Home > Help Needed / General Tech Chat > Turbo Minivan - weird misfire from cold on cylinders 1 & 2.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Hi guys.
Could really do with some advice about a misfire I’m suffering from on the van since rebuilding the engine over the winter.
I’m running Megasquirt MS1 direct fired wasted spark Ford coilpack, VR crank sensor and 36-1 toothed wheel. Up to when cylinder 4 popped on the RR last April, this had been running well since finishing the resto in 2008.
I rebuilt the engine over the winter with a lower CR (8.15:1) achieved using new cast 1293 Omegas which I have had machined to give 14cc bowls and I’ve fitted a NA MG Metro Cam which replaces the AP2, along with an RTS clutch. These are the only changes I’ve made. I’ve just got it all back together again and running.
The misfire I have is weird as it only occurs from a cold start and only on cylinders 1 & 2 and the plugs are noticeably wetter with fuel than 3 & 4 as shown in the shot below (Plug No 4 is far left, No 1 is far right).
No 2 plug, second from left is very wet but is also sooty showing that it’s trying to fire cleanly but is not being allowed to for some reason whereas 3 & 4 are perfectly dry and blackened from the use of a little choke to start.
This is a little weird as the coilpack fires 1&4 together and then 2&3 together so you’d expect any fault with cylinders 1 & 2 to also affect the other good cylinders which it isn’t. The only common theme with 1&2 is that it uses the same inlet tract and I suppose it could be a manifold gasket leak, but read on as the ignition is doing something weird. Thing is, a manifold leak would lean the mixture off in cylinders 1 & 2 rather than cause the obvious over wetting so I’m thinking this is an ignition issue rather than one of fuelling.
With help from Almichie, I’ve changed the coilpack (and run a new earth to the body), 20mF capacitor, put in new plugs (BPR7ES) gapped to 0.028in, tried new Mondeo leads (and swapped over 1 with 4 then 2 with 3), changed the crank sensor (today), all with no change.
A compression test from cold with a closed throttle shows the cylinder pressures within the 5% tolerance;
Cylinder 1 – 152 psi
Cylinder 2 – 152 psi
Cylinder 3 – 155 psi
Cylinder 4 – 160 psi.
The map value at idle is set to 11 degrees and this exactly matches the figure on the crank pulley with a strobe so there’s good correlation there.
However, with a strobe connected, the flash rate on cylinders 1 & 2 is noticeably slower than 3 & 4, and on cylinders 1 & 2 there appears to be a small gap in the flash indicating the misfire.
But why the hell is the strobe rate slower than on 3 & 4 when these are from different coils and by the nature of the coilpack, 1&4 are the same and 2&3 are the same ?
Could it be something to do with the dwell and spark durations in Megasquirt as I’m sure Rod S posted something up a few years back about the Ford coilpack being sensitive when directly driven by igniters in the ECU ?
This stopped me from getting to Bingley today and is driving me a bit mad.
Sorry for the length of the post, just wanted to get a few points over.
Any help much appreciated.
Cheers.
Richard.
hummm, weird,
try swapping the plugs round? 1&2 with 3&4?
shut the plug gaps up a bit?
turbominivanman
Member #: 1504
Westbury, Wiltshire
On 30th Jan, 2011 Joe C said:
hummm, weird,
Yep Joe.
Tried swapping plugs 1&2 with the 'good ones' 3&4 but the problem still comes back to plugs/cylinders 1 & 2.
Tried closing the gap down to 0.022 but no effect, so took them back to 0.028. Anyway, this is the gap I've always used and with the stronger spark from the coilpack, I'd argue this should be more like 0.032. 0.028 is a good compromise at the mo for testing til I get the misfire sorted.
I just wished I could chuck a dizzy in but I sold mine at the end of last year - dohhhh, what a muppet !!!
Anybody local got a dizzy and coil I could borrow ?
Richard.
Edited by turbominivanman on 30th Jan, 2011.
It was Paul S rather than me who pointed it out but yes, the coilpack is sensitive to charge/dwell times with Megasquirt when you fire it direct from the MS rather than through EDIS.
BUT, as you rightly say, if the charge/dwell times were wrong, or the coilpack degrading because they are wrong, it should affect 1+4 or 2+3, not your combination of 1+2.
