Home > Help Needed / General Tech Chat > painting car advice
eden7842
Member #: 8852
leicestershire
hey
im going to attempt a paint job on my girlfreinds mini (pink) wat paint do i need and how much? all advice wanted please
cheers eden
Without being awfull, if you no nothing about painting then dont do it.
Rick
eden7842
Member #: 8852
leicestershire
i know the basics, prep is the main thing. I like ask how hard can it be, so i wana give it a go
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Just take your time. Prep is everything, but if you don't lay it down right, you'll be sanding and repainting from now until your first borns wedding, lol.
-James
eden7842
Member #: 8852
leicestershire
and wats the best paint to use, 2k seems it but also seems that its not very forgiving?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I painted my mini myself and it came out perfect, I practiced on a punto first and painting little bits like my fuel tank. ive since painted my bmw and a nova i restored, its very easy if you get the best equipment you can afford. I bought a devilbiss GTI spray gun, and the biggest compressor i could get, and like miniswordsman says take your time.
2k i found was easier to paint with, i painted the mini and bmw in waterbased because i wanted a pearl metalic.
This link was invaluble for me and i definately recommend it:
http://www.mig-welding.co.uk/spray-painting.htm
even though its painted in a shed, i found it really easy. Total cost of painting the BMW about £100 materials and paint including loads of laquer
Edited by jamesfawcett on 17th Dec, 2010.
jamesfawcett
Member #: 218
and heres from painting the mini :)
hope this inspires you, its not difficult at all and i enjoyed the whole process
jamesfawcett
Member #: 218
Total cost of painting mini was about £150 - £200, because the paint was £55 a litre *surprised* but still i definately recommend having a go
The prep is the main thing really, and that takes alot of time,
on car i done a while ago i flatted the whole car in 240, then 400, the a high build primer, then flatted that done with 600 and scotch in places, final finish came out like glass, was extremely flat, but i spent the best part of 4 days doing it, wasnt in a big rush.
plus a week of welding and filling before, nothing worse than fillering over a little bit of rust , as next year it'l be back......
pot_dan
Member #: 326
bradford, west yorks
I just gave it ago too, I saved up to pay someone to do it and bought the paint but then ended up out of work so had loads of time and no money. I am glad I had a go but you can tell it's not right but next time it will be better. I did really enjoy it though.
Dan
http://turbominis.co.uk/car/105/
jamesfawcett
Member #: 218
hey danny yours came out well to say you hadnt had no practice! im sure it will come out much better next time :) it still looks great just after you have polished it though! :)
and wasnt yours 1pack paint too or something? or waterbased?
eden7842
Member #: 8852
leicestershire
cheers james, im defantly going to do it. where did you get your paint from and how many litres do i need. also what primer?
If it where me, I would just get a big can of paint and a firework. Can on the roof, lit firework in the can, then just run for your life. easy.
eden7842
Member #: 8852
leicestershire
sounds like a great idea but id like to get some paint on the car as apposed to all over my garage
Where's your sense of adventure?
eden7842
Member #: 8852
leicestershire
painting my gfs car at risk of failure thats the risk
scott the joiner
Member #: 9229
newcastle upon tyne
My bro painted an impreza after watching a couple dvds it was also a colour change & turned out amazing I believe it was all in the prep give it a go what's the worst that can happen u got to pay to get it done properly & u lose a couple hundred quid *smiley*
mayoturbo
Member #: 1395
chepstow
I think I will have a go at painting my cars myself too. How do you go about choosing the compressor, gun etc? Must be loads to choose from
Fortecphil
Member #: 7641
Jersey, CI
You'll need at least a 50lt compressor, the higher the cfm the better. Anything smaller just won't flow the volume of air required. As for the gun, the best you can afford, really. I prefer a gravity setup, however others are avaliable. It's best to get a couple of different sized cups/needles also, a 1.2mm - 1.4mm is best for most modern paints. Don't forget a moisture trap for the airline too.
Cellulose is best to start with, as you'll find it easier to work with and spray - modern micas and pearls are much more expensive, and more work to get right/blend should things go wrong.
Of course be aware that all metallic 2k paints need lacquer; as such air-fed respirators are highly recommended, in fact isocyanate lacquer isn't nice stuff and the vapours produced when drying are nasty - in a confined space this is very bad for your health! The down side is that you need a bigger compressor to feed both the gun and the mask.
As others have said, the process of spraying the paint is 5% of the work - preparation is everything!! (hours and hours of it!)
Good results are obtainable at home though - the more time spent preparing before, the better the finish will be!!
This weather isn't the most condusive to painting or refinishing, mind...!
Edited by Fortecphil on 18th Dec, 2010.
eden7842
Member #: 8852
leicestershire
how good is the simple hammerite smooth?
jamesfawcett
Member #: 218
last year i painted my nova in this weather in water based, it took almost two days to dry lol before i could put laquer on!
thats very good advice from fortec phil, i wish i could have got hold of 2k metalics i couldnt get it :(
mayoturbo
Member #: 1395
chepstow
By the time I prep the car it will be summer 2012 probably...
eden7842
Member #: 8852
leicestershire
how much primer and paint would i need ?
Fortecphil
Member #: 7641
Jersey, CI
Depends how much you're painting, tbh!!
I mean are you doing the Interior/boot/engine bay or just the outside...
eden7842
Member #: 8852
leicestershire
yeah should of said. Full exteria minus the roof
