Home > General Chat > whats the best enigine oil
nibble36
Member #: 4273
stoke on trent
hi all what the best engine oil use in my new built turbo
was thinking of useing this (VALVOLINE RACING VR1 20w-50 Mineral Motor Oil)
any other oil to look at
thanks nibble
Thats what I ran in the last engine, and after 5000 miles with high lift cam and rockers the cam still looks like new. I haven't stripped the rest of it down as I may use it again. It was ripped out for a 1380 engine.
I shouldn't think it not being turbo specific should be a problem, but then again there are much more qualified people than me who can answer this!
Edited by minimole23 on 17th Feb, 2010.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Yep mate.
I also use VR-1.
Damn fine brew and suits the box and turbo combo on the A/A+, a really good quality 20/50 IMO.
Richard.
t3gav
Member #: 229
Gavin@minispares.com
kent
Millers CTV also pretty good and semi too.
I've used both in the past, currently use Millers CTV, no signs of wear in my engine
clubminiflip
Member #: 54
nr coventry
i use cheap shitty MOTORWAY 20/50 at £3.20 for 4.5ltrs
change it every 1000miles & the filter every 3000miles
good oil pressures no metal bits on the magnet
why pay more???????
i'd like to see if there is a differance between my way & using a quality oil??? neglidgable
this is on a daily driver though, may be a differance on a car that heats the ooild super hot on track/drag strip!
Edited by clubminiflip on 17th Feb, 2010.
we ran cheap oil in the metro van with regular changes. One weekend at avon and the main bearings where finished. 70% of the bearing face was gone
why pay more???????
I suppose for the sake of x thousand pounds worth of engine and gearbox, 25 quid for a can of oil and a filter is not that higher price to ensure its lifeblood is good.
another vote for Millers CTV here,
clubminiflip
Member #: 54
nr coventry
even the cheapo crap is'nt past its best after 1000miles though, mine only gets a bit darker, as i say its on my daily 7 i change it every 1000mile without fail
maybe on my mini car i may push the boat out for some better lube!
maybe duckems-Q *surprised*D
good thread here chaps, interesting to know what ppl are using & get a clue of what works well!
metroturbo
Member #: 989
North Yorkshire
Shit oil is shit oil whether its in there for ten miles or a thousand. There a lot more to oil than the colour when you get rid.
After hearing on here about i think i now use Millers CTV 20w50,, there is a feature in minimag about it that i did coming soon, have a read it might help, and seems to be the only oil so far that i've tryed that keeps parts from wearing as fast as they did before using the CTV.
nibble36
Member #: 4273
stoke on trent
thanks for all the info guys ill read themag wen it out
millers seem to be the one
but i like the valvoline stuff 2
had a price for miller today from a local fators and he said £50 for 5lts i pissed my self laffing its only 29 in mini sport
lol
clubminiflip
Member #: 54
nr coventry
matt woods how many free cans of millers ctv did you get to promote 7 find good results
teeehhhheeee just kidding chap!
i may be able to get millers cheap i'll get back to you guys, keep you posted!
imo cheap oil finnished off my 998,
currently using coma classic at 16quid per gallon, im nursing a poorly gearbox atm and this stuff seems to help
big_pete
Member #: 8233
I'm using the comma stuff in my 998 too
TTFN Pete
Yes it's funny how other places can offer it cheaper then there own factory. I no mini spares were £35 i think a little while ago when i bought some there.
turbo hogster
Member #: 178
stowmaket suffolk
ctv for me all the way used valvoline to seems ok but millers is better for the box and layshaft plus the bearings
Ben H
Member #: 184
Melton Mowbray, Pie Country
On my daily (not a mini) I change the oil every 10,000 miles. using your method that would cost me £32.50. The oil I buy is not that expensive and I have more hours in my lift to surf for porn. If I changed the oil every 1000 miles I would be under the car every 3 to 4 weeks, sod that.
Although on the road mini I don't use great oil the racer get CTV.
http://www.twin-turbo.co.uk
where are people getting the vr1 from ?
lockfast
Member #: 2775
Aberdeen
anaother vote for Millers CTV. I have tried a good few others in the past and this one is defo the best I have used so far
Laurence
Member #: 8258
Yes Valvoline is probably very good for engines, but Millers has produced a very good oil for our engine/gearbox/differential combination which is now very 'old skool'.
Whatever oil you use it must be suitable for this combo plus it has to be a 'quality' oil due to the greater loads on crank bearings & possibly higher temperatures produced by the turbo.
You don't want the turbo oil feed pipes & galleries clogged-up by deposits from cheapo oils.
You gets what you pays for.
You could probably use some cheapo oil as an engine flush rather than using flushing oil (which wrecks the engine) & then put Millers oil in again along with a new filter.
A mod to the oil filter housing should be always carried out, the by-pass valve should be brazed over to prevent unfiltered oil reaching the engine. The by-pass valve is held shut by a spring which isn't very scientific ie the valve could open at random.
Any deposits on the valve could stop it from seating & so be held open permanently so the oil will never be filtered *surprised* *surprised*
graemec
Member #: 1424
Carnforth, Lancs
I've found that CTV gives lower pressures when it gets really hot - probably not noticed on short thrashes like drag and hillclimb but certainly evident when rallying. VR-1 is supposed to be better for that.
I'm currently using Castrol-R - good for gearbox but a compromise for the engine. But by God does it smell good!!!!
Metro Mandy
Member #: 7724
West Midlands
I use Magnatec in my Metro GTi. Not used it in an A series yet but did notice a difference in the K series. Engine seemed to rev more freely.
Suck, squeeze, bang, blow........
Jackman
Member #: 984
Westhoughton, Bolton
Im doing a bit of a bump on this.
I normally use Castrol GTX 10w40 mineral in my mini, however trying to get some today ive been told its obsolete and you can only get the magnatec stuff.
What other good alternatives are there that wont cost an arm and a leg, currently using the halfrauds own brand.
Manchester Minis