However, there are some unsubstantiated stories going around occassionaly that Ford did have problems in the early days with wasted spark coilpacks because of the way they work - they don't use ground but as there are actually only two coils in a coilpack, the spark goes from one coil into 1, through 4 then back to the other end of that coil. Likewise, from the other coil into 2, through 3 then back to the other end of that coil. As a result, 1 and 2 get a positive jump, 3 and 4 get a negative jump (if that makes sense). Apparently on some models Ford actually specified a different grade of plug for 1&2 compared to 3&4.
Just to rule this out, I would swap the 1&4 leads and the 2&3 leads on the coilpack hence reversing the polarity of the sparks through the plugs but still keeping the wasted sparks on the right plugs.
EDIT - note, that is swapping the leads at the coilpack, not swapping the plugs like Joe suggested (end EDIT).
Finally, have you done a continuity check, all four HT posts to ground ??? Unlike a normal coil, there should be infinite resistance to ground as the HT should only see ground on its path between the two plugs, not at the coilpack.
Rod.
Edited by Rod S on 30th Jan, 2011.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Going off on a tangent....could this be more mechanical issues....sticking valves etc? Got a level compression readings, but was this done warm or cold?
Edited by Jason G on 30th Jan, 2011.
On 19th Jan, 2010 wil_h said:
turbominivanman
Member #: 1504
Westbury, Wiltshire
On 30th Jan, 2011 Rod S said:
..... swap the 1&4 leads and the 2&3 leads on the coilpack hence reversing the polarity of the sparks through the plugs but still keeping the wasted sparks on the right plugs.
Yes Rod, have tried the swap at the coilpack as well. No change, regardless of swapping over 1 with 4 or 3 with 2.
However, also interesting to note your comments about early coilpacks as the markings on the Ford sticker on the coil for HT posts '1' and '4' on the replacement that came from Almichie (thanks Al), are reversed in my original coilpack. The coilpack has a different part number as well, even though they look exactly the same.
..... have you done a continuity check, all four HT posts to ground ???
No Rod. Good point, I'll do that and report back.
Thanks.
Richard.
Star Mag
Member #: 375
Leicestershire
Can you rev through the miss or is it all the time? Does megasquirt have any trim functions related to coolant temp that could have altered. Seems a strange one. You say the earths are good these gave me some issues with my Megajolt.
turbominivanman
Member #: 1504
Westbury, Wiltshire
No I dont think this is a sticking valve issue Jason.
The comp test was done cold and gave good clean repeatable results on 3 separate occasions.
The misfire occurs at cold when you'd expect the vale clearances to be fairly loose as heat hasn't expanded the guides or valves at this point. It also doesn't explain why the strobe flash is slower and with gaps in the pulses on cylinders 1 & 2 - I think this is ignition related IMO, not mechanical.
I've also had the rocker cover off to check the tappets and clearances which are all fine and I've spun the engine over and all valves work fine on cranking and when the engine's fired, although I didn't do that for long as the rocker oil goes everywhere !
Richard.
The only other thing I can think of is your settings in MS aren't ideal for your new lower compression ratio, especially if it only happens when cold.
What settings do you have at the moment ?
turbominivanman
Member #: 1504
Westbury, Wiltshire
Thanks Ron.
I would admit, it feels like you can rev through the miss, yes, but if you hold the throttle at say 3k, you can still hear the dull missed beat in the exhaust, so it lulls you into thinking it'll clear. Once back at idle, the miss is audibly present.
Yes, MS does have a coolant temp advance/retard feature. I'll check it out to see if I can turn it off or at least make it work for me instead of against me.
I remain frustrated why I am getting selective changes to only one of the cylinders on each coil bank.
I have not touched any of the earths which are all inside the car in the dry since I built it. The same earth point is used for my fuel pump, ECU and all sensors. But I will check nonetheless Ron.
Weren't your problems to do with shielding the VR cable Ron ?
Ta.
Richard.
Is the crank sensor close enough to the trigger and does the trigger have any run out?
are the settings for the 36-1 trigger set correctly, and is the dwell for the coil set for 3ms? with battery compensation turned on? usually 4.5ms
turbominivanman
Member #: 1504
Westbury, Wiltshire
Rod/Sprocket.
In terms of crank sensor - I've set this up at 0.8 mm and checked at 4 points radially around the trigger wheel. Not really a sniff of a difference in the gap so runout tis pretty good but it's a bastard to get to.
Apart from a trigger angle of 56 degrees to cure a slightly misaligned sensor, I'm using a 5 degree crank advance angle and I'm using a 'fixed angle of -10' ie, following the map, with no trim angle.
