| Home > Help Needed / General Tech Chat > Electric water pump | |||||||
8th Feb, 2010 at 10:21:34pm
Right , i must of looked through 5 differend threads on water pumps and flow rates and im completely confused.
8th Feb, 2010 at 10:27:10pm
Im using a Meziere pump (flow 80l/min or something like that) with chiquecento rad. I don't think these pump like restrictions so to be on the safe side I used a shuttle type thermostat. Been fine for 2 years now, and to be honest sometimes struggle to get it up to temp on cold days. lol https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Feb, 2010 at 10:32:00pm
Im using the same pump and my temps are usually around 70deg, sometimes cooler
8th Feb, 2010 at 10:40:22pm
what were the temps like with the side rad and no fan Nic? On 28th Aug, 2011 Kean said:
8th Feb, 2010 at 10:43:14pm
a lot higher!!
8th Feb, 2010 at 10:45:11pm
Interesting...
8th Feb, 2010 at 10:45:56pm
It used to run all the time tbh |
8th Feb, 2010 at 10:48:21pm
Do you both just run the pump or is there a contoler with them
8th Feb, 2010 at 10:48:53pm
Cheers Nic,
8th Feb, 2010 at 10:51:15pm
we're not running a controller
8th Feb, 2010 at 10:55:44pm
No worries joe, it just nice to see whats peolpes thaughts are in reality rather than practice.
8th Feb, 2010 at 11:19:00pm
Nic, matty , got a link to them , there seams to be loads in the states
8th Feb, 2010 at 11:21:49pm
thats were ours came from, jegs.com |
8th Feb, 2010 at 11:29:30pm
On 8th Feb, 2010 matty said:
Im using a Meziere pump (flow 80l/min or something like that) with chiquecento rad. I used a shuttle type thermostat. Been fine for 2 years now, and to be honest sometimes struggle to get it up to temp on cold days. lol Should be no problem now
8th Feb, 2010 at 11:38:00pm
Rick what map are you using? Is your ign too retarded? I made this mistake 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
9th Feb, 2010 at 03:03:04pm
Mine runs at 70 degrees most of the time, when mine was idling at 850rpm it would run all day at 80 degrees and no need for an electric fan. :) https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Feb, 2010 at 04:59:28pm
On 8th Feb, 2010 cossierick said:
Ive just put mine on a switch so the theory was fire the car up then two mins later flick the pump on and i could also leve it on after ive turned the engine off. Rick I'd really think twice about this. If you forget to turn on the pump then all of a sudden your engine is stinking hot and its trouble time. A well known member of this board, who shall remain nameless, did this once at Castle Combe, the result a knackered head gasket and a couple of bent valves as they nipped in the guides. The DON has an electric pump as you know, wired through the fuel pump relay, so that if the fuel pump is running, so is the water pump. Thus it cannot be forgotten about.
9th Feb, 2010 at 10:37:47pm
Point taken tom, it did cross my mind , il have to put it so i can overide it so it can be left on when the engine is off.
9th Feb, 2010 at 10:41:00pm
I have mine on a switch, it just becomes habit to switch it on now. And it somes in handy to cool the turbo/engine down after you switch it off to avoid heat soak etc.
Edited by matty on 9th Feb, 2010. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Feb, 2010 at 11:04:19pm
I have a handy button that I press and it turns on the fan and pump for 10mins, optional on shutdown
10th Feb, 2010 at 09:21:23am
Flash git! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
10th Feb, 2010 at 01:36:27pm
Sorry to thread hijack, but does anybody know if this pump would be suitable?
10th Feb, 2010 at 02:37:03pm
On 10th Feb, 2010 n.g.l. said:
Sorry to thread hijack, but does anybody know if this pump would be suitable? http://www.siliconeintakes.com/images/prod...-0392022002.pdf I believe the flow rate is about 20liters/min. David. that web page broke my adobe reader, just re installing it now :- Yes i moved to the darkside |
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
3rd May, 2012 at 07:49:00am
Going on from this does flow rate really effect it that much, is the ideal flow rate 80litres/min and what will happen if i fit lets just say a 120litres/min what will happen? will it not flow as well due to the coolant being flown to fast ? |
3rd May, 2012 at 02:59:53pm
i second that comment, i was going to buy the 115litres a min davies craig (alloy) pump WITH the controller? |
