence me running 10:1 AFR You know where you have to take the car to get it set up without worry of wheel spin ![]() yeah - Northampton Mortorsport no wheel spin issues at all! |
2nd Nov, 2009 at 07:14:00pm
also when Dave walker mapped the car we could only map it around 17 psi due to wheel spin on the rollers, so we kinda guest the boost enrichment after this point, it is to agressive hence me running 10:1 AFR You know where you have to take the car to get it set up without worry of wheel spin ![]() yeah - Northampton Mortorsport no wheel spin issues at all! yeh but would that be true if Jim upped the boost? On 26th Oct, 2004 TurboDave16v said:
2nd Nov, 2009 at 07:16:24pm
im sure they had more powerful cars than ours on there at some point..
2nd Nov, 2009 at 07:25:14pm
Theres a place or places that you bolt the hubs direct to the dyno so no wheel spin at all.
2nd Nov, 2009 at 08:17:08pm
They had a front wheel drive 500+ car on rollers withOUT spin so i think Jim would be ok. I got 257 lb torque doing my best to keep the torque as low as possible and it didn't spin the wheels. Best 1/4 mile 13.2 seconds @116 mph
2nd Nov, 2009 at 09:12:08pm
Well Ok then:)
2nd Nov, 2009 at 09:14:47pm
http://www.youtube.com/watch?v=0yMd2n66uiQ...rom=PL&index=16 On 26th Oct, 2004 TurboDave16v said:
