Home > Paul S trials and testing > Yet Another Rolling Road Log
Plots from the RR sessions at Smart Performance yesterday:
The RR printout:
Odd behavour on the third run, so we aborted. It is not clear at this moment in time if these are flywheel or wheel powers as we did not complete the coast down run.
Run 1:
Hit the rev limiter hard and a nive big bang out of the exhaust *happy*
A little bit of AE spiking to sort out.
Run 2:
Looks OK
Run 3:
Nothing untoward except that the boost did not build as quick, but note how the revs rise twice as fast. I think that Chris must have halved the resistance on that run.
I've plotted the flywheel power, based on the assumption that the above are wheel powers and we are getting the target 120hp. I'll wait for the confirmation before posting the new curves.
Funnily enough Paul, Garry had something similar on one of his runs, inexplicably he couldn't get the motor to make boost, as if it wasn't loaded enough.
I thought I'd forgotten to tighten a clamp in the rush to put it back together, but it was fine on the road both there and back.
Robert mentioned something about the resistance/speed of the rollers affecting boost?
I must say although from a couple of cars, mine included, the numbers seemed credible, it did seem to be quite a low resistance and hence high acceleration rate that was being used for the sweep tests.
The T2 does take time to spool up, so if I'm pushing it in 1st, then I will not see boost until 5000 rpm. By the time I get to top gear it is usually all in by 4000rpm.
Well, Chris has confirmed that we did not do the coast down run, so here is the flywheel power curve using the losses from the NMS rolling road. I think that we should take the Run 3 data with a pinch of salt for now.
*happy**happy**happy**happy**happy*
It also at 11.6 psi boost, so I'm well pleased.
good stuff!
That torque curves not very flat though is it! *tongue*
sturgeo
Member #: 1778
Northants
That could still be down to running too rich. Looking at the datalogs from last years RR days (flatish torque curve) we were running leaner and steadier afr's. Since we've fitted the new FPR we need to do a little more fine tuning.
Ha ha,
I'm just the same as everyone else now. As Sturgeo says, some of it could be due to the fueling settings, but I'm more inclined to think that the crap FPR was not working right on last years runs.
I notice afr2 stays pretty flat and afr 1 goes slighty richer at the top end
Yes, but the main thing is that we are getting enough fuel into the outer cylinders (AFR2 - red trace). That's the holy grail in siamese code terms.
We should be able to lean out the inners (AFR - green trace)by reducing the VE and knocking a bit of the injection timing.
We were in half a mind to sort that out yesterday, but things didn't go our way.
Edited by Paul S on 3rd Oct, 2010.
ah so afr 2 is the outers then?
I hope so.
LOL
well its certainly doing the do!
Well, it seems to be doing incredably well.
I've just calculated the SOT figure and fell of my chair.
Must wait until our psycho-analyst has sorted out the unsmoothed numbers before publishing.
paul ,can you do an overlay of your previous best power graph from nm ?
Yes.
The only change has been the FPR. It certainly feels a lot quicker with the new FPR.
I've had to reduce the fueling map at boost quite a bit with the new regulator which makes think that the old one was not correctly referencing boost. That would have also affected the atomisation due to a low rail pressure.
blimey that was quick ! now can you do a boost overlay for the two runs ?
It's a good job that I've got staff to do the work for me these days :)
This makes me even mor sceptical on my torque figures of 140ftlb. I'll stick my graph up later.
Boost data added.
This is taken from the MS logs as it was not available elsewhere.
Spooling at a different rate, but the NMS RR did have a lot more resistance.
Let me know when you are ready for the SOT curve!
Edited by Paul S on 4th Oct, 2010.
sturgeo
Member #: 1778
Northants
Do you want MAT's and AFR's as well Robert?
Don't encourage him.
Before you ask, MATs were actually within about 2 to 3 degrees on those two runs. Average AFRs were very similar.
Not sure why we did not get higher torque at the lower end of the rev range at NMS, but it's the bit between 4500 to 6000 rpm that I'm interested in.
01smartc
Member #: 2563
Tamworth
Just a note about our rollers that might help you.
The power runs are done via an inertia test. I.e. no load was applied to the rollers. The resistance is just the rollers weight.
So the load was definitely not changed from one run to the other.
Maybe the engines revved up to quickly to produce the best boost?
Chris
Thanks Chris.
Here are the two MV logs from NMS and Run 2:
NMS - 112hp run
SP - Run 2