These are my trigger settings:
Trig Pos A: 3
Trig return Pos A: 8
Trig Pos B: 21
Trig return Pos B: 26
These are my Dwell settings :
Cranking Dwell: 6.0 ms
Running Dwell: 3.6 ms
Min discharge period: 0.1 ms
Battery compensation: ON.
These settings have been with me since 2008. What are your opinions, are they ok ? Difficult to know what's optimal from the info on the MS forum.
Richard.
The settings are quoted slightly differently in MS2, ie, we don't have to set trigger and trigger return - but as the A and B are 18 apart, that shouldn't be the problem.
I do think the (running) dwell is a bit high though. I'm at the maximum recommended of 3.5, Paul dropped his to 2.8 (I think from memory) after misfire problems and possible coil damage and Sprocket suggests 3.0.
So although I'm closest, we are all less than you. So it's certainly worth dropping it to see what happens.
The selective changes affecting only 1 and 2 - if you swapped the leads at the coilpack end only (or the plug end only but not both at the same time) to reverse the current flow through the plugs and it made no difference, it does point to a mechanical/fuel issue such as you have already considered like an air leak. But it could be an air leak on 3 and 4 which you have masked with a slightly rich mixture so 3 and 4 run OK despite the leak and 1 and 2 foul because of the mixture.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Thanks Rod.
I'm away at present but will do as you anf Sprox suggest on Tuesday evening to reset the running dwell to 3.0 mS. I'll also check the coilpack resistance and if that doesn't sort it I'll probably start taking the manifolds off and check the gasket.
Interestingly, just thought about your comments regarding the mixture setting and for the first time I've had to screw the mixture screw right in to richen it enough to get a decent idle mixture. That's probably a significant lapse on my part to remember and point out.
Shit, was hoping to avoid taking the bloody manifolds off ! Will reset the dwell first.
Cheers guys. Will be back with results on Tuesday evening.
Much appreciated.
Richard.
Could you try your old dizzy? This would eliminate MS issues and tell you if your mixture etc is wrong.
tadge44
Member #: 2500
Buckinghamshire
Do try to keep up John, Richard told us earlier that he had sold the dizzy !
Me no ready very good sometimes.
tadge44
Member #: 2500
Buckinghamshire
Maybe so, but you must read bloody quick to have got back so fast !!
richard , although you say that a leak on the inlet to 1/2 would not make it rich ,a leak on 3/4 would make it rich on 1/2 if you adjusted the carb to be right for 3/4 .maybe thats why you have the screw in so far ?
turbominivanman
Member #: 1504
Westbury, Wiltshire
Yeah Robert, that's what I'm thinking too.
But why is the spark rate for 1 and 2 slower and with noticeable gaps on the strobe, than 3 and 4 ?
1 is slower than 4 but they're from the same coil and 2 is slower than 3 but they too are from the same coil. Surely none of that should happen even if there was an air leak present on the inlet tract to 3/4 ?
I'm gonna do the dwell and HT coilpack earth checks when I get back Tuesday evening.
Cheers.
Richard.
possibly the spark is running down the insulator which is wet from the rich mix ? so the kv doesnt build up to a high enough level to trigger the strobe ?
turbominivanman
Member #: 1504
Westbury, Wiltshire
I like that explanation, makes sense.
No 2 plug in particular is very very wet with unburnt fuel when you pop it out after a 30 second run from cold.
Might have to postpone working on the van tonight as the immersion tank in the cottage has just sprung a leak and I need to go plumbing tonight to fix the bugger !
Richard.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Right guys.
Managed a sneaky 20 minutes on the van tonight and reduced the running dwell from 3.6 ms to 3.0 ms.
Didnt make an ounce of difference. The car started and ran with the misfire still present, as equally as bad as before.
Didnt check the HT coil resistance which I'll do tomorrow but before removing the manifold gasket, I think I'd like to see what would happen if I chuck a dizzy in.
Anyone local near Chippenham, Bath or Bristol got an A+ dizzy and a coil I could borrow ?
Richard.
Kean
Member #: 341
aka T2clubby
South Staffs
Try spraying some carb cleaner around the manifold face to prove a leak in the gasket. My money is on fueling rather than ignition mate.
dischub
Member #: 8143
London
I reckon its fueling/air leak too.
If you get stuck I should have a A+ Dizzy lying around somewhere, but I'm not too local
Edited by dischub on 1st Feb, 2011.
Users viewing this thread: none. (+ 2 Guests)   Next ->
