| Home > General Chat > What should I do? | |||||||
![]() 338 Posts Member #: 1911 Senior Member Swindon |
18th Oct, 2010 at 09:34:09pm
In an argument with my dad at the moment as he has this vendetta against 1380's. He thinks that turboing mine with get me about 10 miles down the road and blow it between the Walls of 2 and 3. He thinks I'm better off selling the block and pistons and cam well basically what I won't be using when I go to turbo and doing a 1293.
18th Oct, 2010 at 09:36:20pm
No reason not to turbo the 1380 unless the dish in the pistons is tiny.
18th Oct, 2010 at 09:37:14pm
1380! If something is worth doing, it's worth doing half of. |
18th Oct, 2010 at 09:37:39pm
Theres quite a few running 1380 turbo now and no problems whatsoever, none any different to any 1293 that i can think of.
18th Oct, 2010 at 09:39:04pm
BTW,
18th Oct, 2010 at 09:48:10pm
turbo the 1380 steve and haggy have 1380's iirc and both are fast and reliable Crystal Sound Audio said:
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
18th Oct, 2010 at 10:17:57pm
1380!
18th Oct, 2010 at 11:03:36pm
Thanks guys. Put the confidence back in me :) |
50 Posts Member #: 9008 Advanced Member Lancashire |
18th Oct, 2010 at 11:20:24pm
Bollocks, 1380's are great for quoting big numbers in the pub by kids with big egoes. Listen up, with age comes wisdom, 1293 is a tougher setup with less chance of failure. Its worth spending a little more now than a lot later! Take your dads advice |
19th Oct, 2010 at 12:13:18am
See always one. Ok please explain why's that you agree with my dad? Is it just because of the meet left between 2-3?
19th Oct, 2010 at 01:36:49am
OK, take any random component, say a rod or piston or bearing, if you had the choice of two would you choose the weak one or the strong one? I know which one I'd choose! Unless you are making a balls out race only motor which I doubt, I'd take a safer route to make my desired power output. A 1293 block will have less flex and move heat better. I'm not saying you can't build a stout 1380 but we all boil our motors eventually and you've got more chances with a 1293. You know it makes sense. |
19th Oct, 2010 at 08:02:58am
What's the difference between 1293 and 1380? About 0.080"? Is that really going to stop the block buring through between 2 and 3 on a problem engine? I believe it didn't for Shane. On 11th Feb, 2015 robert said:
19th Oct, 2010 at 09:33:48am
This is bollocks.
In the 13's at last!.. Just |
19th Oct, 2010 at 09:57:24am
Theres plenty of failed ones too! I know I've got one (not built by me) Guess where it failed. 1293 for me every time, but you go ahead with your 1380 and impress every one with your big numbers |
![]() 716 Posts Member #: 9077 Post Whore Cheshire |
19th Oct, 2010 at 10:05:04am
So because your engine failed you reckon that 1380's are 'weaker' than 1293? What a load of ball baggage On 2nd Nov, 2010 wil_h said:
I think it's probably a given that all people who own pink cars like it up the Gary. On 14th Jan, 2011 rubicon said:
please dont put a batty kit on it, il have to by internet law, Report you to barry boys.com |
19th Oct, 2010 at 10:09:38am
The question you should be asking is why it failed? I'm sure it wasn't down to the amount of metal between 2 & 3. More likely a failed head gasket, too much advance, not enough fuel, too much boost or a combination of all of them. As plenty of people have proven, a well spec'd and well setup 1380 will be fine. On 11th Feb, 2015 robert said:
19th Oct, 2010 at 10:43:44am
the only reason to go for 1293 is for the capacity to overbore later, use what you have if it fits your wallet and if your really bothered source another block and pistons for a 1293 once the 1380 is up and running Crystal Sound Audio said:
19th Oct, 2010 at 10:44:13am
On 19th Oct, 2010 quinton said:
See always one. Ok please explain why's that you agree with my dad? Is it just because of the meet left between 2-3? On 18th Oct, 2010 imaginearat said: Bollocks, 1380's are great for quoting big numbers in the pub by kids with big egoes. Listen up, with age comes wisdom, 1293 is a tougher setup with less chance of failure. Its worth spending a little more now than a lot later! Take your dads advice Crystal Sound Audio said:
19th Oct, 2010 at 10:48:59am
A 1293 is better, there can be no dicussion on this. However, that doesn't say that a 1380 won't work, as it obviously does. On 13th Jul, 2012 Ben H said:
19th Oct, 2010 at 10:53:19am
There were days when 1380 na's were only special race cars and were rebuilt all the time, many people would stay at 1293 or 1330
19th Oct, 2010 at 01:21:38pm
I can see I'm not going to change your minds but basic engineering theory dictates,
19th Oct, 2010 at 01:32:47pm
Right,
19th Oct, 2010 at 02:18:56pm
Exactly what Joe said!
19th Oct, 2010 at 03:01:22pm
Right I'm sticking with the 1380. I seriously can't see there ever being a problem between 2-3 Walls. With a comp of 7.5:1 to 8:1 and controllable boost which I won't be using all the times I.e I won't want full boost I can't see if ever going. Heat? Well she's never once reached half way on the temp gauge during summer giving it run so that's another theory gone. But thanks peeps least I've just had my thoughts backed up. |
19th Oct, 2010 at 03:08:41pm
Damn double post Edited by quinton on 19th Oct, 2010. |
