Home > General Chat > kinds of Carbs for forced induction?
jeffreypang911
Member #: 9074
What kind of carbs are people running?
specifically m45 supercharger, I see a lot of people using single SU carbs.
I thought when increasing more air, you would have to uprate your carb too, like a weber 40.
is my logic wrong? is there any power benefit to fitting a larger carb?
Jeff
On a turbo's mini is has been proven that a single 1.75" SU can flow enough air for well over 250bhp.
I don't forsee the 1.75" carb being an issue for the M45 which will never be able to reach these power levels.
You put it well John.
Mini_the_minx
Member #: 9077
Cheshire
If you run a suck through system then a single 1 3/4 is more than capable. If you run a blow through then a turbo carb is fine.
I have the second.
On 2nd Nov, 2010 wil_h said:
I have the second.
The Turbo SU is an 1 3/4". *tongue*
Jonny sti used a 45 on a suck through now has a blowthrough using a hiff44 and has more power!! If it were me i would use a 44 and change the long neck thing they use on suck through sc setups for aomething shorted as i have heard they can be a tad anoying on start up
Mini_the_minx
Member #: 9077
Cheshire
I know that silly, but it has the breathers in different places *tongue*
the n/a and turbo HIF44's can be used for either, most of the turbo stuff you block up anyway *wink*
Edited by Brett on 8th Nov, 2010.
Suck through is where carb sizing needs to match power output in terms of airflow.
When blow through, just ram boost down its neck and it'll work lol
jeffreypang911
Member #: 9074
then why do I see this?
Eaton m45 w/Weber? what is the purpose? maybe 1380?
EricsAmerica
Member #: 7891
Annapolis, MD USA
Mini Johnson? A bit overkill I would say on that setup....but who am I to say running dual 40's on a N/A setup....probably would get just as much power from a single 44...on mine and his...*oh well*
Edited by EricsAmerica on 9th Nov, 2010.
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
weber is just another carb, a case of use what you have, to be different or because you can, in theory no one carb should be better then the other, drivability maybe aslong as its correct sizing and fueling...
jeffreypang911
Member #: 9074
i suppose it is hard to wrap my head around how the SU carb could provide enough fuel if more air is mashed into the engine.
I was to run a weber setup because of this logic. that more air would need a better fuel delivery system for more fuel to get a better mixture.
Also following this equation that a single hif44 would be enough, why do people fit dual, and find the performance better? is it just different with forced induction, or even maybe supercharger specific?
Edited by jeffreypang911 on 9th Nov, 2010.
EricsAmerica
Member #: 7891
Annapolis, MD USA
Dual carb setups were designed to run when smaller carbs were the norm. This did help the flow issues somewhat with more direct intake systems with a carb facing directly at each intake port. Now with the hif44, more than enough air and fuel can flow with it along with better designs on the intake manifold and head. When you think about it, only one cylinder draws fuel/air at a time, so as long as the intake/head flow is at it's best, a hif44 should take care of the highest flow demands physically possible.
As for the weber, it is a very cool carb that was designed to be adjustable for just about any car on the road in the correct layout from the a series to a v12. I like them so much, I use 2... *hehe!*
Eric
Mini_the_minx
Member #: 9077
Cheshire
There are plenty of us running blow through supercharger set ups with HIF44 carbs. So far I've not met a supercharger runner, suck or blow through, that has had a problem running that carb.
But as said above it's totally down to you, there isn't really a wrong or right set up so find what works for you. I'll be sticking with my turbo carb.
The HIF44, has been proven to fuel for 250+bhp, and there is around 10 people now with the magic 200, all on HIF44s...
I'm a bike carb fan... just to get rid of the dash pot oil
Read my post
Blow through and suck through are TOTALLY different in how the engine sees them.
Carbs... Pah!
jeffreypang911
Member #: 9074
Read my post
Oh okay. Suck through=carb before pressure blow through=carb during/after pressure I presume.
Why do you see any mod that different, we all do different stuff, nothing is 100% correct as so much stuff works you can't say it's the "only" way of doing it :)
MadMatt
Member #: 105
Brisbane ,Australia
one of my mates (Big troy) runs a Mk2 escort with turbo,,, he`s got 360hp & running through a 36mm restricter
soooo , the way i see it,,, a single 1&1/2" SU should be good for that also---ish *smiley*
Edited by MadMatt on 10th Nov, 2010.
www.miniman.com.au
G13B
Member #: 1376
mikuni hsr:s are good for suck through, 42/45/48 mm flatslides
The only advantage I can see to using a webber and an M45 are to the profit margins of BP!!
But seriously, what power are you aiming at? As said above the HIF44 is suitable for big power blow through, but would you use a HIF44 on a 130bhp NA engine?
If not then look elsewhere for a suckthrough carb.
I would bear in mind that when using a supercharger, your engine is really making more power then it shows as you loose a signigicant amount driving the thing.
So maybe do your calculations on carb requirement on 150bhp for a 130bhp output.
Edited by wil_h on 10th Nov, 2010.
jeffreypang911
Member #: 9074
I think I will end up going for the SU carb instead. I would think an HS6 would be more than enough, but would I want to use a HS4 instead?
Id like 130-140hp.
