| Home > General Chat > well this is a big F*U$K up! | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
8th Sep, 2010 at 01:54:06pm
thought ill get my gears cryo treated & shot peened.
Edited by NickG on 8th Sep, 2010. |
8th Sep, 2010 at 01:58:10pm
Oh Poop! If something is worth doing, it's worth doing half of. |
8th Sep, 2010 at 02:00:11pm
yes John Inded :( i was really hoping i would do this amazing thing & everyone would be!
8th Sep, 2010 at 02:15:16pm
On 8th Sep, 2010 NickG said:
yes John Inded :( i was really hoping i would do this amazing thing & everyone would be! wow it has really helped nick is doing blah blah no problems Don't get down- I'm still impressed by your neighbours link!!! Its such a shame that its such an expensive error. Is it possible to get the syncros recoated? I've wondered this as I have 2 JK gears with crap coatings Where did the harness come from? |
8th Sep, 2010 at 02:20:30pm
Was it SD mini's? If something is worth doing, it's worth doing half of. |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
8th Sep, 2010 at 02:37:11pm
Can't they be re-coated? |
8th Sep, 2010 at 02:43:22pm
Shot peening is not shot blasting so why did it remove the coating ???
8th Sep, 2010 at 02:44:46pm
ROD S
8th Sep, 2010 at 03:01:30pm
The Moly coating got there somehow in the first place, there must be a way of putting it back again.
969 Posts Member #: 47 Post Whore Not very sunny swanage |
8th Sep, 2010 at 08:27:56pm
On 8th Sep, 2010 Tom Fenton said:
The Moly coating got there somehow in the first place, there must be a way of putting it back again. it did and there is. The link explains it pretty well, Its what i do for a living!! Well, that and a whole load of other stuff a bit more high tech! Syncro cones ares still done exactly the same way, with exactly the same kit!! And on the 7th day........... God created turbochargers! |
8th Sep, 2010 at 08:48:09pm
Can you strip and coat some gears for me?? |
9th Sep, 2010 at 12:29:02am
The Moly coating got there somehow in the first place, there must be a way of putting it back again. yes. the problem is they all want 250au per gear. when i can get a set of gears for say 400au to 500au. they can't guarantee it will work either. i would be interested if you can get it done in the uk. are the gears re made or just old stock from Rover? |
9th Sep, 2010 at 12:31:11am
yes John Inded :( i was really hoping i would do this amazing thing & everyone would be! wow it has really helped nick is doing blah blah no problems Don't get down- I'm still impressed by your neighbours link!!! Its such a shame that its such an expensive error. Is it possible to get the syncros recoated? I've wondered this as I have 2 JK gears with crap coatings Where did the harness come from? lol thanks Nic. not sure if i can get the gears coated it's my every day car & im pretty much fucked. this has gone from a 3 week thing to 6 weeks & now god knows. |
9th Sep, 2010 at 10:29:56am
The shot peening I was involved in was done with glass beads, thse were likike micro marlbes and were a one shot use.applied useing a water jet. the surface was baby bottom smooth but a little duller and thats on aluminium alloy components, steel and other exotic patrs so ifit roughed the surface he has used the wrong media to do the process! Own the day
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
9th Sep, 2010 at 11:33:40am
Queensland metal spraying has done it for us in the past, many times, & they`ve all been good,,,still in the cars & still going well from years of service in fact www.miniman.com.au
9th Sep, 2010 at 11:48:20am
i feel for you and agree it is annoying and very very frustrating and is something that we here time and time again. there are a few reliable companies and people out there, i think we are lucky to have TM who can provide good advice and recommend reliable companies and people. |
9th Sep, 2010 at 02:22:37pm
Well new gears on the way!
9th Sep, 2010 at 04:08:15pm
what spec did he shot peen them to??? there is no way shot peening gears at the correct intensity would strip the moly off?
9th Sep, 2010 at 04:40:38pm
Is it possible the cryo treatment destroyed the moly bond ???
9th Sep, 2010 at 04:41:42pm
Nic, it can be done, but doing a couple off would be hideously expensive, (like more than a new gear sort of expensive). On the other hand if you're not in a rush then i might be able to chuck them on the back of the next lot we do? no idea when that will be though?! And on the 7th day........... God created turbochargers! |
9th Sep, 2010 at 04:47:31pm
On 9th Sep, 2010 Rod S said:
Is it possible the cryo treatment destroyed the moly bond ??? Even so, it doesn't answer why the moly cone surfaces weren't protected during the shot peening of the gear teeth..... possibly, im not sure how the cyro treatment works..... i think it relatively unlikley though, the moly bond onto the base material is a physical bond rather than anything else, unless something in the cyro actually breaks down the moly??? like i say, not too sure!! And yes, for sure the surfaces should have been masked, that said imho with the correct shot and the correct intensity even unmasked, the moly would stay there....... it sounding more like the guy has shot blasted them than peened them?!?! And on the 7th day........... God created turbochargers! |
9th Sep, 2010 at 05:08:18pm
On 9th Sep, 2010 nutter driver said:
it sounding more like the guy has shot blasted them than peened them?!?! That was my thought earlier in the post. But if you destroy one (it must have been obvious) would you carry on and destroy the other three ??? Schrödinger's cat - so which one am I ??? |
![]() 558 Posts Member #: 8143 Post Whore London |
9th Sep, 2010 at 05:15:00pm
Was the Megajolt harness from SD Minis? |
857 Posts Member #: 1778 Post Whore Northants |
9th Sep, 2010 at 05:40:23pm
it sounding more like the guy has shot blasted them than peened them?!?! But if you destroy one (it must have been obvious) would you carry on and destroy the other three ??? Possibly because if he only did one then the blame would point straight at him
9th Sep, 2010 at 06:41:21pm
he is a metalurgest, does loads of race stuff as well, he does know his stuff.
Edited by NickG on 9th Sep, 2010. |
