| Home > Help Needed / General Tech Chat > Opinions needed on this weld? | |||||||
2nd Apr, 2010 at 09:14:54pm
Here's a pic of my cylinder head. Jus tafter some feedback if this welding is shite or not? And what has been done wrong? You can also see the 'crack' that my welder said is making the head unrepairable.
2nd Apr, 2010 at 09:39:19pm
just mailed this to you matt nut ill stick it on here too
2nd Apr, 2010 at 09:45:18pm
Ah cool, hopefully I'll be able to make it over, it would probably be the afternoon though? When is Ian about?
![]() 611 Posts Member #: 5222 Post Whore Northumberland |
2nd Apr, 2010 at 09:47:34pm
Just to echo what robert said about possibly being done with a mig,if thats tig then its very sloppy.I know appearance isnt everything but still a decent welder using a tig set should be welding a lot cleaner than that in my eyes.
Edited by rosco454 on 2nd Apr, 2010. On 20th Jan, 2011 apbellamy said:
I have a bit of a fetish for tools |
2nd Apr, 2010 at 09:48:38pm
I dosen't look a great weld to me, looks like something i would produce lol.
157 Posts Member #: 6496 Advanced Member Somerset |
2nd Apr, 2010 at 09:49:54pm
With regards to the crack, if you don't grind out ALL of the crack, it will keep coming back. You can't just weld over it, you need to dig it completely out. On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair |
2nd Apr, 2010 at 09:57:24pm
Rosco - Apparently the head is cracked (the faint line that runs from the weld to the chamber) but I thought I caused that when I was cleaning the swarf off it...Doh! The welder said as he welds "the crack opens up to about a 1mm and runs to the valve seat".
Edited by matty on 2nd Apr, 2010. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
2nd Apr, 2010 at 10:01:42pm
Owen - He did say the same thing, to sort the crack out he'd have to remove the valve seat, mill a 4mm slot over the crack to dig it right out then fill it with weld. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
112 Posts Member #: 7030 Advanced Member Bucks |
2nd Apr, 2010 at 10:45:35pm
@matty Didn't your problems with this head start with frozen coolant during the winter time and might that not have caused these cracks? |
2nd Apr, 2010 at 11:00:24pm
sorry matty it doesnt help I know, but that I cannot see
To be fair to him, he's welded lots of things for me before without any problems but not sure if its the cast material causing the issue or maybe the technique. TBH Matty, I remember you having problems with coolant leaks right at the begining from porous welds. If this the same bloke? My machinist is niot exactly the best ally welder there is, and all his welds tend to be big fat ones, which for what he uses it for, it doesnt really matter. He uses it mainly to repair ally head castings, for example, a failed head gasket which has erroded the head face between two cylinders. Two K heads done and so far no leaks, so I doubt very much its the head casting, my man says that it actualy welds really well. Edited by Sprocket on 2nd Apr, 2010. On 26th Oct, 2004 TurboDave16v said:
2nd Apr, 2010 at 11:10:26pm
if the crack runs to the valve seat i think you should start looknig for another head as you'll just chase the flaw right around the casting,
3rd Apr, 2010 at 06:38:33am
It has cracked because there is not enough heat gone into it, which is very difficult since its such a large casting, then it has cooled too quickly and cracked again. You need to pre heat the casting - weld it with a silicon or manganese rod then let it cool very slowly in hot water.
I seriously doubt it! |
3rd Apr, 2010 at 07:41:13am
Ah cool, hopefully I'll be able to make it over, it would probably be the afternoon though? When is Ian about? It was definitely done with a tig, as thats the only welder he has. Did he give an explanation of why the wleds might be cracking? hes about in the afternoon matt . he has silicone and mag rods ,but none of the very expensive hard rods for high magnesium aly castings , so he'd need to have a look . woodcote is about 7 miles this side of reading . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3rd Apr, 2010 at 08:26:57am
To be fair to him, he's welded lots of things for me before without any problems but not sure if its the cast material causing the issue or maybe the technique. TBH Matty, I remember you having problems with coolant leaks right at the begining from porous welds. If this the same bloke? That crack is supposed to be the faint line between the weld and the chamber, but as faras I can see its just a light scratch...thats my point I think he's talking out of his arse because he fucked the welding up.
Robert- Im fine to come over today will probbly be about 3ish though, if thats ok with you? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
3rd Apr, 2010 at 08:40:45am
Do you know if it has been preheated before the welding takes place and what process is he using post weld to keep heat in the whole job?That might go some way as to why the welds are cracking.
3rd Apr, 2010 at 08:55:33am
yes thats ok matt , if you can make it earlier do, i want be back for 5 ish .
3rd Apr, 2010 at 09:10:17am
He's not been preheating it, which sounds like why its cracking then. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
3rd Apr, 2010 at 09:03:37pm
Too long out of this forum,
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
3rd Apr, 2010 at 10:12:08pm
After reading this, i went and checked mine out as i haven't looked at it after it was welded up, and a couple of mine have minute cracks in the welds.
3rd Apr, 2010 at 11:09:03pm
Any decent engine shop should be able to pressure test it for you On 26th Oct, 2004 TurboDave16v said:
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
4th Apr, 2010 at 08:54:03am
We have big problems with our magnesium castings and they need to have the crack ground right out, we normally drill them at both ends, then melt the bottom of the crack together without filler rod, then build it up. They need to be f-ing hot though. |
9th Apr, 2010 at 08:21:14pm
Well Ive had robert mate have a look at it, and he rewelded it up for me. There are still a few pin holes but the solid part of the gasket cover these. I think im going to run some ceramic sealant through just to make sure though.
9th Apr, 2010 at 10:10:50pm
Totally agree with drilling a hole each end of the crack, similiar method to glass and other ceramics. Stops the crack spreading. Something like that you would need to pre-heat also.
On 4th Apr, 2010 antman said:
We have big problems with our magnesium castings and they need to have the crack ground right out, we normally drill them at both ends, then melt the bottom of the crack together without filler rod, then build it up. They need to be f-ing hot though. Edited by Jason G on 9th Apr, 2010. On 19th Jan, 2010 wil_h said:
9th Apr, 2010 at 10:16:31pm
That's great news Matt
9th Apr, 2010 at 10:18:30pm
I cant stop thinking about the comment of the crack opening up as it gets hot, lol, aluminium expands a great deal when it gets hot, so if anything a localised hot spot while welding in a large casting like that, if anything, the crack should close up, but we all know why the crack didnt open up anyway.
